Old 11-08-2012, 09:53 PM   #43
demby123
Drives: 86' Toyota Corolla GTSR5, 15' FRS
Originally Posted by FT-86GOD View Post
Watanabe is more suited to oldskool japanese cars but thats just IMO....... Needs to be negative offset atleast!!!
And slightly smaller diameter. Big watanabes just don't look right IMO
demby123 is offline   Reply With Quote
Old 11-09-2012, 05:33 AM   #44
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Originally Posted by Touge Factory View Post
Definitely won't need over fenders for that.
16x8 +0 should be able to fit without much issue. Would be even easier if the car is lowered on coilovers.
very curious how you figure that.
I think I figured out why people aren't liking these wheels as shown: offsets too tame and no lip
dori. is offline   Reply With Quote
Old 11-09-2012, 04:28 PM   #45
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
We have fit 18x9.5 +28 without any issues in the rear with 245/35/18
We have also fit 18x9.5 +28 with 225/40/18 up front. with still about 3-5mm clearance from the fender.
Camber was only at approximately 1.75 degrees.
16x8 +0 wheels would sit approximately 5-7mm further out then the 18x9.5 +28, but with the given clearance between the tire and fender, it should clear with slight tweak of camber. The rears with the 16x8 +0 should be easy.
Now if he wanted to run 255's or something on the 16x8 - would run into fender clearance issues up front for sure.
Touge Factory is offline   Reply With Quote
Old 11-09-2012, 04:45 PM   #46
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
Originally Posted by Hanzo View Post
Looks like a vinyl wrap to me:
Those are 15 x 6.5 with 205/65-15 and they look studable for ice I found my snows LoL
translated from Watanabe site
Vehicle model year Toyota GAZOO RACING 86: DBA-ZN6: Model 2012
Wheel Size
For Tarmac
F / R F8F 17-70 +40 100/5 Black
For gravel
F / R F8F 15-65 +35 100/5 Black
Tire Size
For Tarmac
YOKOHAMA ADVAN NEOVA AD08 225/45-17
For gravel
YOKOHAMA ADVAN A035 205/65-15
Andong Sadatoshi: Co-driver Car Sho Aikawa 1 2 driver name
Yu Suzuki: co-driver canon audition Kobashi Driver Car 2
Class participation
JN-3 class Sho Aikawa
JN-3 class canon Kobashi
【Specifications】 competing vehicle
Spartan65 is offline   Reply With Quote
The Following 2 Users Say Thank You to Spartan65 For This Useful Post:
DAEMANO (03-18-2015), ill86 (12-15-2012)
Old 11-09-2012, 04:47 PM   #47
Spartan65
Spartan65's Avatar
Originally Posted by m0nty View Post
Weak offset, too high, ugly side strips, tacky body kit and silly exhaust. Ruined is being polite.
Aside from those issues, this will be the look that is emulated when the 2013 is vintage.
Old 04-30-2013, 03:36 PM   #48
cyde01
ft86club resident b-boy
cyde01's Avatar
Drives: Yamaha R3, moonslate 2018 GT Black
not lowered, but much better fitment and MAGNESIUM! 12.8 pounds!!!!
F8 type 17x8 +35 matte black
cyde01 is offline   Reply With Quote
The Following 2 Users Say Thank You to cyde01 For This Useful Post:
chris x sway (01-08-2014), DAEMANO (03-18-2015)
Old 04-30-2013, 04:22 PM   #49
Flow
Drives: DGMBRZ
[/LEFT]
Looking at the Watanabe site, it doesn't look like the magnesium come in the 17x8, and the non-magnesium in that size are 8.7kg (~19lbs)...
Flow is offline   Reply With Quote
Old 04-30-2013, 04:39 PM   #50
cyde01
cyde01's Avatar
http://www.rs-watanabe.co.jp/pay/mg81516.htm
mag F8 eight spoke 5.8kg
they started making mag 17in in 2011.
link to those pics, even if you can't read japanese it clearly says mg in red.
http://www.rs-watanabe.co.jp/userspage/fujimoto-zn6.htm
Old 04-30-2013, 04:56 PM   #51
Flow
Drives: DGMBRZ
got it. my mistake. tks.
Old 12-01-2013, 06:56 AM   #52
Juvenile
Juvenile's Avatar
Drives: 86 GTS
17x8 unknown offset
Size:  97.8 KB Name:  85cf6d7cad.jpg
The Following 2 Users Say Thank You to Juvenile For This Useful Post:
DAEMANO (03-18-2015), diss7 (12-01-2013)
Old 01-08-2014, 01:48 AM   #53
chris x sway
chris x sway's Avatar
Drives: 2014 FR-S in Mayonnaise
I would love these in a negative offset please.
chris x sway is offline   Reply With Quote
Old 01-08-2014, 04:49 AM   #54
Yamajee
Yamajee's Avatar
Drives: Rocket Bunny'd GT86
+1
These wheels only looked good with negative offsets and 15-16".
Yamajee is offline   Reply With Quote
The Following User Says Thank You to Yamajee For This Useful Post:
chris x sway (01-20-2014)
Old 01-08-2014, 11:27 AM   #55
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
All these pics of narrow width and/or high offset watanabes on the 86 are frustrating. These are one of the most perfect wheels to go with the gt86. These desperately need to be at least 17x9 with at least a et35 or et30 offset (or, a much lower offset for a narrower 7-8" width - like et0-et20).
Does anyone have pics and/or know if a 17x9 watanabe in an et30 or et35 offset would have a noticeably bigger lip and look much nicer (compared to all these pics of unattractive high-offset 7-8" et40-et50 wheels)?
17X9 et30-35 isn't that crazy (it's not like a et0 or negative offset); so it's relatively still a little mild/conservative and very realistic. I'm wondering why no one has at least mounted a 9" et30-35 yet?! ...17x9 et30-et35 would be puuuurfect
btw:
Rota makes(has molds and is listed in their website) RKR replicas in 17x8 and 17x8.5 with 5x100 in nice low offsets of et0, et5, et10 and even available in the negatives. I can see an 8"+5 or 8.5"+10 easily fitting the 86 without any major problems nor modifications (except coilovers). These would be a fantastic alternative to real(and expensive) Watanabes and would weigh similar to the Watanabe non-magnesium versions anyways (not to mention you make a fuss and cry if you damage one at the track).
http://www.rotawheels.com/wheel.php?id=100
Wheeldude says he only needs 3-4 confirmed preorders, for Rota to fire up the kiln and press some new wheels for a special order
fooddude is offline   Reply With Quote
The Following User Says Thank You to fooddude For This Useful Post:
chris x sway (01-09-2014)
Old 01-08-2014, 12:34 PM   #56
wu_dot_com
Drives: accord
btw:
how much per wheel will that rota cost?
wu_dot_com is offline   Reply With Quote
