Old 07-30-2015, 05:56 PM   #43
Cross
It's the Mad Cow
Cross's Avatar
great attitude. Youll go far in life.
So a debate that's already happened you need to do again because you have nothing better to do and it's a bad attitude to not indulge the attention whore?
I can live with that.
Sent from my SM-G920V using Tapatalk
Old 07-30-2015, 08:47 PM   #44
celek
Resident Gear Head
celek's Avatar
If seen lightened cast iron flywheels take off people's feet when they shatter. I would not recommend spending $100 to have it lightened and balanced. Your passengers will thank you too
celek is offline   Reply With Quote
Old 07-31-2015, 03:08 PM   #45
CxG
Drives: Pearl White '13 ZN6
Originally Posted by industrial View Post
It may be worth considering a clutch and flywheel assembly that are balanced together. I run lightened pulleys, prolite flywheel and alum driveshaft and other than some cosmetic NVH issues, I have no drivability or CEL issues. I had my clutch and flywheel balanced as an assembly and the balance shop did have to make some adjustments to the clutch cover.
Also a driveshaft shouldn't have much to do with idle unless you have an automatic which you obviously don't. At idle you are clutch in or in neutral no?
Hey I'm a bit curious and have to questions for you
1) What do you mean by cosmetic nvh issues and it make it an annoying DD?
2) Also which lightened pulleys do you run? Crank pulley only or did you go all out and get everything from water pump to idler pulleys?
CxG is offline   Reply With Quote
Flywheel Chatter samisons Issues | Warranty | Recalls / TSB 13 12-05-2014 09:30 AM
Fs: act flywheel and clutch Guildjs Transmission and Driveline 9 05-18-2014 03:26 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
*Perrin Performance/Agency Power LIGHTENED Crank Pulleys In Stock* 10k Redline Engine, Exhaust, Bolt-Ons 7 10-15-2012 10:51 PM
Swap: factory 16s for factory 17s Sydney MZ21 Australia Classifieds 10 07-29-2012 10:46 PM
