CSG Mike, JRitt
Old 05-25-2015, 06:19 PM   #43
puma
crew chief
puma's Avatar
Drives: Race car FR-S
well it is too late, everything is now gone in the car
puma is offline   Reply With Quote
Old 05-25-2015, 06:40 PM   #44
86Nanny
haha. Well if you end up with car #2 and need an easier/cheaper route. Let me know and I'll be glad to help.
86Nanny is offline   Reply With Quote
Old 07-13-2015, 06:47 PM   #45
philooo
Drives: 13' Scion FRS Track car
I wanted to see if you solved your problem ?
I went to Homestead last weekend with brand new CL6E and new essex sprint kit, I tried my best to bed the pads, and had a good bluish coat after my first run but after the second session, I don't have the bluish color evenly on the rotors.
I have not yet removed the pads, I'll try to do that this week.
what's the update in your case ?
I had slight vibration in the steering on braking if I hammered the brake too much, after driving back at 75% for a few laps, the vibration went away.
the driver and passenger side rotor look similar to the photo below.
philooo is offline   Reply With Quote
Old 07-13-2015, 07:41 PM   #46
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
To the OP and possibly Philoo too:
Sometimes the answer actually might be: That's just the way it happened that time.
I shit you not.
That longitudinal taper is normal, however it is rather pronounced in your case but I think what caused the excess wear was also what exacerbated the taper.. That would be transfer layer. This happened on a CarboTech pad which have a poor reputation in regards to transfer layer (bedding). All it takes is a pad that can't quite bed-in to wear really fast, really weird or cause awful vibration under braking (uneven layer). Sure, there could be a problem with the car setup or the braking nannies or whatever but do not disregard the possibility that it may be simple, it may be a pad that didn't bed. I think the official bedding instructions of Carbotechs actually involve prayer...and maybe a sacrifice, well usually something ends up getting sacrificed.
I've been racing an under-braked car for over a decade now. I've tried just about every pad that's made for my backing plate and I've seen every problem a shitty transfer layer can cause and the OP (and Philoos) issues are ones I've experienced more than once and for me both were caused by the pad layer.
Another thing.. some pads will put down a buttery smooth transfer layer easily, each and every time, but only with new rotors. Other pads don't care if the rotor is used or not. I have 2 compounds I swap between and 1 prefers new rotors while the other doesn't care.
Finally: flip the pads on the rotor after a couple sessions, this will allow the pads to un-taper themselves longitudinally. Tapering is also a self perpetuating problem, once a pad starts to taper the rate at which it tapers accelerates during it's life. Flip those pads.
With a mono-block caliper you should experience little to no lateral taper (inside to outside of pad) like you would on a floating caliper.
SCCA T4 - FRS
The Following 6 Users Say Thank You to rice_classic For This Useful Post:
aegisdrgn (09-05-2016), Anthony (11-23-2015), BatStig (08-03-2015), CSG Mike (07-15-2015), endless_pain (07-14-2015), GSpeed (07-23-2015)
Old 07-14-2015, 10:37 PM   #47
philooo
thanks @ride_classic to make me feel a bit better, hopefully it is only the pads.
My next question will be : should I dump this set of pads and hope may be next set will clean up the rotor uneven wear ? or my rotor will keep these mark forever most likely ?
In my case the car was just aligned by a reputable race shop and I do the pedal dance each time before I went on the track.
what pads are known to be easy to bed in I think I need one of these because it seems the OP also had problem with the CL6 pads.
Old 07-15-2015, 12:05 PM   #48
rice_classic
I use only "race-only" compounds but in that vein I like the Raybestos ST42 and ST45 and the Cobalt XR1.
Ping @CSG_Mike and ask him as well, they carry and have experience with compounds that I'm unable to try (not made for my application) and may be ideal.
SCCA T4 - FRS
Old 10-11-2015, 06:15 PM   #49
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Any updates on this?
Sleepless is offline   Reply With Quote
Old 11-21-2015, 11:23 AM   #50
DarkSunrise
DarkSunrise's Avatar
I've been having a similar issue lately. LF pads wearing much more quickly than RF, particularly the inner pad which has a tapered wear pattern. Last 4 track days were at Summit Main and VIR which are CW, so that might be my issue.
I'm on a mild setup - stock brakes with XP10 pads. My last set of pads lasted 6 track days, so I'm not nearly as hard on the brakes as others. I'm going to either rebuild the caliper or put in a remanufactured caliper, and switch to XP12 pads and fresh rotors. Fingers crossed...
2022 BRZ Build
2013 FR-S Build
Old 11-23-2015, 12:16 PM   #51
ubernostrum
Drives: 2013 Subaru BRZ Ltd GBS 6MT
Are you doing the pedal dance? I had an issue with the EBFD causing uneven wear on the fronts with the AP Sprint kit. That was when I was just doing the 5 second push to turn off TC. Once I started doing the pedal dance the wear became normal and even.
ubernostrum is offline   Reply With Quote
The Following 2 Users Say Thank You to ubernostrum For This Useful Post:
CSG Mike (11-23-2015), DarkSunrise (11-23-2015)
Old 11-23-2015, 12:22 PM   #52
DarkSunrise
Just the 5 second press. I'll try the pedal dance next - thanks for the tip!
2022 BRZ Build
2013 FR-S Build
Old 11-23-2015, 12:26 PM   #53
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
Which track are you running at? I did a lap at Street of Willow with 5 second press, and the nannies kept interfering. So annoying, and definitely held me back. Pedal dance solved all of that.
LOLS2K is offline   Reply With Quote
The Following User Says Thank You to LOLS2K For This Useful Post:
Old 11-23-2015, 12:50 PM   #54
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
A+ read. Hoping for an eventual movie adaptation.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following 2 Users Say Thank You to Anthony For This Useful Post:
ATL BRZ (11-23-2015), RavioliG (11-22-2019)
Old 11-23-2015, 01:05 PM   #55
DarkSunrise
My last 2 track weekends were at VIR and Summit Main. I can only think of a handful of times when I felt something kick in slightly mid-corner, but it's never spun me out so I never bothered doing the full pedal dance. If it will fix my brake wear issue though, I'm all for it.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
CSG Mike (11-23-2015), LOLS2K (11-23-2015)
Old 05-17-2016, 12:50 PM   #56
ZionsWrath
Thanks
ZionsWrath's Avatar
Just used a new set XP10 this past weekend. They are tapering top to bottom, rears wear normal. I guess its same thing, need do pedal dance?
The Following User Says Thank You to ZionsWrath For This Useful Post:
ATL BRZ (05-17-2016)
Will OEM STi (2004) 17x7.5 +53 fit a BBK (AP Racing sprint/Willwoods)? dejxx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 12-25-2014 03:28 PM
No squeal pads for AP Racing Essex Sprint Kit Hags86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 04-04-2014 04:53 PM
AP Racing Sprint kit with OEM rims dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 02-18-2014 08:47 AM
SoCal Selling AP Racing Sprint Kit evilconcarne999 Brakes, Suspension, Chassis 7 04-02-2013 08:06 PM
