Old 02-19-2015, 09:47 PM   #43
Ultramaroon
not playing cards
Ultramaroon's Avatar
In Australia? in the summer? It just reached it's high temp limit and temporarily cut out.
I respectfully concede, sir. VERY much in the realm of possibility.
Old 02-19-2015, 09:52 PM   #44
Possibility is the key word there! It certainly could have been something else but from the information we have (circumstantial as it is) the root cause seems evident.
Can do a fish bone up if you would like!
Old 02-19-2015, 09:53 PM   #45
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Tomking View Post
This car has a electric power steering unlike other cars using oil pump power steering. When the electric motor died you are actually working against the power steering motor that why it is much harder to turn however it is not impossible.
When you are experiencing this situation at high speed on the freeway for the first time (without knowing there is problem) you will know how frighten that is..
Wuh? The electric motor doesn't have that much force in it, although I do agree it would be scary for someone in the first occurrence. But I'm usually that **** that plays the game with my friends like whether or not I can make it through the entire neighborhood with the engine off and still get in the driveway......
Old 02-19-2015, 09:58 PM   #46
Ultramaroon
not playing cards
I'll get behind that in a heartbeat. ...for fun!
Old 02-19-2015, 10:00 PM   #47
Oh ya they are a blast!!!!
Old 02-19-2015, 10:00 PM   #48
Ultramaroon
not playing cards
Oh, it's on.
Old 02-19-2015, 10:26 PM   #49
WesleyG
Drives: 2014 Satin White Pearl GTS auto
turn your car off then try to turn the steering wheel and see it for yourself...
I have many times, I have a PFC, and the PS switches on when you turn the key to the 'on' position and not when the engine is running, so I have to remove the PS fuse when trying to jump start the car, and leave the PS off for a little while, and drive the car around to let the battery charge as it's a big drain on power. It's stiff but not too bad
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
Old 02-19-2015, 10:40 PM   #50
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Whenever you two get started in the same thread......
PandaSPUR is offline   Reply With Quote
Old 02-19-2015, 10:52 PM   #51
Ultramaroon
not playing cards
In our defense we were actually considering a formal analysis of OP's <ahem> issue.
....well, talking shit about considering it, at least.
Old 02-19-2015, 11:13 PM   #52
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
At highway speeds it will not be an issue...at parking lot speeds it will be more difficult but still manageable. I had the power steering go out on my Camaro track car and I didn't even know it until I came in at the end of the session...and then I KNEW it! 275/45-17 DOT-R rubber all around on a 3200lb car with a smaller diameter Sparco racing steering wheel....steering wheel was flexing and bending when turning in the pits. That was a fun drive home...LOL
I also depowered and devalved the power steering rack on a '90 Integra RS that was daily driven.... steering feel was even better than the FRS and not too bad at slow speeds with a 320mm Momo wheel, 2300lb car though.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 02-19-2015, 11:41 PM   #53
FRSBRZGT86FAN
Oh, it's on.
Like legit it was really really bad what we would do because we were all gearheads and bear in mind I'm 20 and this is when we were just 16 and got our licenses. We would literally go as fast as we could through a neighborhood drop in neutral then turn the car off and make it through in "stealth mode". We would have parents picking up other kids yelling at us and stuff the entire time, we did other stupid shit too like trays under our back tires we stole from the cafeteria and stuff but I thought in hind site that the "stealth mode" thing was the most reckless and stupid thing we did.
Old 02-20-2015, 12:02 AM   #54
Tomking
Drives: FT 86
Good news everyone
Toyota Australia willing to replace the electric Power Steering motor and Power Steering ECU unit (did't know they have a separate ECU for the Power Steering). This is the instruction from the Top.
Good on you Toyota Australia, excellent customer service.
For those who argue about the steering, you obviously has not own an 86, if you do, just try to turn your car off then try to turn the steering wheel to see if you can make the full circle.
For anyone having similar issue and cannot get the local dealer to agree to fix the problem, I would highly recommend to contact Toyota for the nation rather than the local dealer, they operate independently and will not go the extra mile for your Warranty services. The local dealer was going to send the car back to me as it because they could not replicate the fault.
Tomking is offline   Reply With Quote
Old 02-20-2015, 12:35 AM   #55
Poodles
Drives: 2015 Series.Blue
I own a BRZ, which has the same exact parts as the FRS/GT86 (it's the same fing car!) and it's not that hard to steer the wheel with the assist off. Try steering a Miata with a manual rack with wide and sticky Z rate tires on and we'll talk.
Maybe you need to hit the gym...
Also, you said something about a full circle, what were you trying to do? A U-turn or a switchback? Seriously something doesn't add up here, but good on Toyota for taking care of the issue.
Old 02-20-2015, 12:41 AM   #56
WesleyG
I have driven manual steering cars before.... In SA there are alot of older cars so finding one without PS is easy...
maybe this guy could help
2014 37J 86 Auto
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 03:41 PM
power steering ender2664 Engine, Exhaust, Transmission 32 03-21-2015 04:16 PM
Electronic Power Steering Failure tjdiz92 Issues | Warranty | Recalls / TSB 17 06-18-2014 01:34 AM
Electronic power steering Mathewgzlz Issues | Warranty | Recalls / TSB 9 01-22-2014 01:50 AM
Electric power steering madfast Scion FR-S / Toyota 86 GT86 General Forum 33 10-13-2011 10:11 AM
