Old 01-11-2015, 02:56 AM   #43
extrashaky
Drives: 2014 BRZ Limited
Those are fine if you like the shark fin look. I'm not a huge fan.
If I were going to get a shark fin, however, I think I would go with OEM instead of Beat-Sonic. Starting in 2015 the BRZs came stock with shark fin antennae from the factory. You can order the OEM shark fin and put it on an older BRZ. The OEM antenna is about $40 more.
I have a Beat-Sonic Blaid on mine. It's the one goofy bit of rice I allow on my car. I have a like/hate relationship with it.
Old 01-11-2015, 04:53 AM   #44
chubky
chubky's Avatar
Drives: 2014 Scion FR-S Monogram
Valenti taillights!
chubky is offline   Reply With Quote
Old 01-11-2015, 01:46 PM   #45
TheVoiceOfReason
TheVoiceOfReason's Avatar
Drives: BRZ Limited
Consider some weathertech floor liners if you care about your carpet. It's nice to always be able to get in not worrying about what's on your feet.
TheVoiceOfReason is offline   Reply With Quote
Old 01-11-2015, 02:56 PM   #46
FloridaBRZ
Drives: 2013 Subaru BRZ Limited 6sp DGM
If the $700 is just burning a hole in your pocket, the biggest bang for buck ratio is an Open Flash Tablet.
I totally agree with this statement.
FloridaBRZ is offline   Reply With Quote
Old 01-11-2015, 03:17 PM   #47
BlackMonarch
Drives: Red BRZ
OFT + UEL catted header. Done. Enjoy your extra 30whp and a great sound.
BlackMonarch is offline   Reply With Quote
Old 01-11-2015, 03:36 PM   #48
Formula Vee
Lando.Ricciardo.Hamilton.
Formula Vee's Avatar
Drives: 2014 SWP BRZ Limited (MT)
When I purchased my SWP Limited, I considered Tom's Tails and a TapTurn flasher to be mandatory purchases. I am not a fan of the stock tails, and the flasher provides OEM functionality to the Tom's. Red Tom's look great on SWP/Whiteout. I also swapped in lots of LED lighting from Diode Dynamics -- I've done sidemarkers, dome, door, trunk, rear plate, and reverse lighting. The issues people have had with the LEDs frying electronics is from using metal tools to remove/install lights. Don't do that and you'll be fine.
All of the cosmetic stuff is subjective, of course.
OFT Stage 1 -- Grimmspeed Strut Tower Bar -- Perrin Inlet Tube -- K&N Engine Filter
Formula Vee is offline   Reply With Quote
Old 01-11-2015, 04:09 PM   #49
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
I'm in a similar situation (having just bought my BRZ) and here's my opinions so far:
tldr; I'd only consider the bolded stuff, but YMMV.
1. Exhaust: I'm content with the stock one, since 2015 came with bigger tips and I don't want a loud exhaust. There's really no other point to an aftermarket exhaust on these twins unless their boosted, you want more noise, or you want bigger tips.
2. Intake: I was going to just get a drop-in filter until I saw the SuperTek intake kit. $90 for new intake + filter + sound tube delete.
3. OFT or any other Tune: I'm gonna avoid this since I think the gains are negligible. And I also want to go FI in a year or so, which means the OFT would be a waste.
4. Interior: Like some others have said, having a Limited trim already sorts out most of the interior for us. I still like the JPM Coachworks stuff though, especially the knee pads and speaker trims since the stock ones aren't actually padded.
5. Exterior: Again, since we have the Limited trim, we dont need aftermarket HIDs or DRLs. So unless you're itching to change the taillights, you're set. I'd consider clear or smoked side markers though.
6. COSMETIC MAINTENANCE! This was a big one for me and the only actual "mods" I've bought so far. Custom fitted car cover for when its in the drive way. Bumper bully for when I park in the city (put it away in the trunk when driving, which people forget to do). Optimum No Rinse for all cleaning needs. 303 Aerospace protectant for the interior. When spring comes around I plan to get a clay bar, Blackfire Crystal Seal and Collinite #915 wax.
PandaSPUR is offline   Reply With Quote
Old 01-11-2015, 06:24 PM   #50
MikeM7
Drives: 2013 BRZ Limited White
Sounds nice, but think it would put me over budget.
MikeM7 is offline   Reply With Quote
Old 01-11-2015, 06:27 PM   #51
MikeM7
Do you have links for these?
Old 01-11-2015, 06:29 PM   #52
BlackMonarch
Drives: Red BRZ
In retrospect, yes it would. I apologize. I remain resolute that an OFT is your best choice. It both provides a siginificant improvement over stock, while allowing you to plot out what mods you'll do in the future, as well as already having the tool required to tune the engine to support them.
That being said, I would go OFT + downpipe+testpipe. I did the downpipe\testpipe combo from TopSpeed Auto and they sound wonderful, while not droning at highway speed. Freed up some torque too, and the dip is now minimal.
Also I noticed you're asking for links for these things; ft86speedfactory is the main site I use, however I often use that site to find the part I want, and then find a much better deal for it on eBay.
Old 01-11-2015, 09:16 PM   #53
PandaSPUR
PandaSPUR's Avatar
Yep, here's the intake kit:
http://www.ft86speedfactory.com/supe...lter-1346.html
And here's one of many places to get the side markers:
http://www.ft86club.com/forums/showthread.php?t=57650
There's a lot of options for sidemarkers, I haven't looked them all up yet though, so thats up to you.
Old 01-11-2015, 09:51 PM   #54
extrashaky
The JDM Toyota clear side markers are the best looking of all of them. They simply look like they belong on the car.
If you go with clear side markers, be sure you also get AMBER replacement bulbs to go inside them. It's not legal in the US to run white lamps in clear side markers. Either the lamp has to be amber, or the lens has to be amber, so that it shows amber light to other motorists.
I bought a set of amber LEDs for mine for $6 each from a guy on the member classified board. Cheap LEDs that work just fine.
Old 01-11-2015, 10:51 PM   #55
MykeH78
MykeH78's Avatar
Drives: 2014 BRZ 6MT WR Blue Met
I paid @ 700-800 and got alot of stuff as a package deal. HMU if you want the exact details. Prob about everything u would wanna do to keep u happy 4 a while.
MykeH78 is offline   Reply With Quote
Old 01-11-2015, 10:53 PM   #56
MikeM7
Ok, so here's the conclusion I've come to.
Arm Rest $75
http://www.ebay.com/itm/13-14-SCION-...f16cba&vxp=mtr
Full Interior Black Trim (-door handle/lever, shifter) $116
http://www.ft86club.com/forums/showt...ight=vent+trim
Spacers $100
http://www.corner3garage.com/V3-Spac...WRX_p_482.html
Intake/Filter/Delete $90
Side Markers (Super White LED) $150
$531 dollars and covers interior and exterior aesthetics, plus 5 or 6 HP, and leaves me some leftover to put away towards a sub later.
After driving it a good bit today, I realized the only thing I really feel like it's missing is aesthetics and a good sound system. Anyone want to recommend a sub? Are the ones with built in amps good?
Let me know what you guys think of my picks.
Thanks for your help.
New owner of a CPO (Certified Preowned) BRZ. Question with previous owner's audio mod tekniq BRZ First-Gen (2012+) — General Topics 2 12-05-2014 04:15 AM
WTB Red Bumper, Left Fender, Left head light, Clear side markers carlossanchez89 Want-To-Buy Requests 0 09-01-2014 04:43 PM
new owner: first mods revlimit Scion FR-S / Toyota 86 GT86 General Forum 14 11-05-2013 11:27 PM
Tonight: I need a Portland BRZ owner and S2000 owner! DarrenDriven Northwest 2 06-19-2012 03:40 AM
Forum owner should change the top left image of the forum Hanzo Off-Topic Lounge [WARNING: NO POLITICS] 68 01-27-2012 11:33 PM
