Old 03-14-2013, 06:08 PM   #43
ranisron
Drives: 2013 SWP BRZ Limited #2344
bumping this thread to the top. I have similar set up but haven't test fitted (due to Chicago winter). I am contemplating to get a 3mm spacer just to bring down the offset a little bit.
Will this wheel/tire (from the WRX 235 width) rub the front struts?
ranisron is offline   Reply With Quote
Old 05-21-2013, 12:58 PM   #44
Asphalt~86
Drives: Asphalt AT
Anyone know if the centercaps from the stock BRZ/FRS wheels will fit these?
Asphalt~86 is offline   Reply With Quote
Old 06-21-2013, 05:51 AM   #45
kkoh
Drives: GT 86
Sorry for bringing up an old thread
Just wondering if anyone has anymore to report in regards to rubbing on the front strut? Does this only happen at full lock?
Kenneth
kkoh is offline   Reply With Quote
Old 06-21-2013, 08:42 AM   #46
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
It happens if you have any camber. You need coilovers to gain camber. Lowering springs or crash bolts will add too much camber to let these fit. Unless you use springs then REDUCE camber with the bolts.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 07-11-2013, 03:24 PM   #47
jshum
jshum's Avatar
Drives: Scion - FRS
So does that mean stock suspension will be ok?
I am looking to pull the trigger in the weekend to get a set.
jshum is offline   Reply With Quote
Old 07-11-2013, 03:35 PM   #48
Kido1986
Dodging cones
Kido1986's Avatar
Completely stock, yes. Coilovers, yes (depending on alignment). Lowering springs or crash bolts to gain camber, no.
Old 07-11-2013, 03:38 PM   #49
jshum
jshum's Avatar
Drives: Scion - FRS
What about just lowering springs with 0 camber??
Old 07-11-2013, 09:57 PM   #50
Kido1986
Dodging cones
Kido1986's Avatar
When you lower the car you will gain camber. You'd have to use bolts to dial the camber back out.
I sold my WRX wheels to a local with springs. He had to dial the camber back with bolts to almost 0 to fit them.
Old 08-07-2013, 11:25 PM   #51
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
Anyone get weights on these?
Kostamojen is offline   Reply With Quote
Old 08-08-2013, 02:57 AM   #52
chonody
Drives: 2013 Subaru BRZ
I'm the one with them now and the most camber I can run is about -1.2 before rubbing on the lower spring seat and spring with camber bolts.
chonody is offline   Reply With Quote
Old 08-08-2013, 08:53 AM   #53
Kido1986
Dodging cones
Kido1986's Avatar
Ah, I thought you told me you had to dial almost all of the camber out to fit them.
Old 08-12-2013, 11:17 PM   #54
Caboose
Drives: WRB BRZ Premium
Let me know if you or anyone does this. I'm considering the same set up.
Caboose is offline   Reply With Quote
Old 09-06-2013, 01:04 AM   #55
ranisron
Sorry just saw the bump to this thread.
I have been running the MY2011 WRX wheels and tires (235/45/17) this summer. It rubs at full lock (stock alignment).
In the past week, I added 5 mm KIC spacers to all four corners which helped with the rubbing issue (now GONE). HOWEVER, due to the spacers not being hub centric, I got a little vibration at high speed (85+ MPH).
EDIT:
I also want to point out that the WRX stocker MY2011 wheel/tire combo is way grippier than the stocker Michelin. Imagine how good this car can handle if you put some serious rubber (not the Dunlop Sport Maxx from the WRX)... Also, from all the threads I have read so far, by the time the tires are worn, I am getting 225 series tires. 235 weighs too much.
Old 09-08-2014, 03:34 PM   #56
ort895
ort895's Avatar
i know you guys are going to hate me for bumping an old thread but my question never really got answered. With 235's they rub at full lock, but what about with 225's? Will 225's make a difference?
ort895 is offline   Reply With Quote
WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel RavSpec Wheels and Tires 72 12-04-2012 03:58 PM
TE37SL - 17x8.5 / 17x9.5 / 18x9.0 5x100 Pre Order Available Now ! RavSpec Wheels and Tires 2 07-14-2012 10:37 PM
Wheels Magazine June 2012 Nardi330 AUSTRALIA 66 06-14-2012 10:28 PM
17x8.5 wheel selection Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 06-10-2012 03:13 AM
GrimmSpeed BRZ is Here! GrimmSpeed Member's Car Journals 19 06-01-2012 12:59 AM
