Old 09-29-2014, 11:12 AM   #43
PandaBRZ
PandaBRZ's Avatar
Drives: SWP BRZ
Air fuel ratio.
Read my writing about the BRZ on my website.
PandaBRZ is offline   Reply With Quote
Old 09-29-2014, 11:18 AM   #44
s2d4
s2d4's Avatar
Originally Posted by PandaBRZ View Post
Air fuel ratio.
Implications bro, not the unabbreviated words.
Old 09-29-2014, 11:38 AM   #45
Pat
Pat's Avatar
Drives: 2023 BRZ
I'm really surprised the AFR increases by a full point with a K&N filter. Do we know if the OEM filter used as the baseline was a new/clean one or could it have been dirty?
I love regular maintenance that gives me an excuse to modify and improve the performance of my car. When it comes time to replace my air filter I may get a different style of filter.
That said, I'm concerned about this AFR chart. I get about a dozen or so track days in per year, and am concerned about running lean. Do any of you track guys have evidence to show this is safe in that environment?
Old 09-29-2014, 11:39 AM   #46
PandaBRZ
PandaBRZ's Avatar
Drives: SWP BRZ
Ah my bad. From my basic understanding of AFRs, the graph looks to me to imply that panel filters have an AFR curve that's more stoichiometric, or an ideal AFR. This means the engine is running at its peak without being too rich or lean and is making a bit more power because of the drop in filter.
I could be reading the chart all wrong so please, someone correct me.
Old 09-29-2014, 11:44 AM   #47
PandaBRZ
PandaBRZ's Avatar
Drives: SWP BRZ
Also some interesting research from Grimmspeed for their own intake.
"The silicone elbow doesn't appear to have much of an effect on performance (1-2whp with the stock filter and less with the K&N)."
Old 10-02-2014, 06:35 PM   #48
FR-Sizzle
Drives: brz
People need to realize that when people are adding inlets/ducts that it is also to improve throttle response. On my s2000 I had the spoon duct and even though it didnt add anything on a dyno you could feel the difference in throttle response when your at cruising speed and on the freeway. Once you go faster the ducts then do much better.
You cant imitate freeway speeds with just a dyno fan blowing air into your hood. Thats what people dont understand when it comes to ducts. You arent going to get any enormous gains like you would with CAI. But you do increase throttle response and keep the stock air box and those are actual gains unlike other intakes that just lean out the AFR's. Once you get a tune those intakes dont add shit since the stock oem air box is so well designed already. Your just going to make it harder for the tuner to tune your car by modifying your intake. If anything do that last and get your CBE and headers first.
FR-Sizzle is offline   Reply With Quote
Old 10-02-2014, 06:38 PM   #49
FR-Sizzle
Drives: brz
Originally Posted by Timmy_Jones View Post
Not worth it from a power perspective.
Why would you say that? 1-2 whp for 100-150 bucks that will only get better when you get more mods done to your exhaust and headers. The inlet allows more air/volume so it will produce results especially when you start doing other mods.
Perrin for example saw a 3-4 whp bump by adding there inlet to their CAI after modifying their cat back exhausts/front/over pipe
Old 10-02-2014, 08:30 PM   #50
zooki
Drives: waiting on a 2021...
You have to understand the position of the air inlet on these cars in front of the radiator is in a high pressure area already. Air basically "stacks up" in front of the radiator at speed. Having the inlet facing sideways or facing forwards doesn't really make a difference. The grill opening, radiator, and headlight assemblies create a big high pressure "box". I think Grimmspeed's pressure testing confirmed this. Also at it's smallest point the stock snorkel is as big as the throttle body, so it's not really a restriction. Again, both Grimmspeed & Cosworth confirmed this through testing.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 10-03-2014, 12:33 AM   #51
cmdboy_347
Drives: '13 FR-S, '12 CBR1000RR, 10 Cayenne
I have the Perrin drop in and i barely noticed any differences in performance except for the engine noise.
cmdboy_347 is offline   Reply With Quote
Old 10-03-2014, 01:15 AM   #52
s2d4
s2d4's Avatar
There is so much wrong in this post, don't even know where to begin.
Old 10-03-2014, 08:29 AM   #53
Timmy_Jones
Spun
Drives: 23' Supra
No one, will EVER notice 1-2WHP. Would you spend $150 on something you wouldnt notice?
Timmy_Jones is offline   Reply With Quote
Old 10-03-2014, 08:39 AM   #54
rs999
rs999's Avatar
Drives: VW MK6 GTI | 13 Mustang GT
The tube is really only good for removing the sound tube from the passenger side.
Really doubtful you'd experience any performance improvements from this mod.
SOLD FR-S Build | MK6 GTI Build | I might be getting another FR-S
rs999 is offline   Reply With Quote
Old 10-09-2014, 01:56 PM   #55
Supertek Industries
Supertek Industries's Avatar
We saw +6whp gains when paired with our filter.
Supertek Industries is offline   Reply With Quote
Old 10-09-2014, 03:17 PM   #56
lucid215
can you show some kind of proof of this? not trying to bash, im more curious and tempted on getting this. was it tuned as well to get that or just a replaced and untuned?
lucid215 is offline   Reply With Quote
Simple Sound Tube Switching "on/off" Tech DIY (Do-It-Yourself) Guides 266 03-10-2021 04:12 PM
Perrin 2.5" Unresonated Cat-back, Zeta Intake Tube SportInjected Engine, Exhaust, Bolt-Ons 7 08-14-2014 06:48 AM
Perrin 3" Intake and Inlet Tube 14BRZ Engine, Exhaust, Bolt-Ons 6 06-03-2014 12:35 AM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
*NSFW* "Check Out My Subaru" on You Tube Axel Other Vehicles & General Automotive Discussions 4 01-17-2010 05:56 PM
