Old 04-01-2015, 08:30 PM   #43
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Originally Posted by Avo1789 View Post
How have these been working for you guys? My main concern is if the adhesive will hold up when my car is roasting in the CA sun all day.
so far, so good! The adhesive on these things is pretty impressive.
Its made by 3m, the same people who make the double sided sticky tape with red backing, thats used for lips, spoilers and other exterior car parts.
Obviously this stuff is way thinner, but same idea.
Old 04-01-2015, 08:37 PM   #44
Stark Performance
Drives: 2014 FR-S
I too was concerned about how well the adhesive would hold up in Southern California summer. The standard 3M VHB you pick up at the auto parts store doesn't cut the mustard (tested it myself) in this application. I tested a better adhesive that has a high heat tolerance, but it would get flimsy after being in the sun all day and eventually failed. The stuff I use now has a long term temperature tolerance of 300 degrees Fahrenheit and a short term temperature tolerance of 500 degrees. Sounds like overkill, but it doesn't get gummy or flexible after being in the sun all day and hasn't failed either. Even when the paddles are almost too hot to the touch, the connection is very firm and has a crisp feel to the engagement of the paddles.
Stark Performance is offline   Reply With Quote
Old 04-02-2015, 02:08 AM   #45
Avo1789
Avo1789's Avatar
Drives: Ultramarine FR-S
Awesome, thanks for the reply!
Sent from my SCH-I545 using Tapatalk
Avo1789 is offline   Reply With Quote
FIRST fs: Scion 10 series shift knob! (actually pretty cool) jacobzking Interior Parts (Incl. Lighting) 23 08-08-2016 10:34 PM
DIY: Installing Stark Performance Shift Paddle Extensions for the A/T FRS/BRZ continuecrushing DIY (Do-It-Yourself) Guides 19 02-23-2016 10:04 PM
AT Paddle Shift Replacement Feeler Thread Hancha Group Cosmetic Modification (Interior/Exterior/Lighting) 71 11-05-2015 04:58 PM
Auto Trans paddle shift issue Craig Issues | Warranty | Recalls / TSB 26 08-17-2015 10:00 PM
Can you manually shift automatic version w/out the paddle shifters? maxeveland Scion FR-S / Toyota 86 GT86 General Forum 31 02-01-2012 11:51 AM
