Old 07-05-2012, 06:46 PM   #43
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
Originally Posted by jeebus View Post
unless of course, you set the advance multiplier to 1 through a tune.
Multiplier tables are 2d, that is why I asked Jon what the other variable was that effected the multiplier table, depending on what is being looked up could adversely effect the tune if you just went and set it to 1 for the entire table. If I had to guess it would be timing vs. coolant temp, as both a safe mode (romping before the engine reaches operating temp, and also to increase cat heating). Jon is this correct? Since you are the man with the tables infront of you.... Still cheating HaHa
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline   Reply With Quote
Old 07-05-2012, 06:48 PM   #44
jedibow
Originally Posted by Boxer-Guy View Post
It would be awesome if a tune by it self would offer just 20-25whp.
We just have to wait and see.
Oh and thanks for message Boosted2.0
Factory tunes are consevative, but not that conservative. In order to see those numbers there will have to be a mechanical change in the breathing aspect of the engine (Intake, Header, Exhaust, cams, porting, valves...)
This in in reference to the TUNE only, not the maximum total change in horsepower by adding the above...
G
Old 07-11-2012, 03:31 PM   #45
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Although that might be the case for Toyota ECUs this is not the case for Subaru - the ecu in these cars.
After ecu reset the car does not run maximum advance. Car needs to e given a drive cycle and go thru some things in order for the advance multiplier to jump up allowing maximum advance.
By default the advance multiplier is at .7. Car won't see full advance until the advance multiplier jumps up to 1.0
John
Interesting. Next time we have a free hour I will re-dyno. I will make a few pulls, reset the ECU and make a few more and see what happens. If it drops I will re-dyno the next day andsee if it has come back up.
Boosted2.0 is offline   Reply With Quote
Old 07-14-2012, 09:51 AM   #46
Visconti
Drives: 05 STi
Anything ?
Visconti is offline   Reply With Quote
Old 07-15-2012, 10:23 AM   #47
Illusive
Drives: 2005 Subaru STi
Anything ?
Soon?
Our dyno has been booked up with customers cars as of late.
Our normal day's are 9:00 am to 10:00 PM 7 days a week. I'm the lucky one who gets two day's off from shop work. Boosted2.0 is too hardcore for rest So a free hour can actually be hard to come by around here.
Illusive is offline   Reply With Quote
The Following User Says Thank You to Illusive For This Useful Post:
ChrisOkc8 (07-15-2012)
Old 07-15-2012, 09:58 PM   #48
SnapOv3st3r
Drives: 400whp Scion tC
Originally Posted by WillRacer1jz View Post
I think they did a 400 meter run which is shorter than a 1/4mile by 18 feet. Shorter distance = faster time.
More like 8 feet (1312 vs 1320). DK is short and probably weighs around 130+/- lbs also.
SnapOv3st3r is offline   Reply With Quote
Old 07-16-2012, 04:16 PM   #49
Boosted2.0
Boosted2.0's Avatar
Originally Posted by Illusive View Post
Soon?
This.
Busy is a good thing though, so I'm not complaining
Old 08-27-2012, 05:26 PM   #50
Boosted2.0
Boosted2.0's Avatar
John
It has now been confirmed - the FR-S is defionitely running Toyota ignition strategy where you start at maximum advance and it is managed by 2 ignition trims.
Here is the relevant data:
I figure I'll just post up the plots and then discuss them afterwards.
Here is the extended testing (250 miles to 8500 miles with 2 oil changes) with an ECU reset for curiosity's sake tossed in.
Here's just the ECU reset before/after:
All runs in 5th gear, on the same dyno (ours) and the same car obviously.
Runfile 10 represents the best pull on a fresh motor with 250 miles on the odo.
Runfile 17 represents the best pull on a broken in motor with 2500 miles on the odo and a fresh oil change
Runfile 21 & 22 were done today back to back at 8500 miles with no changes but fresh oil from runfile 17. It represents additional power from break-in at the 8500 mile mark
Runfile 23 represents a fresh ECU reset pull with ideal conditions (cold coolant, warm oil)
Runfile 24,25,26 represent a hot motor and were done with zero cooldown between pulls.
The second plot is just to give a good example of what a fresh ECU reset can do to the power plot.
We previously argued that the ECU is more like a toyota ECU in that it runs max timing on reset and slowly pulls back timing as knock is detected. Other's had made the claim that it is more like a subaru ECU in that it runs a dynamic advance multiplier below max and slowly adds timing back in.
With this dyno testing we can confidently say that the ECU runs max timing on the ECU rest.
Furthermore we can give advice for those seeking to have parts installed on their vehicle, and or tuning.
Based on our extended testing, we recommend not having the vehicle tuned until at least 2500 miles on the odo (and hard driving after the first 500 break-in miles.)
We also recommend, prior to dyno testing/tuning, to reset the ecu get a baseline pull or 3, install parts, reset the ecu again and do the final after dyno.
Doing it in this way will eliminate any power gains from an ecu reset and show just what the parts will make.
Not doing it in this way enables others to potentially inflate their power claims.
Old 08-27-2012, 05:30 PM   #51
Visconti
Drives: 05 STi
Thanks for the update but this isn't correct.
After ecu reset the car does not run max advance..
The ignition logic is 100% what subarus have been using for over 10 years.
John
Old 08-27-2012, 05:51 PM   #52
2forme
why does a 190hp elise dyno the same as a 180 hp celica?
Old 08-27-2012, 06:56 PM   #53
xwd
John
Why do you suppose they saw gains after the reset? I kind of figured it was still using the Subaru ignition mappings.
Old 08-27-2012, 07:23 PM   #54
Genomaxter
Drives: 2013 firestorm FRS
Because they dont make 190 hp. That was a marketing gimmick. Its still only 180 crank. Its been dyno confirmed many times.
Genomaxter is offline   Reply With Quote
Old 08-27-2012, 07:36 PM   #55
2forme
Bastards!
Old 08-27-2012, 07:51 PM   #56
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I thought it was because the exhaust was different and the ecu had a slight tune difference. But I never looked at a dyno from it
clayrush is offline   Reply With Quote
BRZ on the dyno Symbiont BRZ Photos, Videos, Wallpapers, Gallery Forum 1 05-22-2012 01:17 PM
When will magazines start testing the performance? swift996 BRZ First-Gen (2012+) — General Topics 10 03-23-2012 02:10 PM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 08:55 AM
