#43 | |
Drives: 2013 DGM BRZ
I've easily driven 50+ manuals without a handbrake in the short time I've been driving. The fact is you cannot rely on every manual you get in having a fully operational handbrake and it's very easy to start on a hill without one. Anyone who thinks it isn't really just proves my point that they need to practice this. |
#44 | |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
http://www.autocar.co.uk/car-news/in...manual-gearbox anyways, i learned to drive on a manual more than 30 years ago and had my first AT last year with the BRZ. in my previous car (1978 datsun 280Z), the parking brake wasn't that good, so i used the heel/toe technique for starting on hills.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#45 | |
Yes, I am aware that is how it is taught and tested. However, considering how much people suck at driving MT, I wouldn't be surprised since the handbrake hill start is the easiest way to do it.
#46 | |
Drives: BRZ Pearl White
#47 |
#48 | |
Drives: Toyota GT86 Coupe Red (UK)
On topic.... In context of the OP, who is just learning to drive a manual. Regardless of who thinks what is "cool" and the "hip" and "Im a great skilled driver"... The handbrake is the easiest way to learn, the safest way to learn and considered in most places to be the correct way. So it should IMHO be the recommended method to that audience and it seems what the OP's current instructor has been teaching him. Which is good. As a learner I would also include short hill holds and slow, clutch slipping maneuvering on hills as good practice. Clutch wear is clutch wear. If you can't smell it burning yet, you will NOT wreck your clutch in an afternoon!
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
#49 |
No, learn to drive, like not having the back end loose on the streets.
Yes, are you saying the people that can do this can't do a handbrake start? lol.
#50 | |
Heavier flywheels in older cars probably helps. The best are diesels. I learnt to drive in a Renault Clio 1.5 diesel. All "maneuvers" were done with your right foot off the throttle completely. Even the "left hand reverse" maneuver uphill or 3 point turn on a hill. The thing just pushed back if you tried to stall it. You could stall it, but you really had to try hard. The instructor showed me a trick of putting the car into 5th and lifting the clutch very slowly, no throttle and have it slowly accelerate up to 30mph and sit there at 30mph with no throttle at idle. The down side was when you forgot to downshift while braking, suddenly at 1,000rpm it would start to push back against the brakes and you feel like you were accelerating again.
#51 | |
Praise Helix!
#52 | ||
I'd like to see a picture of the truck you claim couldn't use it's parking brake for a hill start. Quote:
From what I can tell you've got one foot on the clutch partially engaged and one foot on the gas to keep yourself stationary on a hill. Am I wrong? Sounds horrific for clutch wear if it is, I wouldn't let you touch my car with a ten foot pole, let alone give advice to others... |
#53 | |
Horrific for clutch wear? at 900rpm? on light load? What is your basis of this? That's fine, I don't need to touch your car nor have I ever had to change a clutch yet, even on the ones that I've kept for more than 10 years now. At the end of the day, it's a consumable item that protects your gearbox.
#54 |
Drives: swp brz limited
Hmmm I think you've been misinformed young man. No keys to my car either. Let me guess you redlined through the break in period too?
#55 |
Drives: 2013 Scion FR-S - Argento
1. I didn't read the entire thread or any of the others on how to drive a stick. I learned on a stick almost 30 yrs ago. It was a '63 Bug, we went to a parking lot and I stalled and made jumpy starts for an hour or more. The best thing Dad told me was something like, "gas and clutch should move in opposite directions".
2. I had the Bug for a few years, then got a 4 spd '73 2002, then a 5 spd Mazda truck, then went to an auto Xterra for 15 yrs. I was tired of the lack of interaction, so my FR-S had to be a stick. So out of the 5 cars I've had, 4 were manual but the 30 yrs or so was half on an auto (the Xterra is a great truck!). 3. I have only very rarely used the e-brake for hill starts. Just put it in neutral and stay on the brake, then when green, go! This includes driving the FR-S in the Bay Area on very steep hills last summer. I had a bigger issue seeing over the lip of the hill where I was going than getting the car underway It is really about feeling with your right hand and feet what the clutch and engine are doing. When the clutch starts to grab, the RPM want to drop because you are taking a moving part (engine) and mating it to a stationary part (wheels) by using the clutch and tranny. Feeling that drop and adding gas to compensate is what getting started is all about. It may require some slip of the clutch if the matching of engine rpm/wheel rotation isn't perfect. In my experience this slippage here and there is not going to ruin or seriously shorten the life of the clutch parts. (I've never had a clutch have to be replaced prematurely.) If you are learning, turn your tunes off, go slow, focus on what you hear and feel from the car. Once you have it down smoothly, it's easy! I agree with others who said if you want a stick, get the stick! Don't compromise on a vehicle because of a skill you don't have yet but can develop. |
#56 | |
Best of luck with your car.
| Teaching wife to drive stick? | Nm86 | Scion FR-S / Toyota 86 GT86 General Forum | 58 | 03-26-2014 11:41 AM |
| Stevens Creek Scion salesman can't drive stick | chas3wba0 | Northern California | 10 | 11-01-2013 06:51 PM |
| Fact: Girls find it hot when a guy knows how to drive stick? | shishand | Off-Topic Lounge [WARNING: NO POLITICS] | 86 | 10-20-2012 03:51 PM |
| To Drive a stick or cruise an Auto? | MrFRsLa | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 04-30-2012 07:50 PM |
| AutoGuide.com: Parents Push Teens To Drive Stick to Avoid Distracted Driving | poormans_LFA | Other Vehicles & General Automotive Discussions | 15 | 01-25-2012 10:02 AM |
