#43 |
Drives: 2013 BRZ Premium 6MT
havent had much in the way of rattles. one crazy one that happened twice. i think it was either the glovebox door or my ipod and the door together. i also have a random squeak/squeal that happens on the freeway. no idea where its coming from...may even be something outside the car.
2013 Subaru BRZ Premium 6MT -STOCK!
#44 |
Large Member
Drives: Toyota GT86 - Silver
I think you've all got it wrong, its not the car its the squeals and squeaks from amazed and shocked onlookers
Sent from my iPad |
#45 | |
Drives: '13 Subaru BRZ Limited WRB
#46 |
Drives: Forester 2007, BRZ Limited '13
Sorry, took me so long to answer - I pry it with hands, it comes off pretty easy. Don't use flat screw drivers - you'll leave markers.
I am busy. Do not disturb. http://youtu.be/I58ZSqwFlWw?hd=1
#47 |
Drives: DGM BRZ Limited, 05 Baja Turbo
I was getting a pretty bad rattle, seemingly from around the center console on rough roads between 35-50 mph. In frustration, I opened the glove compartment door, and noticed the rattle got quieter. Then I took out the glove compartment contents one by one. When I took out the padded binder containing all the manuals and paperwork, the rattle completely disappeared, but it reappeared immediately when I put the binder back in the glove compartment and shut the glove box. Looks like the weight of of the binder changes the way the glove box makes contact with its surrounding parts, just enough to make the car sound like a rattle trap. Without the padded service manual binder in the glove box, there is no rattling, even going over bumps.
#48 |
Drives: 2013 WRB BRZ Premium 6MT
It's been getting worse with every day, hopefully tomorrow I can take a look and try some of the tips.
#49 | |
Waited 5 years for this
Drives: '18 MX-5 Club
#50 |
Anyone notice a rattle on the shifter just below the collar? It's just behind the boot, and it seems to happen only at a higher rpm. It's really quite annoying.
#51 |
Drives: SWP BRZ Limited MT
For the last week or so I've heard a high-pitched squeak coming from the back of the car. Pretty annoying as it sounds like a smoke detector when the battery is running low!!!
Anyone else hearing something similar? |
#52 |
Is the noise a quick tick/click? Or is it more like squeak/beep(smoke detector) long? Does is sound different with the rear seats up vs down?
#53 |
Seρor Member
Drives: 2013 SSM DZE BRZ
I'm hearing an occasional squeak driving down the road. I'm not sure, but I think it may be coming from the front suspension. Is anyone else experiencing the same thing?
#54 |
Sounds like a squeak/beep (smoke detector). Haven't had the rear seats down so it's when they are up. To be honest it's really difficult to try and pinpoint exactly where the sound is coming from.
#55 |
I see. We probably have different noise then. Mine is more like tick/click noise.
#56 | |
Drives: 13' BRZ
Damn you dead silent previous dd mercedes for spoiling me! |
