Old 07-17-2014, 10:39 AM   #43
steve99
I agree with the both of you, just figured Shiv would know better than all of us is all. I would recommend running the stage 1 map as well, no point in risking detonation for a potential few hp difference.
I have seen the logs of a couple of guys that have hi-flow cats and stock headers.
On stage 1 map they tend to run a bit lean up top and knock if not on the best quality fuel as the hi flow cat tends to make them run a bit leaner than intended.
On stage 2 map which runs a bit richer higher rpm but also runs a bit more timing advance and that can run them into a bit of knock again.
The maps just don't cater for hi-flow main cats with stock headers , so you often need to tweek it a bit or run really good fuel. I don't think it anything dangereous I am just anal about knock.
Old 07-17-2014, 11:06 AM   #44
raven1231
understandably
Old 07-17-2014, 11:44 AM   #45
lucid215
from what he told me i can run the stage 2 el pump gas map since i have intake, over pipe, front pipe, and exhaust. i wont be running e85 until i get my uel headers in. thats why i gotta watch my logs to make sure everything is ok. let me find the link where he said it.
lucid215 is offline   Reply With Quote
Old 07-17-2014, 11:47 AM   #46
lucid215
heres the link. its the first comment he posted
http://www.ft86club.com/forums/showt...11#post1827011
Old 07-17-2014, 11:53 AM   #47
Malt
Drives: 2015 WRX
You do what you want, but shiv didn't explicitly say stage 2 is the map you should run. He said IF the car has a bunch of other exhaust mods that reduce enough restrictions then it MAY work better than stage 1.
I'd caution you to at least log to ensure you are not running into any dangerous AFR conditions/knock events. Shiv obviously knows best since these are his maps but this seems like a gigantic gray area where people need to be careful (much like running the stage 2 EL E85 maps with stock headers). Since you have the tools to log whenever you want, do yourself a favor and ensure that you are running safely even though you are outside the recommended mods for the map.
Malt is offline   Reply With Quote
Old 07-17-2014, 11:59 AM   #48
lucid215
and thats why i said i was gonna log after flashing to make sure everything is good im not gonna go flash the car then start beating on it haha i wanna make sure everything is right and parameters are set straight. hopefully i will be getting my ofh within the next couple weeks so i can run e85
Old 07-17-2014, 12:08 PM   #49
Malt
Drives: 2015 WRX
Actually, you'd probably be better off running a stage 2 EL E85 with your current setup than trying to run a stage 2 map sans header. At least that's been semi proven safe.
Old 07-17-2014, 12:36 PM   #50
steve99
If you still running that Takeda/AFE intake it might be best to scale MAF for that intake on petrol stage 1 tune, then see how it goes on stage 2 then try E85.
Dont try and scale MAF when your on E85 tune
see here
http://www.ft86club.com/forums/showthread.php?t=64790
Old 07-17-2014, 01:14 PM   #51
lucid215
ill be switching to a 3" signature intake soon as well so i wont be running the this intake for long. i guess i can run the stage 1 then bump it up to stage 2 and see how she runs
Old 07-18-2014, 12:08 PM   #52
Malt
Drives: 2015 WRX
Do you have any particular reason for wanting to run a 3" Intake? Beside the fact that running aftermarket intakes typically mess with MAF readings, which means you'll need to rescale your MAF if you want it to run correctly, most (if not all) aftermarket intakes provide little to no gains over a simple drop in filter.
Save yourself some money and hassle and just get a drop in and put your stock intake back on.
Old 07-18-2014, 12:26 PM   #53
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Originally Posted by Jyn View Post
3) For the DI seal issue, didn't Toyota release a TSB to fix that for earlier ('13) cars and '14s already have that update applied?
Thanks,
Jyn
3) Yes.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 07-18-2014, 12:49 PM   #54
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
One more question. I assume the device becomes locked to the car itself after syncing (otherwise several people could share one device). If someone wants to sell the OFT in the future, what's the process for decoupling or unregistering the system with the car?
Jyn is offline   Reply With Quote
Old 07-18-2014, 01:04 PM   #55
lucid215
all you gotta do is put your stock rom back on the ecu and it unmarries it and you can sell it.
the intake im getting made more power then the perrin intake. yes a drop in filter is just as good as a intake when the car is not tuned. tuning the car will get better results and will utilize the intake better.
Old 07-18-2014, 01:26 PM   #56
Malt
Drives: 2015 WRX
According to who? The manufacturer that is trying to sell you said intake?
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 06:29 PM
VISHNU OpenFlash Tablet: Add Up To 20HP With Improved Drivability Garrett@Openflash Engine, Exhaust, Bolt-Ons 7 01-24-2014 01:33 PM
***VISHNU OpenFlash Tablet IN STOCK*** Garrett@Openflash Engine, Exhaust, Bolt-Ons 15 12-17-2013 01:30 PM
FS: Vishnu OpenFlash Tablet - Unused, Mint Condition AyJay Engine, Exhaust, Bolt-Ons 6 11-09-2013 11:45 AM
