Old 06-03-2014, 09:53 AM   #43
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
Originally Posted by Sportsguy83 View Post
I have a good strap on you can use, and I'm local... LMK...
marcoaferrer is offline   Reply With Quote
The Following User Says Thank You to marcoaferrer For This Useful Post:
Sportsguy83 (06-03-2014)
Old 06-03-2014, 11:25 AM   #44
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
Originally Posted by Tye300 View Post
What typical whp levels and boost are people getting with the 2.87 and 3.125 pulleys on pump gas?
Someone should also do a DIY video on how to change pulleys.
i had to upgrade my injectors and fuel pump but im right at 300ish. after the tune is dialed in, we are expecting 315-320 on 93. at 7500 rpms we were seeing 12 psi on the 2.87.
its super ease to swap out. like they said changing out the belt is a pain. i left my charger on the car.
i loosened it up
then took off the bolts on the left side and slid out the belt
slid the new belt in
put the left side bolts back in
took off the bolts on the right side and did the same thing.
its just awkward taking off and putting on the charger by yourself so i did it in stages without fully taking it off.
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 06-05-2014, 10:28 AM   #45
marcoaferrer
Big thanks to @draggin_az for sending me the V2 upgrade instructions that Vortech provided him with. Main post has been updated.
The Following 3 Users Say Thank You to marcoaferrer For This Useful Post:
draggin_az (06-05-2014), kiichiro (07-21-2014), misooscar (06-05-2014)
Old 06-05-2014, 12:21 PM   #46
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Depends what ebcs or MBc settings u have. I see over 14psi without it at sea level, never tried to see or measure it at redline with our a boos controller attached, not that I don't want to but at moment can't afford to dive into the rebuild but it's planned, but more boost isn't the answer for more power, I have all the air delivery a built motor would need
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
The Following User Says Thank You to kiichiro For This Useful Post:
Tye300 (06-05-2014)
Old 06-05-2014, 12:22 PM   #47
kiichiro
Any install questions feel free to pm me too, I have venting the thing down to a science
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
Old 06-05-2014, 12:23 PM   #48
marcoaferrer
@kiichiro do you have any info or pics of your wastegated vortech setup that I could add to the main post?
Old 06-05-2014, 12:28 PM   #49
kiichiro
Pm sent
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
marcoaferrer (06-05-2014)
Old 06-06-2014, 11:39 AM   #50
marcoaferrer
fixed attachments from yesterdays post
Tye300 (06-06-2014)
Old 06-10-2014, 03:21 PM   #51
marcoaferrer
Added info on BPV upgrade. thx to @Tye300 for his write up, pics, and comparison videos
Tye300 (06-10-2014)
Old 06-10-2014, 03:56 PM   #52
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Glad to help bro!
Tye300 is offline   Reply With Quote
The Following User Says Thank You to Tye300 For This Useful Post:
marcoaferrer (06-10-2014)
Old 06-21-2014, 02:21 AM   #53
GT86_2014
Drives: Raven
2,62" the smallest 6-rib pulley Vortech has for V-2 and it can be used as guys from vortech confirmed, I just worry about belt slipping...
GT86_2014 is offline   Reply With Quote
Old 06-23-2014, 09:35 AM   #54
marcoaferrer
I think another problem with the 2.62 pulley is that it puts the impeller speed at 57,143rpm which spins the blower faster than its 55k cap. I dont think there is much if any power to be made with a 2.62 pulley over the 2.87. Hell I could be wrong, but the numbers seem to point to no.
Im working on a solution to bring the power output for a vortech kit over the 400whp mark and maybe even the 450whp mark but it requires some changes to the kit.
Old 06-23-2014, 02:44 PM   #55
Tye300
Tye300's Avatar
marcoaferrer (06-23-2014)
Old 06-23-2014, 02:46 PM   #56
marcoaferrer
@Tye300
Im getting the finances together so I can make the jump. Ive done the research if you couldnt already tell lol. Ill post more info once I start buying parts
draggin_az (06-24-2014)
New Vortech Maxflow Blow-Off Valve Upgrade for FT86 Supercharging Systems Brian@Vortech Forced Induction 168 08-08-2018 11:45 AM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 02:05 PM
Vortech Supercharging System Update - More boost, more POWER! Brian@Vortech Forced Induction 337 03-12-2016 03:42 PM
Vortech Supercharging Systems Now Legal On 2 Continents... Brian@Vortech Forced Induction 27 01-22-2014 01:33 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
