Old 04-21-2014, 08:47 AM   #43
wparsons
wparsons's Avatar
Originally Posted by Poodles View Post
Been done. People knock on the Camry, but the V6 model has always been a bit of a crazy sleeper. Got a beater one and it makes ricers cry
Plus. the Lotus Evora runs a Camry V6 (slightly tweaked with a supercharger, but it's still a Camry engine).
Not exactly. It's just cheaper to go single. It's been years since I've seen the car, but there was a rare twin setup for the MKIV Supra that make pretty crazy power and the torque band was pretty nice too. It's just a hell of a lot more work to get much the same goal (turbos aren't cheap, fitting all the piping, running all the lines, etc).
S4's make more power over a wider RPM range with a single turbo than twins. I would suspect other engines would be the same. It all comes down to efficiencies. Each turbo has friction, there's losses in piping, etc. The more you add the less efficient the whole system becomes.
flickr
Old 04-21-2014, 10:27 AM   #44
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
It does all come down to efficiencies. More specifically, compressor and turbine efficiencies. You can design a twin turbo setup that does anything a single turbo can do, and vice versa.
There are also losses in having headers that are routed in convoluted ways to get both sides of an engine hooked up to a single turbo. Intercooler piping isn't the only piping in a turbo car.
Sellout is offline   Reply With Quote
Old 06-15-2014, 09:35 PM   #45
Freshfrs86
Freshfrs86's Avatar
Drives: Scion FRS
So what shop is this kit from???
Freshfrs86 is offline   Reply With Quote
Old 06-15-2014, 09:48 PM   #46
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Thats what happens when people have more money than brains.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 06-15-2014, 09:50 PM   #47
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Good luck with that heat under the hood.
Old 06-15-2014, 10:09 PM   #48
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Originally Posted by Freshfrs86 View Post
Attachment 82155
That kit is from a local shop here in Phoenix cal FAT (Forced Air Tech). I saw it yesterday in person. It should do fairly well from what I saw.
Edit: this is @fst86frs car
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
The Following User Says Thank You to evo4g63 For This Useful Post:
Freshfrs86 (06-15-2014)
Old 06-15-2014, 10:12 PM   #49
Freshfrs86
Freshfrs86's Avatar
Drives: Scion FRS
@evo4g63 do you know what turbos are being used?
Old 06-15-2014, 10:18 PM   #50
evo4g63
evo4g63's Avatar
I actually do but I will let him chime in on this as it's a member on this forums build.
-2016 Subaru WRX
Old 06-15-2014, 10:25 PM   #51
sw20kosh
Drives: 2013 Black FR-S
It looks damn bad ass but you could generate the same performance from 1 turbo and 1 intercooler etc...
Twin is only necessary if there are space/routing constraints preventing a single turbo setup.
Gotta hand it to him for the craftsmanship and uniqueness!
Old 06-15-2014, 10:35 PM   #52
Reaper
Reaper's Avatar
Drives: violent
Id like to see the results. Everything I know about building turbo cars tells me this is a complete waste. But then again i never thought id be daily driving a 12.5:1 compression 450whp 2.0liter.
The Following 2 Users Say Thank You to Reaper For This Useful Post:
evo4g63 (06-15-2014), Freshfrs86 (06-16-2014)
Old 06-15-2014, 10:48 PM   #53
1086
1086's Avatar
Drives: UM86 - 6MT
https://www.facebook.com/pages/Toxic...13370045394907
https://www.facebook.com/photo.php?f...2247305&type=1
1086 is offline   Reply With Quote
Old 06-15-2014, 11:03 PM   #54
diss7
Drives: AE86, 2x GT86, TE27
So many haters.
I guess its the usual "the majority of the forum doesnt like it, so I better not like it too"
A boxer is a prime candidate for a twin turbo setup. Thats why Subaru did it on some EJ's.
We even looked at it here (we as in myself, a couple of race team level mechanics, a fabricator, a tuner) Basically our idea was have a small frame turbo behind the cross member (like ptuning) but one either side. (Each 'bank' would feed its own turbo. The passenger side bank (drivers on LHD) would have its own maniflod/overpipe, rather than having to go around the oppostie side like OEM)
Have them both come up to w2a intercooler and new rear fed intake manifold.
But there was ALOT of fucking around with it. So I just got a JDL kit instead.
With all that said, I don't like the kit posted above at all.
diss7 is offline   Reply With Quote
The Following 2 Users Say Thank You to diss7 For This Useful Post:
Fear (06-16-2014), Freshfrs86 (06-16-2014)
Old 06-16-2014, 11:33 AM   #55
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
When the heat from one turbo isn't enough.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
cdrazic93 (06-16-2014), nelsmar (06-17-2014)
Old 06-16-2014, 02:39 PM   #56
fst86frs
fst86frs's Avatar
Drives: FAT H8R Hot Lava FRS
To chime in the heat is actually not to bad, to each they're own opinion why not try something different, decided to be different and works well, could gone the simple way like all the others and slapped my 30r on and called it a day but chose to push the norm and innovate a twin setup on the car and feels great and will be coated once fully completed
fst86frs is offline   Reply With Quote
The Following 2 Users Say Thank You to fst86frs For This Useful Post:
alexand3r (06-19-2014), Freshfrs86 (06-17-2014)
Twin Turbo FR-S/BRZ? KidWonder Scion FR-S / Toyota 86 GT86 General Forum 44 06-27-2014 02:22 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 03:36 PM
Twin Turbo BRZ xn7485 BRZ Photos, Videos, Wallpapers, Gallery Forum 10 08-23-2013 08:13 PM
Dealership twin turbo brz... BRZ283 BRZ First-Gen (2012+) — General Topics 23 06-03-2013 11:59 AM
Twin Turbo kit? enjoi23 Forced Induction 15 12-03-2012 08:53 PM
