#43 |
Drives: Hydra EMS Powered FRS Raven Black
#44 |
So far I am not happy with what I'm seeing in terms of oil pressure.
Any engineers available to chime in on this pump gear design? ![]() From what I'm seeing this oil pump was designed for efficiency/fuel economy as it doesn't jump right to the pressure relief like the EJ oil pumps do. This pump is RPM based and it slowly ramps up the oil pressure with RPM. Now when my engine is cold I will see 120+ psi and then when warm it will cruise in the 60 psi range and get up to about 80 psi. Once the oil is hot it's around 40 psi under cruise and by redline it's about 65 psi. I took pressure readings in two spots and I'm seeing about a -10 psi difference between the main oil pump outlet (where OEM pressure switch is) vs. the oil feed galley plug at the crank/rod feed. The pressure at the crank feed is what really matters! ![]() I wanted to test the pressure drop with the OEM water based oil cooler in place but I can't tell you if the pressure difference of 10 psi is due to the oil cooler or just the location but to be safe I took the oil cooler off for now. If the cooler keeps oil temps much lower well the 10 psi pressure drop may actually be insignificant and pressure may actually be higher with it in place. I'll let someone else test that. I need to get business done and the prep our STi for Formula D/Global Time Attack this week in Atlanta so I don't have time to research this but if someone is willing, please look up the part numbers for the FA20 oil pump vs. the FA20T oil pump. I'm hoping Subaru uses a "normal" oil pump gear for higher pressure on the FA20T motor. A simple pump gear swap may solve this problem. Here is the bottom line, 65 psi will never allow the rod bearings to survive on a 450+ HP FA20 motor. These pressures are recorded at street temps and not under racing conditions. Frankly knowing what I do on our EJ motor race program bearing skimming occurs in the 60s and failure in the 50s almost instantly. With an NA motor or even a supercharged setup under 300 whp, I don't think the OEM pressures are something to worry about. The reason is that the power delivery is linear in both cases and therefore the linear nature of how this oil pump works I don't see it being a deal breaker. Now a turbocharged setup hits peak torque much earlier in the RPM range and so peak oil pressure is needed much sooner (you can't wait until redline to see 65+ psi). Is anyone else recording their oil pressures and if so what are you seeing under various conditions? Thanks, Phil Grabow |
#45 |
CHECK ENGINE
Drives: 2004 STi
The FA20DIT oil pump on the new WRXuses 14mm rotors instead, maybe that will help enough with oiling? I don't know many more details about it at this time other than the size
i don't cry about crickets
#46 | |
The gear while it may fit in the existing timing chain front cover it would protrude out of the housing so either the entire front timing chain cover is different or the back of the oil pump cover and gears only are different. |
#47 |
CHECK ENGINE
Drives: 2004 STi
Technically the oil pump is "not serviceable" so its only sold as a unit, but once I'm back from lunch I'll get the chain cover asst part number from the parts guys
#48 |
#49 |
CHECK ENGINE
Drives: 2004 STi
13108AA140 is the PN for the dit chain cover asst with the larger oil pump
#50 |
Also I don't know how readily available they are but the JDM RA EJ motors came with a 12mm oil pump that used a standard gear profile. It's possible if we can source one we can test fit that into this pump housing.
#51 |
Drives: Scion FRS Firestorm
This thread has so much valuable information about our engines and oil. Love it. Keep it up!
#52 | |
We still really need a dry sump but I may test this pump and one more device before going to a dry sump. I'm hoping ARE will design the oil pan before I have to
#53 |
Motorsports
Drives: 19BRZ PP, 16 M4
@Element Tuning have you been able to confirm the DIT pump is larger and fits?
Douglas W.
#54 |
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Tell us more
SOLD THEM BOTH
Hers: 2007 987S Mine: 2012 991S That was fun, thanks Hachi ![]() |
#55 | |
#56 | |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
You guys should try Miller's Nanodrive racing oil, I think it's a perfect match for this car. It is more durable (tested to last at least 1600 race miles on one fill) and offers better friction reduction and bearing protection than other race oils. The FA20 responds very well to it and so do other dedicated race engines. I've been using it for a while now on and off track. Great stuff.
| FA20 Engine component photos | Crawford | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 89 | 02-22-2016 02:31 AM |
| FA20 Engine component photos | Crawford | Engine, Exhaust, Transmission | 46 | 01-26-2015 05:19 AM |
| Engine Hardware, Gaskets, & Bearings Oh My; All on sale at FR Sport. | FRSport.com | Engine, Exhaust, Bolt-Ons | 0 | 01-10-2014 12:33 PM |
| FA20 Le Mans Race Engine | SilverSkyline210 | Engine, Exhaust, Transmission | 11 | 11-17-2013 11:24 PM |
