Old 04-09-2014, 10:53 AM   #43
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Originally Posted by Dooley View Post
You can have a single out RCA on a sub. You can also choose to split a L/R because it is already done internally.
Essentially, there is 2 RCA inside the single out. Everything is the exact same, just less external wiring.
So if your sub's wiring has 2 RCA plugs, would you just buy a Y adapter?
Prog is offline   Reply With Quote
Old 04-09-2014, 02:11 PM   #44
Dooley
Drives: Asphalt
Correct.
Dooley is offline   Reply With Quote
Old 04-09-2014, 06:17 PM   #45
Prog
Prog's Avatar
Holy balls, $59 shipping to the U.S...
Old 04-09-2014, 07:28 PM   #46
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Originally Posted by DC2R View Post
Shouldn't subwoofer be two RCA?
Sent from my SM-N900T using Tapatalk
Not on a home A/V receiver system, pre-amp out is just one RCA out, not sure if it's different for car audio.
Deathalo is offline   Reply With Quote
Old 04-09-2014, 08:21 PM   #47
DC2R
Drives: 2014 Scion FR-S
Every head unit I ever had had a left and right for sub
DC2R is offline   Reply With Quote
Old 04-09-2014, 08:33 PM   #48
xjohnx
Grip>Slip
xjohnx's Avatar
do you know if they have an iphone/ipod cable with the lightning adapter?
Old 04-09-2014, 08:36 PM   #49
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Same here but I don't think it's necessary to have left and right channels though, I believe sub's (left and right) are always "mono" aka left isn't hitting while right is not, they always go together/ simultaneously. Someone correct me if I'm wrong.
Old 04-09-2014, 10:15 PM   #50
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
it has a standard ipod connector - not the new style lightning connector
Andrew
2013 Scion FR-S MT (Silver)
2011 Toyota Rav4 Sport V6 4wd (Silver)
SHIFTER is offline   Reply With Quote
Old 04-09-2014, 10:16 PM   #51
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
The price strikes me when comparing to appradio. I know they are two different things. Probably the closest would be parrot head unit which I believe runs gingerbread. I think the nexus installs tend to get pricey with proper mounts and amps/wiring too. I will try to check this out in person at local meet.
Can't recall if this was covered but does this handle incoming calls over Bluetooth as well as stock head unit?
indeed - its a good price for what it is comparatively speaking. sure a n7 is cheaper - but as you said the sum of all parts gets damn close to this complete bolt in unit
Andrew
Old 04-09-2014, 10:18 PM   #52
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
Originally Posted by Namuna View Post
You quoted my post, but it seems you didn't actually read it. Particularly the part where I said I get it, that the Ca-Fi is a "package" and not just a tablet to be compared directly with the N7.
My perspective, to put it another way is that 'the whole doesn't equal the sum of the parts' here. The 'whole' being the $533 pricetag and the 'parts' being the Ca-Fi package of tablet/amp/tuner/etc...
My main point of contention is the fact of how inexpensive a powerhouse like the N7 is (and that's even at full retail cost, not even considering how much less expensive it would be for similar specs direct to a manufacturer like Ca-Fi would be) as compared to the specs of the component part of the Ca-Fi "package" that is the tablet.
So, to reiterate and in my opinion and my perception of fair market value...$533 seems high for the overall package, when taking into consideration that one of the main components (the tablet) has sub-par specs.
...To be fair, I don't know what all costs are involved for Ca-Fi to put such a package together, what with all the components involved (amp, tuner, tablet, etc...) and licensing and such and I don't even know of any competing product to compare costs to. I'm going by my 'gut' feelings and my own threshold of what I'm willing to pay for such an item.
It is definitely to each his own.
I agree with you to a certain extent - but with I factor in my time to customize something to fit - and at that point this is significantly cheaper.
That said - a tablet install IS cool as hell when done right, and is great for the person that likes that sort of stuff. This is great for the person that likes a drop in easy to install stereo - that has all of the same (and arguably more) features.
I did read through your post a bit quick, so i apologize if i missed part of the message. No harm meant by it! Like i said before, I dont mean to bash those that want to go that route!
Andrew
Old 04-09-2014, 10:36 PM   #53
xjohnx
Grip>Slip
xjohnx's Avatar
i'm ordering one of these. it better not suck.
i opted for the cellular modem and BT OBD reader when i ordered. mainly because if at a later point i decided i wanted to add either shipping would be another $59. Hopefully I can get it to tether reliably on my iPhone though so I won't need the modem.
Old 04-09-2014, 10:36 PM   #54
DC2R
I have had my hand in trigger for appradio 2/3 since I had my gs-r. For full mirroring to work with a Note 3 running kitkat it seems like a full time job to keep it running daily. The ease of install is tempting here. I know if I order appradio from crutchfield I get many added products for free to make sure everything fits. Also 60 day money back guarantee for $450. Are any added cables needed for 2014 FR-S with bespoke radio? I'm assuming there is no support if it doesn't work correct?
Old 04-10-2014, 01:40 AM   #55
eliminist
Is this a resistive or capacitive screen?
eliminist is offline   Reply With Quote
Old 04-10-2014, 05:41 AM   #56
Scavanger
Avid searcher of things
Scavanger's Avatar
Drives: Scion Fr-s 10 series
Capacitive, so multi touch capable
Scavanger is offline   Reply With Quote
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
