Old 04-23-2014, 03:49 PM   #43
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Here you go guys, for B00C and B01C:
Code:
RAM_EngineSpeed                FFF893F8
RAM_EngineSpeed_0              FFF8DB98
RaM_LTFT                       FFF8DB90
Ram_AFR_Sensor_Heating_Limit_Result             FFF88478
Ram_AF_Correction_3_32bit_ECU                   FFF8A900
Ram_AF_Learning3_Percentage                     FFF8DC10
Ram_AF_Learning_3                               FFF81640
Ram_AF_Sensor_1_Current                         FFF8932C
Ram_AF_Sensor_1_Resistance                      FFF89344
Ram_Accelerator_Pedal_Angle                     FFF89230
Ram_Alternator_Duty                             FFF884A4
Ram_Atmospheric_Pressure_1                      FFF89B94
Ram_Base_Pulse_Width                            FFF89744
Ram_Battery_Voltage                             FFF87C6C
Ram_CFP_Delta                                   FFF89048
Ram_CPC_Valve_Duty_Ratio                        FFF89CD0
Ram_CPC_Valve_Duty_Ratio_1                      FFF8DC14
Ram_Calculated_Base_Pulse_Width_                FFF8A058
Ram_CoolantTemperature                          FFF890A4
Ram_Coolant_Temperature???                      FFF87C74
Ram_Defogger_Switch                             FFF8939F
Ram_ECU_volt                                    FFF8DBD8
Ram_Engine_Speed                                FFF89570
Ram_Exhaust_VVT_Retard_Angle_Left_              FFF8C148
Ram_Exhaust_VVT_Retard_Angle_Right_             FFF8C144
Ram_Fuel_Injector_1_Pulse_Width                 FFF887D8
Ram_Fuel_Injector_1_Pulse_Width_4byteExt_E60??? FFF887F0
Ram_Fuel_Injector_2_Pulse_Width                 FFF887DC
Ram_Fuel_Pressure_MPa                           FFF89378
Ram_Fuel_Pump_Duty                              FFF8B1B4
Ram_Fuel_Pump_Duty_0                            FFF8BD38
Ram_Gear?                                       FFF89395
Ram_Idle_Switch                                 FFF8B5C6
Ram_Ignition_Total_Timing                       FFF8AE0C
Ram_Ignition_Total_Timing_0                     FFF8DBA0
Ram_Intake_Air_Temperature                      FFF87C64
Ram_Intake_Air_Temperature_0                    FFF8DBA4
Ram_Intake_OCV_Current_Left                     FFF891B8
Ram_Intake_OCV_Current_Right                    FFF891AC
Ram_Intake_OCV_Duty_Left                        FFF8C20C
Ram_Intake_Temp                                 FFF890B8
Ram_Intake_VVT_Advance_Angle_Left               FFF8C100
Ram_Intake_VVT_Advance_Angle_Right_             FFF8C0FC
Ram_Load                                        FFF8DB84
Ram_MAF_Voltage                                 FFF87CB4
Ram_Map                                         FFF8DB94
Ram_Map_Delta?                                  FFF8A234
Ram_Mass_Airflow                                FFF89118
Ram_Mass_Airflow_0                              FFF8DBA8
Ram_O2_curr                                     FFF8DBD0
Ram_O2_voltage                                  FFF8DBC0
Ram_Rear_O2_Sensor                              FFF8DBB0
Ram_Roughness_Monitor_Cylinder_1                FFF8CEDD
Ram_Roughness_Monitor_Cylinder_2                FFF8CEDE
Ram_Roughness_Monitor_Cylinder_3                FFF8CEDF
Ram_Roughness_Monitor_Cylinder_4                FFF8CEE0
Ram_SI_Drive_Mode_I3_S1_SSharp2_                FFF88999
Ram_STFT                                        FFF8DB8C
Ram_Throttle_Opening_Angle                      FFF8DBAC
Ram_Vehicle_Speed                               FFF8DB9C
Ram_Vehicle_Speed_0                             FFF893D0
Ram_abs_load                                    FFF8DBDC
Ram_amb_press                                   FFF8DBCC
Ram_cat_temp                                    FFF8DBD4
Ram_coolant_temp                                FFF8DB88
Ram_fuel_level                                  FFF8DBC8
Ram_fuel_pressure                               FFF8DBB8
Ram_lambda                                      FFF8DBBC
E_AF_Correction_1_4byteExt_E81                      FFF8A5EC
E_AF_Learning_1_4byteExt_E48                        FFF8A774
E_AF_Sensor_1_4byteExt_E91                          FFF89330
E_CLOL_FuelingExt_E33                               FFF8DC26
E_Closed_Loop_Fueling_Target_4byteExt_E121          FFF8A6D0
E_Engine_Load_4ByteExt_E32                          FFF8914C
E_Engine_Speed_Delta_E157                           FFF89408
E_Feedback_Knock_Correction_4byteExt_E39            FFF8B0C4
E_Final_Fueling_Base_4byteExt_E123                  FFF8A01C
E_Fine_Learning_Knock_Correction_4byteExt_E41       FFF8B160
E_Fuel_Injector_1_Latency_4byteExt_E50              FFF8A05C
E_Fuel_Injector_1_Pulse_Width_4byteExt_E60          FFF887C8
E_IAM_4byteExt_E31                                  FFF816F0
E_Idle_Speed_Map_SelectionExt_E49                   FFF8B748
E_Ignition_Base_TimingExt_E53                       FFF8AE88
E_Knock_Correction_Advance_4byteExt_E43             FFF8B0C0
E_Knock_Correction_Advance_IAM_onlyExt_E40          FFF8B134
E_Knock_Correction_Advance_Max_PrimaryExt_E118      FFF8B12C
E_Manifold_Relative_Pressure_4byteExt_E113          FFF88F78
E_Manifold_Relative_Sea_Level_Pressure_4byteExt_E52 FFF88F74
E_Primary_Open_Loop_Map_Enrichment_4byteExt_E84     FFF8A988
E_Requested_TorqueExt_E56                           FFF8B4A4
E_Target_Throttle_Plate_PositionExt_E57             FFF8B58C
E_Throttle_Plate_Opening_Angle_4byteExt_E38         FFF89030
E_Tipin_ThrottleExt_E54                             FFF89038
Td-d is offline   Reply With Quote
The Following 4 Users Say Thank You to Td-d For This Useful Post:
illmatic (04-23-2014), jprice130 (04-23-2014), ML (04-23-2014), steve99 (04-23-2014)
Old 04-23-2014, 05:48 PM   #44
steve99
Originally Posted by ML View Post
I agree these people are whats driving the community and making it awesome! I meant can he add the information that you need the A01C Rom to log properly to the original post
I'll make some notes in the original post and post up the new RAM addresses that Td-d provided.
If you guys on B01C or B00C roms can test them out by substituting in the new ram addresses (scaling is hopefully the same) then post up a B series logcfg.txt I will add that to post as well
Thanks
ML (04-23-2014)
Old 04-23-2014, 07:43 PM   #45
ML
ML's Avatar
Drives: 13 White MT FR-S
Thanks
Try this one.
The Following User Says Thank You to ML For This Useful Post:
Old 04-23-2014, 09:40 PM   #46
steve99
Try this one.
Thabks , have added your BO1C logcfg.txt to original post
Old 04-23-2014, 09:43 PM   #47
ML
ML's Avatar
I havn't got to test it yet, but I updated all the hex addresses.
Old 04-24-2014, 12:11 AM   #48
steve99
Ok thanks, let us know when you do
ML (04-24-2014)
Old 04-25-2014, 08:39 AM   #49
Td-d
Steve, also - people must use this 32bitbase.xml for Ecuflash - the most up to date, if you could edit the OP:
https://raw.githubusercontent.com/TD.../32BITBASE.xml
Old 04-25-2014, 04:48 PM   #50
reardrv
Drives: 2013 Subaru BRZ
Ok so I had previously flashed my car successfully with the OFT stage 1 ROM. This morning I installed the OFT headers and went to flash their stage 2 ROM, but everytime I try to read or write this happens:
[16:36:31.871] using metadata XML ID read_subarush72531brz from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_subarush72531brz.xml
[16:36:31.885] J2534 API Version: 04.04
[16:36:31.885] J2534 DLL Version: 1.01.4035 Dec 16 2013 23:12:40
[16:36:31.885] Device Firmware Version: 1.14.4010
[16:36:31.885] Device Serial Number: TAn8SKIw
[16:36:37.608] reading vehicle info...
[16:36:37.617] CALID : ZA1JA01C
[16:36:37.619] CVN : 8349A8FB
[16:36:37.624] VIN : JF1ZCAB17D1611837
[16:36:37.624] starting programming session...
[16:36:37.626] turning off DTCs...
[16:36:37.964] turning off unnecessary communications...
[16:36:38.066] unlocking ECU...
[16:36:38.066] Requesting Seed...
[16:36:38.069] interface close
[16:36:38.081] interface close
Anybody have any ideas?
reardrv is offline   Reply With Quote
Old 04-25-2014, 05:31 PM   #51
steve99
Thanks has been updated
Old 04-25-2014, 05:36 PM   #52
steve99
Check you connection to obd port use the rubber band trick or use an obd extension. Check if the tactrix will log data that will check connection. I got similar issues when I had bad connections
Just updated 32bitbase file link in original post see Td-d post above.
Old 04-25-2014, 06:33 PM   #53
reardrv
Just tried a new USB cord and tried holding the tactrix firmly in place, still nothing. I can't get OBD logging to work on Rom Raider, but I'm not sure if I'm doing it right.
Old 04-25-2014, 06:59 PM   #54
vgi
Drives: frs
The OBD logging on RomRaider works only on special tactrix beta version, don't know what you have but it might be ok you can't log via RR.
As tou your problem, I would also suggest rebooting your laptop and/or trying a different usb port. Also make sure you've waited after initial bips at least 5 seconds.
vgi is offline   Reply With Quote
The Following User Says Thank You to vgi For This Useful Post:
reardrv (04-25-2014)
Old 04-25-2014, 07:07 PM   #55
reardrv
So apparently I wasn't waiting for the beeps, lol. Good to go now, thank you!
Old 04-25-2014, 09:00 PM   #56
steve99
I've never heard any beeps out of car or tactrix maybe its different on USA cars , always wait 15 sec (as it says in guide in original post) after you turn ignition on before you click ok on read/write dialog box.
I was talking about logging to Tactrix SD card using logcfg.txt files :-)
good to hear its all sorted.
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
