Old 04-01-2014, 11:02 PM   #43
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Thanks Just to clarify, the log I posted above was from the standard OTS v1.55 tune....not the altered 98RON tune as I haven't loaded yours yet.
Anyhow, I gather that my engine is seeing some knock hence the drop in IAM yes? How much knock is the engine actually seeing, and are the "corrections" the ECU is making pulling more timing than necessary (as you mentioned in your first post)? Basically is this what's happening in my case as well?
Fizz is offline   Reply With Quote
Old 04-01-2014, 11:12 PM   #44
steve99
Arrrrhhhh
That makes more sense it looked pretty bad if you had already loaded my ROM
Yes I found if you pull about half or sometimes less than half of what the ecu pulls (knock correction value) it will generally correct the knock in that area.
Once you IAM has dropped it takes timing from entire rpm/load range.
Your fuel trim LTFT does seem high, do you have intake/exhaust mods mods ??
Old 04-01-2014, 11:16 PM   #45
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Only a drop-in filter, and a motiv front pipe with hfc.
Old 04-01-2014, 11:29 PM   #46
steve99
You could ask shiv about running the EL header stage 2 tune, its for catless headers but it appears hfc (secondary cat) has similar effect ,but check with shiv.
Old 04-02-2014, 10:05 PM   #47
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I've sent @shiv@vishnu a couple of logs via PM asking for advice....waiting for this reply on best course of action. Anyway I took another (long) data log this morning and the IAM is even worse...dropping as low as 0.5! http://datazap.me/u/fizz/data-loggin...log=0&data=1-9
Old 04-02-2014, 10:17 PM   #48
steve99
If you load my map for 98rON should sort the IAM drop out, you also get high RPM knock as well on 98 with "standard" map
Old 04-02-2014, 10:28 PM   #49
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I've saved your map....but haven't uploaded it to my car yet. Waiting for Shiv to respond first. By the way...when you said "standard map" you're referring to the standard canned v1.5x map yes?
I can't believe the 98 RON we get is so piss poor? I thought Shiv's v1.5x maps were all tuned for 91AKI, so anyone running 93AKI (or comparable) should not see as much knock.....but obviously not?
Old 04-02-2014, 10:52 PM   #50
steve99
Yes "standard map is shiv's 1.5 tune. Their fuel is different and rated via a different method, I run 100RON all the time now.
Their 93aki fuel seems significantly better than our 98, I appears it even a bit better than out 100ron
This is your log expanded around a 3000 - 5000 rpm pull.
http://datazap.me/u/fizz/data-loggin...om=14392-14570
Your IAM is down to 0.6 which is already pulling 40% of timing from the Advance max A table values. But your KC Learned is still dropping very significantly pulling more timing due knock.
compare to this
http://datazap.me/u/steve99/100-ron-...zoom=2051-2248
IAM is one and no significant drops in KCA(KC Learned) which is knock correction timing advance I'm running 6 degrees at 5000 rpm your only running 1.7 degrees due knock retardation.
Old 04-03-2014, 12:08 AM   #51
Nardi330
Nardi330's Avatar
Drives: 86
@Fizz, how do you drive your car usually?
I usually do short trips and by the time the car is warmed up I would have arrived. While the car is warming up, i usually keep the rev under 3000rpm which is the rev range where knock happens frequently.
when i started logging my car after flashing OFT, my IAM was 0.29!!! I have now changed my driving habits a bit and will drive a bit further than previously after the car is warmed and do some pulls over 4000rpm to clear the knocking range.
after a few weeks, my IAM now is mostly at 1.
Nardi330 is offline   Reply With Quote
Old 04-03-2014, 12:17 AM   #52
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
My daily commute is basically your average metro area driving, but not much start-stop traffic. Takes about 25mins to get to work, and being rush hour there's hardly any opportunity to rev past 4000 rpm. So mostly around 2000 to 3000+ rpm which, as you've mentioned, is where knock happens.
Old 04-03-2014, 12:23 AM   #53
Nardi330
Nardi330's Avatar
Drives: 86
maybe drive in a lower gear occasionally just to let the engine revs pass 3000rpm?
Old 04-03-2014, 12:30 AM   #54
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
compare to this
So I gather that my tune isn't producing much performance over the stock map due to all the knock I'm getting....but what about potential damage? Since flashing Shiv's tune I've driven the car hard (i.e. redlined) a number of times, and with all the knock that has been going on, do you think there's any damage done? Or would the ECU have pulled quickly enough to counter this?
Old 04-03-2014, 01:49 AM   #55
steve99
It will certainly be losing performance how much is debatable. The best option is to run better fuel.
Second best is to pull some timing to stop the knock, the ECU is very aggressive when it pulls timing due knock, if you pull timing from the map yourself you generally only need to pull half as much.
As for engine damage well that's probably unlikely (I am no expert on knock damage to engines though). The stock tune knock's on 98 as well seen iam drop to .6 or so on stock tune on my car and others. The ECU is pretty efficient at managing knock but it does so at the expense of performance. I just don't like to see that level of knock on a long term basis.
The overall ignition advance is a couple of degrees higher than stock on the vishnu tunes over about 4500.
Old 04-03-2014, 11:02 AM   #56
akyp
Drives: 2012 86
Thank you @steve99. Just flashed the 98 RON maps on page 1 and went for a drive: http://www.datazap.me/u/akyp/2014040...om=13406-13893
Still seeing some KC at 3000rpm though AM stays at 1.0. Should I pull more timing or is it within acceptable range?
akyp is offline   Reply With Quote
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 08:19 PM
Fuel gauge misreading actual fuel in tank. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 19 10-09-2013 03:39 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
