#43 |
Drives: BR86
OK, engine failure caused rear to lockup & spin the car. I reckon the dealer doing the work appear to be somewhat incompetent & unwilling to help you :/ Perhaps you can contact the Tech Div @ TSA directly & speak to them ? Perhaps go to another dealer? You need to be diplomatic with them to get action & results. Toyota usually come to the party.
#44 |
Turbo 86
Drives: Toyota 86 Turbo
I had an srange experience this week. I had a P0351 error on Morning.. did a OBD scan and seen the Coilpack.. so light was on....car still driving good. .. so on Theusday driving in a strait line... my traction contol kicked in, but no spin.. still driving with the enigine error Theusday afternoon during driving the error went of. . did a new OBD scan no error....so what the helll. . is our cars cursed.
#45 | |
| The Following 2 Users Say Thank You to sshole For This Useful Post: | Fast_Freddy (09-09-2014), Jacques Blom (07-13-2014) |
#46 | |
Drives: Toyota 86 Pearl White
Had another forum member from SA contact me in May this year, his traction light also started blinking while in a straight line before the wheels locked up and he ended up having a serious accident. Didnt seem like a mechanical failure but just software. Btw, my second engine blew after 5000 kms. No harsh driving at all. Car is with Toyota for the last 7 weeks and a third engine has been fitted. They have no idea what caused it. I am expecting more early spec cars to start having problems as the mileage/wear and tear gets closer to the levels I was at. |
#47 | |
Drives: 2013 FRS / 2013 427 Vert
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#48 | |
Drives: WRB BRZ Series.Blue
#49 |
Turbo 86
Just recieved my IP coil pack... Hope this fix my errors on coil pack.. Yesterday had a quick pull and slight drift. This time traction and ABS kicked in and stayed on... Could not switch traction on or off... Needed to stop dead swithc off and then on again... Will keep you posted on the IP Coil pack upgrade.
| Code P0351 Trouble shooting? | Bahraini86 | Issues | Warranty | Recalls / TSB | 46 | 09-10-2017 05:07 PM |
| Major engine Failures - one year overview | regal | Issues | Warranty | Recalls / TSB | 51 | 08-31-2016 09:16 AM |
| Crawford posts of engine failure example at 218hp | OICU812 | Engine, Exhaust, Transmission | 95 | 03-27-2015 06:40 PM |
| Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) | R2RO | Issues | Warranty | Recalls / TSB | 3 | 02-04-2013 11:06 PM |
| ECU & Slip light p0015 ~ p0019 error | v3rgil | AFRICA | 48 | 11-09-2012 05:09 PM |
