Old 02-17-2014, 01:27 AM   #43
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Originally Posted by krulux View Post
And if e85 is an option your increase will net 20-30HP, more depending on your mods/bolt-ons. I've flopped back and forth between 93oct and e85 a few times now.. and not once has there been an issue... just smooth reliable powwah!!! (other than the fact we've only got 1 e85 station near my home )
Can you give a brief process on how you go on about doing this?
How often/tank almost empty/when to switch ecu?
I'm waiting on my headers. Once I get them put on I'll be trying e85
Carlitoz3 is offline   Reply With Quote
Old 02-17-2014, 02:27 AM   #44
DC2R
Drives: 2014 Scion FR-S
Originally Posted by stevo585 View Post
Yeah expect low 20's that's what I've been getting. Its really obvious the gas gauge is dropping faster lol.
E85?
Sent from my SM-N900T using Tapatalk
DC2R is offline   Reply With Quote
Old 02-17-2014, 03:14 AM   #45
steve99
You can run E85 on a "stock" car ie no headers by using the E85 stage 2 tune for EL or UEL headers there is a thread here on this.
see thread
http://www.ft86club.com/forums/showthread.php?t=56452
Just run your tank down till low fuel light on, fill with E85 . Drive moderately
Use the Diag mode of OFT to monitor fuel trims once you see the fuel trims rise (will only take a kM or two) petrol now out of system pull over and flash E85 tune. Drive moderately untill fuel trims stabalise below 10% (mabe 5-10km) and your done.
I have also just pulled over in the station car park and idled for a couple of minutes then flashed and drive moderately (no wide open throttle) till fuel trims stabilize on new fuel might take 10km or so.
Repeat going back the other way just monitor fuel trims and don't drive hard till STFT and LTFT stabilize below 10%
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Carlitoz3 (02-17-2014), Shiv@Openflash (02-17-2014)
Old 02-17-2014, 03:23 AM   #46
Sonolin
All you have to do is run your gas tank down before you fill up with e85. Then reflash your car with the e85 map. Super simple. I just waited until it got to E and filled up, Shiv mentioned the ECU compensates for small changes in ethanol ratings.
Sonolin is offline   Reply With Quote
The Following 2 Users Say Thank You to Sonolin For This Useful Post:
Carlitoz3 (02-17-2014), skye67 (02-17-2014)
Old 02-17-2014, 04:20 AM   #47
skye67
skye67's Avatar
Drives: 2013 black AT, OFT, 4.65
Im going to drive the shit out of my car this week to fill up at the local E85 station. Kick ass to more powwweeerrrrrrr!
skye67 is offline   Reply With Quote
Old 02-17-2014, 04:50 AM   #48
Carlitoz3
Carlitoz3's Avatar
Seriously
Old 02-18-2014, 02:45 AM   #49
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
Originally Posted by shiv@vishnu View Post
Sonolin-- Thanks for the review! We appreciate it I'm very happy that you are enjoying the tune. And, of course, apologies for the shipping a day late when you told the guys that time was critical. As for shipping costs, definitely call the sales office and they will refund you the difference between what you paid for and what you got. Not to make excuses for them, but the day after we receive a big batch of OFTs is usually pretty crazy since they often need to prepare 50+ OFTs shipments so sometimes things can get a little delayed. Each one takes a few minutes to configure and pre-load so it gets pretty hairy when UPS pick-up times draws near. Also, if you feel that any part of the OFT enclosure is opening, please let us replace it. It's not been my experience for the enclosures to loosen as they are internally glued with compression fittings at all four corners. In fact, I've bent a few screw drivers trying to open enclosure!
DriftHappens-- Yes, indeed. We already support Phantom SC kits. And we will be supporting Vortech SC in the very near future. I'll be spending Monday at Vortech Engineering working with their tuner, on their in-house dyno, calibrating a supercharged 2013 BRZ that we provided to them last week
DAEMANO and WNDSRFR-- Thanks for the props. I'm enjoying Phantom SC as well. In fact, I'm installing a secondary dump pack this weekend.
Xabiss-- With the Stage 1 and Stage 2 EL maps there will be a noticeable change in induction noise right around 3800-4300rpm, at full throttle. This is caused by a valve timing shift which is intended to minimize the torque dip. Most people only hear it immediately after installing their OFT but soon get accustomed to it. Nothing to worry about. It's the sound of the engine making more power
WiebTech Performance- 9 out of 10 communication errors between OFT and Laptop can simply be solved by trying another USB port (use USB 2.0, not a 3.0). Or, in worst case scenario, another computer since some have port interference issues depending on what other applications you have. I have yet to see a problem caused by the OFT and not the laptop settings itself.
Now this is good service, thanks Shiv
leicaboss is offline   Reply With Quote
The Following User Says Thank You to leicaboss For This Useful Post:
Shiv@Openflash (02-18-2014)
Old 02-18-2014, 07:45 AM   #50
Captain Insano
Agreed. I just ordered OFT + OFH combo and gaskets. Thanks for this thread. I was already thinking about pulling the trigger but this was the final read that pushed me to it.
The Following User Says Thank You to Captain Insano For This Useful Post:
Old 02-18-2014, 09:35 PM   #51
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Thanks for the order! I think you'll enjoy it. Especially with the new v1.6 maps I'm currently developing
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
fstlane (02-19-2014), stratodyne (03-19-2014)
Old 02-18-2014, 10:37 PM   #52
Captain Insano
Absolutely! My OFT shipped today.
Shiv@Openflash (02-19-2014)
Old 02-19-2014, 07:55 PM   #53
Proof
Proof's Avatar
Drives: 2007 STI Limited / 2014 BRZ Limited
New maps?! I have not even been able to drive on 1.55!!! Stupid winter
Proof is offline   Reply With Quote
Old 02-19-2014, 10:58 PM   #54
cycleboy
Drives: 2013 Scion FR-S - Argento
What's winter?
- signed Californian who will be buying water from someone come summer!
cycleboy is offline   Reply With Quote
Old 02-19-2014, 11:10 PM   #55
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
What can we expect to see...any hints?
Fizz is offline   Reply With Quote
Old 02-19-2014, 11:12 PM   #56
HSayaovong
HSayaovong's Avatar
Drives: blk;2dr;rwd;fun
Sonolin's review was so persuasive I just bout a OFT. Thanks for the detailed review Sonolin and also to shiv for his quick responses to my PM's
Life is like taking a dump, sometimes it's easy and other times its hard. But it always stinks
HSayaovong is offline   Reply With Quote
The Following User Says Thank You to HSayaovong For This Useful Post:
Shiv@Openflash (02-20-2014)
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
***VISHNU*** OPENFLASH TABLET: Say goodbye to locked tunes Garrett@Openflash Engine, Exhaust, Bolt-Ons 54 06-11-2014 06:29 PM
***VISHNU OpenFlash Tablet IN STOCK*** Garrett@Openflash Engine, Exhaust, Bolt-Ons 15 12-17-2013 01:30 PM
Vishnu OFT tablet software mod request... Tromatic Software Tuning 5 12-07-2013 07:52 PM
FS: Vishnu OpenFlash Tablet - Unused, Mint Condition AyJay Engine, Exhaust, Bolt-Ons 6 11-09-2013 11:45 AM
