CANADA Canada
Old 02-04-2014, 03:15 PM   #43
congee
congee's Avatar
Drives: SSM BRZ
Originally Posted by Taro View Post
Kelby, you gotta get winters. Only the foolish and wreckless dont get them here. It's night and day. Or like life and death, really. Just remember that the car won't handle quite the same
+1
One day in november, it decided to snow 5 cm at night. I still had my all seasons on when it did. It was fun but scary af. No lie, it literally took me about 20 seconds to turn left at an intersection as there was no traction at all. I literally had to drive sideways for most of the time I was out. With winters tires, I have to try really hard to slide it side ways even with 10cm of snow.
congee is offline   Reply With Quote
Old 02-04-2014, 03:33 PM   #44
STV3
Señor Member
STV3's Avatar
Also don't forget while slapping a set of snows on the stock 17" wheels is still good, it's much better to get a smaller set of wheels and throw a set of tall narrow tires on there. A set of 16's with a 205/50 snow tire on them would work very well.
STV3 is offline   Reply With Quote
Old 02-04-2014, 03:56 PM   #45
Kfresh23
Kfresh23's Avatar
Drives: 2013 WRB Subaru BRZ
A little side note about weight in the trunk.......I personally found that it has helped. last year, with no weight I had no problems, but this year, I experimented and found that extra weight helps put a little more grip on the back end when you really need it, like up a steep hill. Side note though: I had a jug of washer fluid in the trunk and it moved around and hit the "VALET" button. This then prevents the trunk from being opened with anything EXCEPT YOUR KEY! Do not think that your trunk button is broken, or that it is frozen shut...first pull out the key from your fob, and open the trunk with it. Then push the valet button located on the drivers side, inside your trunk. The position your washer fluid in a way this does not happen again!
Kfresh23 is offline   Reply With Quote
The Following User Says Thank You to Kfresh23 For This Useful Post:
daiheadjai (02-21-2014)
Old 02-04-2014, 04:19 PM   #46
aghuman
aghuman's Avatar
Drives: 2013 Asphalt FR-S
I put my washer fluid and any other necessities like a few microfiber cloths and scrubber in a little shoe bag that I then tie to the handle that is used to open the cover for the spare tire. Been working like a charm for months now, the last thing id want is a bottle of exploded fluid in my trunk
aghuman is offline   Reply With Quote
The Following User Says Thank You to aghuman For This Useful Post:
Kfresh23 (02-05-2014)
Old 02-05-2014, 10:44 AM   #47
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Drove the car (VSC/TRAC off) the 18 or so km downtown to work.
Poor conditions, but with proper footwear (I keep a pair of comfy shoes in the car - I usually wear leather dress shoes), it was pretty easy to get to work.
If anything, the FWD and AWD guys were driving a lot slower than they needed to (but that's understandable in this weather).
Slowly trying to wean myself off of the nannies.
daiheadjai is offline   Reply With Quote
Old 02-05-2014, 10:52 AM   #48
Kfresh23
Kfresh23's Avatar
Got in my car this morning, and at -25C, she started right up! This is what my dash looked like though! Almost had to scrape it!!
For the first time my stereo/Nav unit did not come on right away.......about half way to work, it did with a message "temperature returned to normal". At least I know this is supposed to happen.
I also love the "smoke screen" you give the people behind you when you accelerate from a light while the hot gas expells from the dual exhaust!
Old 02-07-2014, 06:24 PM   #49
J-Cam
J-Cam's Avatar
Drives: FR-S MT
Just shy of 30,000km's in the 6 short month's I've owned the FR-S, it's still a joy to drive. To say we've been through a lot this winter would be a bit of an understatement.. No problems.. but I'm ready for spring now...
J-Cam is offline   Reply With Quote
Old 02-08-2014, 08:22 PM   #50
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Decided to drive the car out today seeing how all the roads are bone dry. Finally got to use VSC Sport Mode in crappy unplowed tight parking lots and even up the ill-plowed Shell car wash path. The allowed wheelspin is just perfect and not too crazy. Getting into the car wash with the car wiggling non-stop while making sure to not wrap it onto the sides of the entrance took quite a bit of finesse.
krayzie is offline   Reply With Quote
Old 02-08-2014, 09:51 PM   #51
brzr
brzr's Avatar
Drives: 2013 frs
you washed the car today?
i'm itching to wash mine so badly.......haven't given my baby a bath since october......i'm starting to feel anxious, especially when i see all the dirt collected on the bottom of the door panels
brzr is offline   Reply With Quote
Old 02-08-2014, 10:31 PM   #52
krayzie
Drive From Home
krayzie's Avatar
Don't want to piss off the garage next week for the flexible draw stiffeners install with a really dirty undercarriage (OMFG I sat there for an hour translating the instructions into English without knowing much Japanese lol).
I'm always afraid that the bolts underneath will rust and seize from Winter driving before I'm able to afford to get all the mods I want bolted onto the car.
Old 02-08-2014, 11:09 PM   #53
PMPB
Drives: BRZ Sport-tech
Last weekend we got a little rain, and that took off most of the salt, but then I took her to the touchless, got the under-body spray washer and took my sweet time going over the jets. She looked so pretty in the driveway.
... Then we got 25cm of snow. Haven't moved her in over a week now.
PMPB is offline   Reply With Quote
Old 02-09-2014, 12:17 AM   #54
brzr
brzr's Avatar
Drives: 2013 frs
mine's been sitting in the garage for most of the week.....i did go out yesterday to get some food.......but soo soo dirty....and my garage is so tight...maybe i can try and wash the car tomorrow inside the garage......it's been driving me insane for weeks now
Old 02-12-2014, 08:51 PM   #55
Sigh On
Drives: Scion FR-S
...I'm running 200lbs of a bagged "sandbox" in my trunk, strategiclly placed around a 12"sub...Hankook iPikeRS winter wires..Weathertech insanely slippery, gonna twist your ankle/break your leg mats while trying to look normal getting in your car and realizing you just performed a new yoga move.... mini shovel knowing I'm going to get stuck in deep snow..... and a huge a$$ brush...A thrill to drive in winter if you are smart and drive to the conditions...Depressing when its dirty...short term excitment when you finally wash the car and remember its original colour and lustre;short lived with the winter we have been having, but memorable nonetheless.........I dont know about anyone else but the inside of the car heats up quickly, and its a "carbeque" in no time..
my 2 cents......
Sigh On is offline   Reply With Quote
Old 02-20-2014, 07:30 PM   #56
krayzie
Drive From Home
krayzie's Avatar
This is why Suberman can't drive for f*ing shitz!
Internet died so I had to goto the office.
I came out at 5pm to the parking lot and it's a fluffy snowstorm (thanks for the disinfo Environment Canada). All I had was new Michelin Pilot Sport A/S 3 tires and absolutely no experience with RWD stick shift driving in the snow. Took off in 2nd gear and quickly into 3rd and then 4th all the way home from Markham to Scarborough @ 30ish km/h (car becomes unstable when it hits 40km/h). The ass kept swinging out to the right (VSC & VSC Sport made no diff.) and freaked everybody out so they all gave me plenty of room. Did stalled at Midland and Finch cuz the snow was too thick, so I looked like a loser going thru the intersection mad slow sideways lol! Made it home in one piece no sweat really. Hardest part was actually making up the driveway and into the garage with zero traction so did take me a min or two.
17" Michelin Pilot Alpin on another set of STI rims next year for sure.
no suberman yet?
Winter Driving? project d CANADA 383 01-28-2014 08:52 PM
Why winter driving is so much fun in this car Suberman CANADA 5 01-25-2014 01:48 PM
winter driving jmaryt Scion FR-S / Toyota 86 GT86 General Forum 88 11-11-2013 12:15 PM
winter driving paraguin BRZ First-Gen (2012+) — General Topics 25 08-03-2012 06:26 PM
