Old 04-05-2014, 08:52 PM   #43
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Do you have any pics of them lit up side by side with a BRZ with the stock power boomerangs (entire vehicles, not headlight next to headlight)? I'd like to see the comparison.
Old 04-12-2014, 10:48 AM   #44
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
First post has been updated with side by side comparison shots.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 04-15-2014, 08:51 PM   #45
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
Originally Posted by Acree View Post
EDIT: 4/12/14
Here are some crappy side by side photos of my car with a stock BRZ boomerang. Sorry for the iPhone camera.
Hey @h4nh it's your BRZ
mikeTee is offline   Reply With Quote
Old 04-15-2014, 09:11 PM   #46
B-R-Z
B-R-Z's Avatar
Wow that's bright and nice, gj
Old 04-16-2014, 05:51 PM   #47
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Quick question on this, did you bake the lights to get to the components inside? And if so, did you bake them with the HID bulbs and wiring/etc everything still attached? Seems like that is the only way to do this and to access the wiring. Just didnt see anywhere that you mentioned it.
gdrider77 is offline   Reply With Quote
Old 04-27-2014, 02:27 AM   #48
flightmaster
flightmaster's Avatar
Drives: Subaru BRZ
Great tutorial, wish I had the know-how to do this myself!
Bump for an answer to this question
flightmaster is offline   Reply With Quote
Old 04-27-2014, 12:12 PM   #49
gdrider77
gdrider77's Avatar
Just did this. Also blacked out the lights. Looks great. Man they are bright now!!
One thing i would add, you dont have to trim the fins on the heatsinks. What i did was simply heat the plastic that they are hitting with a heatgun, then pushed that in slightly, allows the full heatsink to fit, and is much easier and faster to simply do that.
Old 04-28-2014, 04:52 AM   #50
flightmaster
Drives: Subaru BRZ
Are you experienced at this sort of thing? How difficult would you say it would be for someone with little knowledge of this type of thing to do?
Old 04-28-2014, 01:08 PM   #51
Acree
Acree's Avatar
I removed what I could which would be the ballast and bulb. The wiring harness has to remain on the headlight when baking because part of it can't be unplugged until you separate the housing and the lens.
That's great to know! I'm glad you completed the tutorial successfully. I believe you are the first.
Old 04-28-2014, 04:19 PM   #52
gdrider77
gdrider77's Avatar
Not experienced at all. Although I feel very comfortable soldering. That's the key thing in my opinion. If you feel comfortable soldering a circuit board connection.
Honestly, I was more concerned with baking my lights and taking apart and reassembling. That was tough.
The circuit board mod was quite simple , as its really just a few solder connections.
Do make sure you have a multimeter to check the connections for continuity after scoring the trace. As noted, be absolutely certain there is a good clean brake, you need to be sure the connection is open.
I always go into a new mod with the idea that it could go wrong and you will be paying for a new part. If you can't accept that, then I advise you to not do this.
Old 04-29-2014, 02:49 AM   #53
flightmaster
Drives: Subaru BRZ
Honestly, I was note concerned with baking my lights and taking apart and reassembling. That was tough.
Cool, thanks for the great advice! Really helps
Old 05-01-2014, 01:13 AM   #54
FitchAlcyone
FitchAlcyone's Avatar
Drives: 2019 BRZ Series.Gray
Great job! If you get a chance, could you please take some daytime photos as well?
FitchAlcyone is offline   Reply With Quote
Old 05-22-2014, 11:55 PM   #55
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Hope no one minds me bumping this but...
I was wondering, how easy/possible would it be to scrap the stock setup altogether and replace the LEDs with SMD 5050 RGB LEDs with a RGB controller?
I see places making angel eyes using SMD 5050 RGBs mounted in a circle with one of those common chinese RF or IR controllers.
I cant seem to find any pre-wired single SMD 5050 RGB LED though, I only see them sold in strips. Any ideas?
PandaSPUR is offline   Reply With Quote
Old 05-24-2014, 11:47 PM   #56
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
hmm... this is pretty tempting, and looks really pretty easy. Looks great, and great write up!
brighter fog light bulb for BRZ? chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 17 01-11-2016 01:57 AM
Interior LED Dome Light Diffuser | DIY | 6X Brighter Dezoris Cosmetic Modification (Interior/Exterior/Lighting) 8 04-21-2013 08:59 PM
Brighter "Boomerangs" Jaylyons1 Mid-Atlantic 3 02-05-2013 07:53 PM
