Old 02-05-2014, 04:31 PM   #43
weedtank
weedtank's Avatar
Drives: Ultramarine
Originally Posted by tr1x5tuh View Post
Here's my experience with Bryson R
Attachment 63857Attachment 63858Attachment 63859
The body shop that I took it to said they were one of the easiest pieces they have ever done. And I told them I paid only around $75 for them and they were shocked at how good it fit for so cheap. I got to say though it's a 9/10 fit I was recommended to not use the double sided tape that was attached to the kit. So I used the body shops 3m tape so I have never tried their tape but it looked legit.
Which shop did you go to for paint?
weedtank is offline   Reply With Quote
Old 02-05-2014, 04:46 PM   #44
tr1x5tuh
The Original Super Saiyan
tr1x5tuh's Avatar
Drives: 2014 SWP BRZ
i went to orange county collision and glass in fullerton. speak to Diego he's super chill. He has my uncles 5 series in there right now and my god its coming together. paint matching is his specialty.
To each his own, Agree to Disagree
tr1x5tuh is offline   Reply With Quote
The Following User Says Thank You to tr1x5tuh For This Useful Post:
weedtank (02-05-2014)
Old 02-05-2014, 04:49 PM   #45
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Originally Posted by jonathan9573 View Post
Don't suppose you will be removing the license plate bracket on your?
Nope. Required in Md so ill just be leaving it
Old 02-05-2014, 04:59 PM   #46
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
Well I LITERALLY just got the front lip in an unpackaged it. First thing I have to say is the packaging is very well done. It didn't come in a box but was basically wrapped in a bubble wrap, heavy duty cardboard armor and a whole lot of box tape. If it was going to get broken it would have to get run over by a truck. Also had "fragile" box tape around it to. Not that that usually helps but it was still there. So after i got it out of its armor shipping cage it looked very good as far as quality. The finish is very smooth and crisp. The edges are a tiny bit ruff and i do mean tiny bit. I will most likely take a bit of 300 grit sand paper to them when I test fit it. The ABS is quality thickness. Probably about 1/8 inch. There is 4 metal brackets on the underneath of the lip to attach it to the car which are riveted to the bumper and not screwed which shows more effort to me in quality.
It comes with the rubber edging where the lips fits up tight to the bumper of the car with is AWESOME. Leaves a very nice edge, also a very nice addition.
Then a few bolt for the license plate and a few screws for where it wraps around the inner wheel wells. It does not come with double sided tape so that will have to be added but not a big deal to me.
There was 1 small gouge in the front about 1/2 inch long but easily fixed before paint.
I can not speak for the fitment to the car just yet because my car is under a cover in my driveway with 6 inches of snow on it right now but as far as fist impressions and over all quality i am completely satisfied.
This bumper should is very good for the price and its defiantly not going to get that sag that occurs with poly kits.
you mention you are going remove the license plate frame..right?? please do a DIY on it, if I go with this front lip I will probably remove the license plate frame too..just dont know how the ABS holds while cutting it.
Old 02-05-2014, 05:00 PM   #47
jonathan9573
jonathan9573's Avatar
Drives: 2013 Asphalt Scion FR-S
I will do the best I can for a DIY but it will be pretty labor intensive .
Sent from my iPhone using Tapatalk 2
jonathan9573 is offline   Reply With Quote
Old 02-06-2014, 09:52 PM   #48
spitfire481
Drives: 2JZ FRS
Front lip arrived today. Left California on the 4th, delivered to my shop in maryland on the 6th. Awesome. Packaging was perfect. Actually took about 10 minutes to get it out haha. Edges were all clean, but the best part was fitment. My bumper is off the car and on a bumper stand. Fitment was spot on. All gaps were perfect, all corners lined up as they should. Not sure what the oem has to offer over this. Took a few pics but won't be home to upload them until Saturday probably
Old 02-06-2014, 09:53 PM   #49
jonathan9573
Good to hear. I won't be test fitting mine till the snow clears up here in illinois.
Old 02-07-2014, 12:28 PM   #50
sirsol66
Drives: 2013 FRS- Hot Lava
Pics would be fantastic!
sirsol66 is offline   Reply With Quote
Old 02-07-2014, 12:36 PM   #51
jonathan9573
Size:  180.5 KBName:  ImageUploadedByTapatalk1391794573.117141.jpg
Old 02-07-2014, 12:37 PM   #52
jonathan9573
Old 02-07-2014, 01:02 PM   #53
spitfire481
Drives: 2JZ FRS
this is just sitting in place. no tape, screws or anything else
The Following 3 Users Say Thank You to spitfire481 For This Useful Post:
jonathan9573 (02-08-2014), Midarete (02-13-2014), van_fc3s (02-08-2014)
Old 02-07-2014, 01:08 PM   #54
jonathan9573
That looks like it fits perfectly.
Old 02-07-2014, 01:11 PM   #55
spitfire481
Drives: 2JZ FRS
i am not correcting anything on it. the kit is not even supposed to be double sided taped on. there are supposed to be two screws up behind the license plate into the bumper (i drilled two new holes slightly lower so they are into the grille so nothing permanent is done to the bumper). then the clips underneath. the rubber gasket is there to hide any slight gap since its not taped to the bumper. i will be adding an inch or so of tape to each section just to make sure it does stay snug.
Old 02-07-2014, 01:13 PM   #56
jonathan9573
Did you order the whole kit or just the front lip?
Bayson R lip kit review Cjymiller Cosmetic Modification (Interior/Exterior/Lighting) 59 07-06-2017 01:23 PM
Weather strip/Rubber seal for bodykits FRSHunter Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2016 04:34 AM
Weatherstrips for bodykits FRSHunter Exterior Parts (Aero, Lighting, Etc.) 1 12-14-2013 09:15 PM
Who has Bayson R Lip kit? Cjymiller Northern California 21 09-29-2013 09:52 AM
Bodykits....Bodykits....Bodykits.... FT-86GOD AUSTRALIA 78 08-08-2012 09:44 AM
