Old 05-03-2012, 04:20 AM   #43
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Originally Posted by Phaedrus29 View Post
Can someone explain this? Not sure what all this means.
On Subaru motors, they have a 2 stage cam system to open the valves up quicker...it is called AVCS or Dual AVCS ..Single AVCS is for the Intake cams. DUAL AVCS is for both intake/exhaust cams.
From WIKI:
The active valve control system (AVCS) is an automobile variable valve timing technology used by Subaru. It varies the timing of the intake valves by using hydraulic oil pressure to rotate the camshaft in order to provide optimal air flow in and out of the engine. The system is closed loop using camshaft sensors, crankshaft sensors, air flow meter, throttle position as well as oxygen sensors and/or Air-Fuel ratio sensors in order to calculate engine load. The ECU is programmed to operate control valves that adjust the delivery of the hydraulic pressure in order to move the camshaft into the position that will provide the engine with the best performance while minding emissions standards.
Dual AVCS is also found on Japanese Spec engines, although a complete list of the engines with Dual AVCS has yet to be compiled.
In Essence, Subaru did not Aggressively TUNE the AVCS Crossover point,it is kinda flat, most likely for emission reasons. In most Tuning Applications for Subaru: Cobb, TXS, Element, AEM and even the factory ECU...there is a more aggressive map qualities that allow the AVCS to be more aggressively tuned...therefore: eliminating or at least improving that Dead Spot.. Hope that answers your question. sorry it took so long to get back to you.. Any more questions.. LMK.
Bill
Scooby South is offline   Reply With Quote
Old 05-06-2012, 04:22 AM   #44
Lordharding
Drives: Subaru WRXd & classic turbo 2000
Well I had a great hour with one in the showroom last night and can confirm there is plenty of headroom for my 6 height
Also my 5'4 misses can drive with the seat forward with me sitting in the back seat
It will never happen though
She squeezed into the back and I was quite far back just to gave her an inch or too and I could drive also
Seats are well shaped in the back the trick being you must raise the seat height to stop crushing the rear seat passengers as you slide it back
When I did my head test there is plenty of seat height adjustment
Car is fantastic
Lordharding is offline   Reply With Quote
Dealer wants to do a launch event around delivering car to me HotLavaMann Scion FR-S / Toyota 86 GT86 General Forum 24 05-09-2012 02:16 AM
Sat in FR-S yesterday Arthur Scion FR-S / Toyota 86 GT86 General Forum 35 04-11-2012 12:50 AM
Interesting take on 2012 GT-R bofa Other Vehicles & General Automotive Discussions 84 08-29-2011 06:38 AM
Why ft-86 is interesting? NewCarInQ42011 Scion FR-S / Toyota 86 GT86 General Forum 69 11-26-2010 04:05 PM
