Old 04-30-2012, 01:14 PM   #43
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Originally Posted by Sleeperz View Post
Oversteer only occurs when your pushing the limits of the car. Don't turn off the Stability control and you will be fine. Lots of new technology on the lastest cars to keep you out of trouble.
30 years ago Domestic V8 cars had less than 200 HP from 5+ L . Now your getting 200Hp from 2L that is why cars these days have stability and traction control.
Good Test Video
http://www.ft86club.com/forums/showthread.php?t=5528
LOL i think you did not read my post but this will be my track car so pushing it to the limits will be part of a daily routine with her . I hate Stability control and abs for track driving since they interfere almost all the time under the slightest sign of pushing the car towards the limit. It might be good to leave the stability control on sport at first to learn the behavior of the car though. But my current track car has no stability control or abs and is pushing 380whp lol and no problems so far my stability control is in my foot lol.
Thanks for the video its great!!!
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 04-30-2012, 07:42 PM   #44
fatoni
Originally Posted by pcasso87 View Post
Yup im wondering if its a bit too much though, a way to correct it could also be going a bit wider in the back but i am afraid to cause understeer on a car thats so well balanced. Its weird that all tires are the same size, and normally rwd cars come with a staggered setup.
i wouldnt call staggering normal. i actually think its kind of stupid unless you have a fwd car, a midship, or make obscene power. what you should really do is pick a tire you want and then find the lightest, widest rim that will work with that tire
Old 04-30-2012, 07:48 PM   #45
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by fatoni View Post
you pick a tire size and go with the widest wheel possible not the other way around
Well.. not really..
You pick the wheel size that works BEST for your tire size (or vice versa, doesn't really matter which side you start with).
You could probably put a 195 on a 12" wide wheel but you shouldn't unless you are doing it for "looks"...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-30-2012, 07:51 PM   #46
track_warrior
Track Junkie
I understand your reasoning behind that but its unexplainable why for example my c63 has no understeer even with 235's up front and 265's in the rear its still very tail happy though i have noticed that if i create a drift its hard to control since the front wheels seem to respond less. I have to say that turn in is great even with skinnier tires up front i guess it must have something to do then with the weight balance or the suspension geometry of the car. Its one of those weird things like i still cant understand why a gt-3 has no understeer even though the engine sits way back in the car and the front tires are skinnier, but if you rotate the tail a bit on a gt-3 its very hard to get it back under control since that weight in the back acts like a slingshot.
Old 04-30-2012, 07:52 PM   #47
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yes i have, two friends have spec miatas with seats welded to the floor i still rub the roof plus i did not like the visibility from being so far down to the floor plus i found the seats uncomfortable.
Huh? So you still rubbed the roof.. yet visibility was bad because you were so low? Are these SCCA prepared class (EP or whatever the hell a Miata is legal for) instead of SM/ITA cars? That statement doesn't make sense unless the windshield is chopped/removed. and the bars are just high enough to clear the owners heads.
Seats are personal preference. I've liked some and hated some, but that doesn't really apply to the current topic.
I think you got the wrong idea since i was just saying they are grippy compared to other brands or oem tires.
While I doubt the Federals.. how do they compare to RS-3s, StarSpecs, RE-11s and AD08s in your opinion?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-30-2012, 07:54 PM   #48
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
This is coming from a person who probably has little to no track experience since your closest racetrack is in washington? Trust me i lived in Vancouver and know there is not a race track nearby.
30K for you buddy i live in the US more like 27.5 out the door for me. It might confuse you but im here to make it stick through your thick head i asked for tire size advice not Brand Advice. I bet the closest you have ever come to r compounds or a race track is super street magazine.
His point was valid, there's no need to go after him. He wasn't attacking you so you don't need to attack him.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-30-2012, 08:00 PM   #49
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Suspension tuning, HP/TQ, etc.
C63s understeer unless you are on throttle, at least the students that I drove did like a pig. :shrug:
This car was setup for a non-staggered setup, going staggered will shift traction towards the rear, which if the car is neutral and no other changes are made will result in understeer.
Fast S2000s IMO (which are staggered from the factory) run non-staggered setups as well.. and those are cars that many drivers claim are oversteer happy, although I've found you have to be VERY ROUGH with throttle application for them to oversteer that much.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-30-2012, 08:02 PM   #50
fatoni
Well.. not really..
when i say works i dont mean fits physically, i mean works. the widest recommended rim is going to be faster than the thinnest
there are explanations galore. narrow front tires increase turn in response (which is why i said not to go 235 on stock rims), the car is designed around a stagger, suspension geometry weight balance, power and mainly front roll couple all alter steady state handling handling. your c63 isnt a sports car and it has way more power than the frs. the gt3 is a nice car but you will have no trouble finding enthusiasts who will say that if the cayman was built to that degree it would be the better car
Old 04-30-2012, 08:08 PM   #51
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Agreed. Just didn't want to see you telling people to go hellaflush :P
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 04-30-2012, 08:49 PM   #52
2000
Drives: None
Good Test Video
I thought they had stability control because they are required by law.
http://www.nhtsa.gov/Laws+&+Regulati...trol+%28ESC%29
2000 is offline   Reply With Quote
Old 04-30-2012, 09:16 PM   #53
fatoni
you mean you wouldnt want 185 allseasons on some dope xxr 15x9s?
Old 04-30-2012, 11:35 PM   #54
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Well of course *I* do, but that doesn't mean I want others to as well
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-01-2012, 02:29 AM   #55
track_warrior
Track Junkie
Old 05-02-2012, 06:41 AM   #56
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
For what it worth since this thread has gotten waaaaay of topic, lol, I'm planning on running 225/45/17 Star Specs but I'm having a lot if trouble finding a 17x7 lightweight wheel in 5x100 with a good offset. Everyone either makes 17x7.5 or 17x8. In order to stay in stock class in SCCA Solo II you have to stick with stock diameter/width unless there was an optional wheel then you can go up to that. I wouldn't go crazy with width since a lighter wheel tire will keep a lighter/lower HP car faster.
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Delete driver01 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-21-2012 12:50 AM
Stock all-season tires? Wait4BRZ_STI? Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 05-03-2012 07:58 PM
Which stock JDM wheels do you prefer? switchlanez Scion FR-S / Toyota 86 GT86 General Forum 40 02-08-2012 07:34 PM
Why are most stock wheels weak stance? #87 Other Vehicles & General Automotive Discussions 16 12-17-2011 05:15 AM
Anybody considered using 16" wheels for the track? ft86Fan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 12-08-2011 09:55 AM
