Old 01-13-2014, 01:16 AM   #43
sandman126
Slide Ways
sandman126's Avatar
Drives: 2013 SWP BRZ, 85 VW Golf
delicioustuning,
How do you feel about remote tuning a JDL turbo setup? Not exactly a lot of tuning options in my area (minot, ND)
sandman126 is offline   Reply With Quote
Old 01-13-2014, 01:33 AM   #44
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by sandman126 View Post
delicioustuning,
MAF system or a Speed Density setup? Need to know a little more about the kit. From there I can determine what can be offered and also the boost levels/power levels you are looking for.
Cheers,
William Knose
Old 01-13-2014, 01:43 AM   #45
sandman126
Slide Ways
sandman126's Avatar
maf system I'm pretty sure, not sure of the difference. Precision 5130 turbo, deatchwerks 900cc injectors and 265 fuel pump, 3" turbo back. Hoping for 300-350whp on 91oct. Then eventually flex fuel making around 450whp. Any other info needed than this?
Old 01-19-2014, 10:22 PM   #46
DeliciousTuning
Now that I have dialed in Speed Density with a new 10 PSI MAP sensor I feel very confident tuning any turbo kits via speed density now. As it should make quick work of the tuning. So it should not be a problem.
Next will be working on a larger MAP sensor. Trying to determine the ideal larger MAP sensor. In the mean time here is what to expect from the current 10 PSI MAP sensor on Speed Density.
http://www.ft86club.com/forums/showp...&postcount=595
Cheers,
William Knose
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
Deadspool (01-19-2014), sandman126 (01-20-2014)
Old 01-19-2014, 10:32 PM   #47
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
When would you suggest using a MAP sensor over MAF? I know there has been debate over this before but I'm not sure which I should use given my goals. I ask you because right now you're the front runner on who I'll be purchasing my tune from.
Oh and my goals:
Innovate Stg2 w/ 72.5mm pulley - waiting on tax refund
nameless header - purchased, waiting on delivery
3" headerback exhaust - have OP/DP, need to order the rest
Tuned on 93
looking to get minimum 250whp
anything over that is icing on the cake.
Dustin is offline   Reply With Quote
Old 01-19-2014, 10:46 PM   #48
DeliciousTuning
Oh and my goals:
Tuned on 93
MAF is a great and if you can use as long as it is placed prior to the forced induction system as it was designed, then it will work well. Though a lot of turbo kits or supercharger kits do not seem to take this into consideration and use it as a blow-through, my least favorite design.
When you are put into this situation, speed density is a much better way to go. Also with MAF, you can scale the MAF up to a 3 inch intake, not a problem, though this will still limit you on how much power you can make.
With the Innovate Kit you are fine on the stock MAF sensor all the way through 300+ whp on E85. So not an issue.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Dustin (01-19-2014)
Old 01-21-2014, 11:15 PM   #49
Dezoris
Dezoris's Avatar
Vortech support planned, or is this one those you need to do onsite?
Old 01-22-2014, 12:19 AM   #50
DeliciousTuning
Need to do. But it is getting finished up in about 1-2 months. I am finishing up some other supercharger tunes and then will be finalizing that one.
Cheers,
William Knose
Old 01-22-2014, 01:05 AM   #51
Dezoris
Dezoris's Avatar
Cheers,
William Knose
I was checking to see how much it would cost to ship car out to you and drive back, or to drive out there for tuning and there is just no good way to do it without costing either a few grand in shipping or a weeks worth of driving.
Want a tune as perfect as possible with reliability for street (100F or 10F), and track consistency lap over lap. Power/output numbers are a last priority.
The Following User Says Thank You to Dezoris For This Useful Post:
CK_Bladesmith (01-22-2014)
Old 01-22-2014, 01:53 AM   #52
DeliciousTuning
Well were are you located? Think you can get a few people together for tuning? Maybe we can fly out there and dial it in?
Old 01-22-2014, 02:12 AM   #53
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
@DeliciousTuning on your Innovate tune what do you rec for fuel? I see a lot of people being tuned on the stock injectors and a DW65 fuel pump only. Even with your e85 tunes for this specific FI kit. I ask because all the other tuners on the board require bigger port injectors for e85. Have you found something in Your tuning this kit that others have not using ecutek? Also is a 3bar map sensor rec or is the factory sensor okay?
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 01-22-2014, 02:13 AM   #54
jflogerzi
jflogerzi's Avatar
So are the tunes that you have in the thread, are they one tune fits all? Or do we still need dyno tuning?
The Following User Says Thank You to jflogerzi For This Useful Post:
evo4g63 (01-22-2014)
Old 01-22-2014, 02:15 AM   #55
Dezoris
Dezoris's Avatar
Northern Illinois, 45 minutes outside Chicago. It's possible to get maybe 3-4 guys together maybe more, but I would have to do some research on it.
When you get a chance maybe throw together some specifics of what you need including ballpark of costs for you to do this so I can find out if it makes sense.
I have a local guy with a dyno who is good about renting out time as well.
Old 01-22-2014, 03:50 PM   #56
Brick
Drives: White 2013 FRS
I have a FA20 club kit that I will be installing when I have the time, there is no real reason that I couldn't use the FBM tune correct? Also I am going to be welding in a recirc line for the wastegate instead of open dump. Is the recirc line required to be before or after the 02 sensor or does it matter for the tune? @DeliciousTuning
Thanks
Brick is offline   Reply With Quote
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 04:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 06:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 02:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 03:33 PM
