03-30-2015, 05:19 PM | #43 |
Drives: WRB JR BRZED
1-2 miles around the track. I could stroll around the paddock if that would help.
03-30-2015, 08:42 PM | #44 |
03-30-2015, 11:41 PM | #45 |
03-31-2015, 12:39 PM | #46 |
ABS heats up the pad significantly and if you're constantly on it with minimal cool down time, that heat gets transferred to other components in your brake system. Cut down on the ABS engagement since you should pretty much know when it comes on now and your braking performance should be more consistent.
05-10-2015, 04:55 PM | #47 |
First 86
Anyone had this gel up in the reservoir?
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch |
06-24-2015, 02:40 PM | #48 |
06-24-2015, 06:15 PM | #49 |
First 86
Only thing I can figure is the tech contaminated it somehow when I had it done at a shop. I sucked out the reservoir, filled with fresh, sucked that back out, filled fresh again, then bled the whole system out with fresh.
06-24-2015, 07:10 PM | #50 |
Some Dumb Guy
Drives: wanting an Acabian
I'm glad that this about a DOT 4 brake fluid as I checked with Scion about changing fluids and the following was their response.
"Recently you contacted Scion Customer Experience. Below is a summary of your contact message and our response. Thank you for allowing us to be of service to you. Subject Modifications affect on warranty Discussion Thread Response Via Email (Brett K.)05/12/2014 04:48 PM Dear Mr. Blank, Thank you for contacting Scion. We apologize as we do not recommend or assist with modifying our vehicles from the original factory specifications.Scion's warranty covers repairs and adjustments needed to correct defects in materials or workmanship of any part supplied by Scion. Modifications to your vehicle could affect the performance, safety or durability, and may violate government regulations. Non-Genuine Scion Parts, or any damage or failures resulting from their use, are not covered by any Scion warranty. We would recommend using the fluid below for the brakes in your FR-S: FMVSS No.116 fresh DOT 3 or DOT 4 brake fluid If you have any further questions or comments, call us toll free at 1-866-70-SCION, Monday-Friday 5am-6pm PST and Saturdays 7am-4pm PST. Brett K. Scion Customer Experience Customer By Web Form (Mr. Blank)05/10/2014 06:55 AM My question is what affect on my warranty would changing my brake fluid to a DOT 6 brake fluid have? I would like to have better than stock brake fluid in my vehicle and the service contact at the dealership suggested that it might impact my warranty should I change my brake fluid." I like to do my research first and the recommended DOT 6 isn't to be found. I still wanted to know what Scion's thoughts were.
She said it was her or the car. Longest she had ever seen.
06-24-2015, 07:57 PM | #51 | |
I'm not familiar with any DOT6 fluids... |
The Following User Says Thank You to CSG Mike For This Useful Post: |
06-24-2015, 08:13 PM | #52 |
Some Dumb Guy
That's what I said, but if you google it, there is a DOT 4 Class 6 fluid.
06-24-2015, 09:16 PM | #53 |
The Following User Says Thank You to CSG Mike For This Useful Post: | Hyper4mance2k (06-30-2016) |
06-24-2015, 09:27 PM | #54 |
Some Dumb Guy
Please reread the last two sentences of my comment. My thanks to CSG David.
10-06-2015, 11:59 PM | #55 | |
Drives: Subaru BRZ / Toyota 86 Experts
Here is what someone summarized regarding the "Class 6" requirement: http://www.jaguarforums.com/forum/ge...ss-6-a-100370/ ISO 4925 class 6 addresses brake fluid with low temperature viscosity requirements for ABS and traction control systems. It also addresses chemical compatibility with two specific newer seal materials. The viscosity of such a brake fluid at -40C is in the range of 750 cST whereas typical DOT4 is in the range of 1500 cST. The ISO 4925 Class 6 standard for "Super DOT4" is a good one and thus, ATE SL.6 was formulated. Is it better than other brake fluids? Depends. They are all designed with a purpose in mind and every single brake fluid has a specific range of application. The purpose for this "Super DOT4" is meant for a better ABS response in low temperature regions. Some reports saying it's 30% more responsive, but 30% responsiveness is a vague quantitative value...significant, but vague. Qualitative is another subject which is extremely subjective. For our purposes and many others with a larger application range they are seeking, Torque RT700 is a great brake fluid to work with. We have quite a stock of RT700 so please do not hesitate to contact us for the brake fluid alongside a set of pads you may be seeking for your application. |
The Following User Says Thank You to CounterSpace Garage For This Useful Post: | Blu-by-U (10-08-2015) |
12-08-2015, 02:04 PM | #56 |
Drives: 2013 GBS BRZ Limited
Two questions:
1 - I am due to change my BF in my DD (35k miles), and I have a few quarts of ATE super blue that is a few years old (never opened). Can I use that to push out the old stock BRZ fluid (are all DOT4 BFs compatible with each other) AND 2 - Regarding having the absolute highest boiling point of BF in a race car. I was told by a brake expert at driver's school that you will ruin the piston seals in brakes at 400deg ( I assume he meant 400F). So if that is the case, wouldn't we WANT the fluid to boil and let you know you are cooking the calipers BEFORE you destroy the seals? Just curious. Seems to me that IF you boil ANY of the fluids in the chart on page 1, you have already ruined the seals.... |
Similar Threads | ||||
CounterSpace Garage - Authorized Dealer - Torque RT700 Racing Brake Fluid | CounterSpace Garage | Announcements, Contests, Giveaways | 0 | 09-26-2013 07:33 PM |
Brake fluid question | barabia | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 07-31-2013 11:08 PM |
Amount of Brake Fluid.... | THEmailman | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 04-13-2013 11:46 PM |
Brake fluid leak.. | tintumz22 | Issues | Warranty | Recalls / TSB | 9 | 02-01-2013 03:20 PM |
Racing brake fluid promo | MillersOilsUS | Brakes, Suspension, Chassis | 0 | 12-31-2012 11:29 AM |
