Old 09-28-2013, 07:37 PM   #43
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Unless the exhaust temps are the reason innovates sensors burned up I'd stay away from them.
Had 5 in 50k miles on my wrx. Then the unit itself started having problems.
From what I understand the aem worked better but needed a custom cable to log with
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 09-28-2013, 08:46 PM   #44
jamesm
Weird I've used innovate sensors (actually they're Bosch sensors, same supplied to many oems) for years without issues. Where were you installing them? Heat can be an issue if installed in the wrong location.
Old 09-29-2013, 08:29 AM   #45
StormTrooper
As far back in the dp as the cable would reach....
It was wrapped and I was running high boost. As much for the fact that I have 12psi for atmosphere
GR86 MT premium
Old 09-29-2013, 12:19 PM   #46
jamesm
maybe the wrap, load on the turbo, and placement options conspired to kill your sensors lol.
Old 09-29-2013, 01:51 PM   #47
StormTrooper
About 300whp at 4500 ft.
Takes lots of boost in a stock turbo wrx.
GR86 MT premium
Old 09-29-2013, 02:45 PM   #48
stugray
Drives: 2013 GBS BRZ Limited
I tried to get romraider to work with one of the posted RR_BRZ ECU definition files.
I get the "Cannot find ECU definition file" error.
Anyone on this forum actually get it to work yet?
I dont want to flash anything.
I just wanted to play with romraider before deciding if I want to go the ecuflash route or the openflash tablet route?
BTW - what ROM editor is used with Openflash? Can you still use romraider to edit the ROMs?
Old 09-29-2013, 03:13 PM   #49
jamesm
you can open the rom colby posted in tunerpro with the openflash defs (just don't open the flat foot shift or launch control tables lol). still waiting on the guy from the romraider forum to post his xml def. you could convert the .xdf from the openflash files to a romraider xml if you really didn't want to wait for it, or just use tunerpro for the time being.
that's important to note: you can use any tuning software for which defs are available for either flashing solution. all the openflash/ecuflash do is flash the rom. editing it is an entirely separate process.
Old 10-01-2013, 07:00 PM   #50
SkullWorks
Drives: SSM LT MT BRZ
you can use RomRaider and the RR_ZA1JA00c XML to open any of the OpenFlash Roms that have the SAME revision (ZA1JA00C)
Rom Raider actually has many more defined tables...and since td-d actually knows what he is looking at/for, ALL of the CEL tables have been Identified and defined. Looks highly promising...just waiting on the beta of ECUFlash now....
SkullWorks is offline   Reply With Quote
Old 10-01-2013, 07:21 PM   #51
Sonolin
Does anybody know if Ecuflash has a donation link? I'd love to donate to them (they are open source aren't they? Couldn't find much information about the actual software...).
Sonolin is offline   Reply With Quote
The Following User Says Thank You to Sonolin For This Useful Post:
EAGLE5 (10-01-2013)
Old 10-01-2013, 11:58 PM   #52
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
As far as I can tell, the RR defs work for any of the OpenFlash roms. They all appear to be based around the same ZA1JA00C rom. They just appear to have the CAL ID headers changed.
FrX is offline   Reply With Quote
Old 10-02-2013, 12:24 AM   #53
jamesm
if you wanna support ecuflash, buy a tactrix cable. if you wanna support romraider, you can donate on the romraider.com main page with paypal.
ecuflash isn't open source, romraider is.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
EAGLE5 (10-02-2013), Sonolin (10-02-2013)
Old 10-02-2013, 02:48 AM   #54
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Morning guys
Just to answer some of the questions in the thread:
Is it only the Beta version that will interface the BRZ or will the release candidate 2 out currently work? Guess i need to dust off the OP2.0 again.
Ecuflash will allow both the editing and flashing of the Roms onto the ECU, whilst RR is an editor, logger and more recently has learning view capability incorporated (though not yet for the BRZ, the logic will need to be reviewed to see if there are changes, and the Ram addresses identified). I already have a good deal of the extended (4 byte) parameters defined, still digging through the logic to fully define, since the structure of the SSM array table is different in these new roms.
On reading Ecutek roms - the ones I've seen seem to be locked / encrypted. And
Originally Posted by shiv@vishnu View Post
There is no "deciphering" of ecutek tunes. They use the same map addresses as the stock tune. And we read an ecutek rom using the standard read protocol used to read stock roms. We won't even bother trying to crack the ecutek security because, IMHO, it's not necessary or even worth doing given other (better) options.
echoes my sentiments exactly.
On the issue of the various CAL IDs, I've seen the SADM and USDM roms, and as soon as Colby releases the beta, I'll be able to pull a local (South African) rom, which is the EUDM version. From what I've heard, there are little differences between the territories (generally the US roms are more anal about emissions). In any case, once one rom is defined, it is pretty straightforward to define the others using a set of of templates that speed up the disassembly process. Colby has also mentioned that he will assist with software that he developed that will auto define most of the roms once the initial table template is set up, which will speed things along.
Since I was already stuck in, I thought I'd finally define all the Alpha parameters that I've pulled out over the past 1-2 years. I've been avoiding it since it's tedious work and time is constrained - especially when it's for over a hundred tables and parameters
I've defined about 70 odd 'new' tables for the BRZ, of which ~30 are specific to DI, the other 40 are previously defined 'Alpha' parameters, a lot of which were identified through COBB's implementation on the forced induction platforms (I've never denied that ).
There are still quite a few new tables to be incorporated into the definition, just need to find the time - hot restart, knock sensitivity, idle throttle, the remainder of the tau tables (transient fueling) to name a few (and I need to also trawl the logic to see whether others exist, like cruise/non-cruise map blending).
Once we have a fairly comprehensive solution going, I intend to work with Merp (if he has the time) to see if we can port his work to the BRZ platform (FFS, LC, map switching, Knock CEL flash, High EGT CEL flash, amongst a host of others). Otherwise, I need to start boning up on C## and the Renesas HEW environment...
Td-d is offline   Reply With Quote
The Following 10 Users Say Thank You to Td-d For This Useful Post:
calispec (10-02-2013), coyote (10-02-2013), FrX (10-02-2013), jamesm (10-02-2013), JouMaSeHoes (10-02-2013), King Tut (10-02-2013), Ralph Spoilsport (10-02-2013), Sportsguy83 (10-02-2013), vgi (10-02-2013), Wepeel (10-02-2013)
Old 10-02-2013, 02:54 AM   #55
Td-d
One other thing - the picture of the timing table posted using the first definition needs to be replaced with one from the latest definitions (since the first iteration inherited the scaling from the existing roms, which is different (to be precise, the old scaling is (x*.3515625)-20, whereas the BRZs use (x*.3515625)-30 - hence the timing tables are 10* overstated).
Just before we start a whole thread about how open source is prone to errors, and the superiority of closed platforms (trolololol...)
The Following User Says Thank You to Td-d For This Useful Post:
Old 10-02-2013, 03:21 AM   #56
mswhong
Is this open-source software? Like BRZEdit? I'm a bit new to the tuning industry.. never heard of the mentioned companies
mswhong is offline   Reply With Quote
Close iJason Member's Car Journals 1 08-04-2013 08:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 02:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 01:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 09:40 AM
