#43 | |
Two grades lower than the manual recommends with heavy track session don't seem like a good combination. You're basically running a 30 weight oil in your engine for the track with great results, but you went the opposite direction with the tranny oil ?
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#44 |
In Test:Oil Fed SC
Drives: Vortech Prototype Test Car
What's two grades lower?
#45 |
Pentosin is an 80w, the owners book says 90w, in between is an 85w.
Generally the harder you drive (ie track) the higher the temp of the gearbox. Oil decreases in viscosity with temperature.
#46 |
Drives: Altezza RS200-Z 6MT
I'd be running an Ester gear oil if I was seeing track time especially with additional power going through the box. What's the Pentosin MTF2 shearing back to? It's only 7.7 cSt @ 100°C where as say Gear300 is 15.2 cSt.
The 86 race series here in NZ are trialing Motul Transoil Expert 10w40 in the box http://www.motul.com/system/product_...pdf?1290086773 Last edited by SXE10; 10-04-2013 at 12:17 AM. |
| Pentosin MTF2 | Calum | Engine, Exhaust, Transmission | 10 | 12-09-2014 07:43 PM |
| FS: Zeta air tube, hks drop in, & Pentosin | chappys4life | Mid-Atlantic | 14 | 05-24-2013 12:58 PM |
| Pentosin mtf2 and approaching hot climate | bdanisi | Engine, Exhaust, Transmission | 1 | 04-20-2013 10:48 AM |
| Looking for Pentosin MTF-2 in Ontario? | wtout86 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 12-26-2012 07:07 PM |
| redline | kendalldwhite | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 08-26-2012 02:12 PM |
