Old 08-29-2020, 12:10 AM   #43
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by ShadowReaper View Post
2 year revival.
How good of a seal is this afterwards. I'm not sure of the material in the headlight but if you need to bake something, what is the material that is being softened, and inevitably expanding. How does it go back to normal fitment, please don't say "it just stiffens back up to original fitment"
it's butyl rubber. it's got a low melting point around, and it's tackier than gum on your good shoes. so yeah, if it's warm, it generally goes back together just as well has it was before.
Old 08-29-2020, 06:11 PM   #44
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
Ok. Did you still have to add any new sealant after disassembling?
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 08-30-2020, 12:30 AM   #45
soundman98
soundman98's Avatar
the most common method involves using a flat blade screwdriver or a putty knife to pry the halves apart. if very little ends up on the screwdriver/putty knife, no. but if you end up with more butyl than screwdriver once the two halves are apart, then yes.
ShadowReaper (09-03-2020)
Old 08-31-2020, 07:16 PM   #46
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Can confirm this. I've opened mine up 4 times now, and never needed new sealant. Never needed to pry them apart, just some oven mitts and a little patience.
All I do when I pull the halves apart is once it's getting stringy between the two sides, I pass a razor blade through to cut them nicely and I guide the cut stringed out sections back into the groove. A little patience and pre-planning goes a long way in retaining a good seal.
sharpsicle is offline   Reply With Quote
The Following 2 Users Say Thank You to sharpsicle For This Useful Post:
ShadowReaper (09-03-2020), soundman98 (08-31-2020)
Anyone North Teas know how to Black out Headlight J-Money Southwest 2 02-05-2013 06:08 PM
Another headlight black out, with a twist. Hardrock4445 Cosmetic Modification (Interior/Exterior/Lighting) 32 01-16-2013 04:26 PM
FS [SYD] - Modelista front headlight eyeliners in black eleu2166 Australia Classifieds 9 11-05-2012 08:07 AM
And yet another Black headlight, different still FastLane1000 Cosmetic Modification (Interior/Exterior/Lighting) 23 10-29-2012 01:31 PM
Another black headlight, a little different Vonsamhain Cosmetic Modification (Interior/Exterior/Lighting) 26 10-18-2012 11:10 AM
