Old 05-06-2014, 08:05 AM   #43
diss7
Drives: AE86, 2x GT86, TE27
Thread specific about regional issue would be better placed in regional forum.
diss7 is offline   Reply With Quote
Old 05-06-2014, 09:21 AM   #44
Lavalover
Drives: 2014 FR-S Monogram Hot Lava
An article in DSport magazine a couple months ago mentioned that the Innovate SC is now CARB legal.
Lavalover is offline   Reply With Quote
Old 05-06-2014, 09:23 PM   #45
Marco_86
Drives: 14' Frs Raven
Originally Posted by Kostamojen View Post
Care to be more specific?
Which exhaust, are you including headers, etc.?
Also, this thread was made for CARB legal specific items. I totally forgot about it though... Any new CARB stuff out there?
Their axle back and high flow cat package
Marco_86 is offline   Reply With Quote
Old 05-06-2014, 09:37 PM   #46
Haeb
Haeb's Avatar
Drives: 2014 Scion FR-S Monogram Series
Originally Posted by Team STILLEN View Post
The headers for Honda's back in the 90's were CARB Legal because most of them were Pre-Cat headers. The real challenge with headers for the FRS/BRZ being CARB legal is the position of the stock Cat. Since it is welded to the stock headers and not bolted on I think we are SOL without welding in a new 50 State Legal Cat.
Does the 6 year no smog rule apply to everyone in the US or just California? I'm curious to see how the California cars that have removed the secondary cat are effected when they go to smog their car.
If theres a missing catalyst in CA its going to fail the test - visual failure. Underhood label will indicate number of cats and thats what the smog tech is going to be looking for. Any sign of welding throws up a big red flag as well.
Haeb is offline   Reply With Quote
Old 05-06-2014, 09:42 PM   #47
Haeb
Haeb's Avatar
Originally Posted by Chee-Hu View Post
For the FRS, yes. But is it the same for the BRZ seeing that they are technically the same cars?
If the executive order specifically says Scion FRS, and its on a BRZ.... it will technically fail. This would depend on the tech, his knowledge of the car, and his or her willingness to take the risk that its not an undercover car. That's exactly the kind of thing the B.A.R. does to try and catch shops doing illegal, or improper smogs - send a BRZ through with an FRS EO. We all know the car is same/same, but to the B.A.R. two separate makes and models.
Old 05-06-2014, 09:51 PM   #48
Haeb
Haeb's Avatar
The actual executive order only lists the FRS.
If this is the EO for a part and that part is on a BRZ, most, and I have to say most because SOME will ignore it, but MOST smog stations would fail the vehicle. And being purely technical about it ...ALL should technically fail it. When it comes to executive orders everything must match - year, make, model, engine size, and if its listed engine family. We've failed many a car with an aftermarket catalyst that had an EO that matched year make model and engine size, but had the wrong engine family listed - so mostly right just wont do. The both the shop and techs licenses are on the line if its a BAR car
The Following User Says Thank You to Haeb For This Useful Post:
8R6 (04-22-2015)
Old 05-06-2014, 09:53 PM   #49
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
The highflow cat is not legal.
Kostamojen is offline   Reply With Quote
Old 05-06-2014, 09:56 PM   #50
Haeb
Haeb's Avatar
Originally Posted by rainmonkey View Post
This is probably a really dumb question, but if they see the sticker, do they actually run the numbers/code that's on it?
What's to stop someone from just... putting the sticker/stamp on another part?
I cant speak for every shop, but here, as soon as my tech spots a EO sticker he notes the number and brings it to me. I look up the EO and verify it applies to that specific vehicle. And the part itself had best have the manufacturer and part number listed, as both are critical. If we have an EO and an unidentifiable part - it fails. If the car has many aftermarket parts with stickers all over the place, its coming off the rack and someone (me for a fee) or the customer is gonna have to come up with EO's for every piece - and even then the cost of the test is gonna go up
Old 05-06-2014, 10:06 PM   #51
Haeb
Haeb's Avatar
Originally Posted by cnk View Post
I would think nothing could stop you from doing that, but if they did catch you, then I'm sure there would be some hefty penalties.
No penalties to the consumer....other than the car will fail the inspection and the part in question will have to be replaced with a legal replacement. The penalty would be if lets say the incorrect catalyst was welded on - and the correct catalyst was only available from the dealer...and it costs say $1000. In that case your out the $400 or so dollars for the wrong cat that ya put on....AND ya still have to buy and install the correct catalyst..... so your out $1400 to get the car through the test. And again...if your a smog station and the BAR runs a car through with an incorrect cat (or any other part for that matter) and the tech passes it...the tech and the shop are getting fined and losing part of their license potentially.
8R6 (04-22-2015)
Old 01-13-2015, 11:02 PM   #52
Drakelee117
Drives: Subaru BRZ 2015
Anyone knows if the Borla Catback and Perrin Non-Resonated are CARB legal? And what about the Koyo Radiator and A&N drop in filter? These are just some ideas for my first mods. Maybe going SC in the future, pretty sure vortech is CARB legal now.
Drakelee117 is offline   Reply With Quote
Old 01-13-2015, 11:46 PM   #53
Kostamojen
Catbacks, radiators and air filters are legal as far as I know. There might be noise restrictions for the exhaust in certain counties/cities though.
Old 01-14-2015, 10:40 AM   #54
Drakelee117
Perrin's catback might be one of the quietest out there as far as I understand? Might be necessary to check the borla ones?
Old 04-21-2015, 04:53 AM   #55
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
Just bumping this since I just found out that my CARB Pending Injen intake isn't actually CARB Pending.
AFAIK The only CARB Legal Intakes are:
AEM
TRD (FRS Only)
K&N (2013 & 2014 ONLY) http://www.knfilters.com/search/appl...prod=69-8619TS
It's not like it isn't possible to get a number for our car. It's pretty disappointing for such a large market we have such limited options, especially since Arizona, Connecticut, District of Columbia, Maine, Maryland, Massachusetts, New Jersey, New Mexico, New York, Oregon, Pennsylvania, Rhode Island, Vermont, and Washington have all adapted California emission standards and all will now require a CARB E.O. number on parts.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
The Following User Says Thank You to Hyper4mance2k For This Useful Post:
Bonburner (04-30-2015)
Old 04-21-2015, 11:53 AM   #56
churchx
churchx's Avatar
Drives: 2014 GT86
Wild guess .. depending on how thorough tests are .. how do you guys think - can catless header + custom frontpipe with 2 cats slip through for less thorough checks, that simply will look up how much cats car should have without inquiring where exactly they are mounted?
Imho if it MAY slip through 85% cases, it's good enough. For those less lucky 15% there is option of bolting back stock one.
I have no clue how really tests are performed and how thorough they are over in CA though, hence just an mad idea. But if it will work .. replacing just frontpipe should be easier then regular remounting of headers, no?
For lulz. If catback is legal, so do probably this.
Recent Thread List Anthony Site Announcements / Questions / Issues 0 07-21-2013 11:24 AM
Any of the FI kits CARB approved yet? RYU Forced Induction 27 05-05-2013 11:51 PM
Carb legal intakes EN2_Squirrel Engine, Exhaust, Transmission 2 04-18-2013 06:59 PM
Parts.com = Master Limited BRZ > FR-S Thread? dkenne2586 Cosmetic Modification (Interior/Exterior/Lighting) 1 03-12-2013 01:44 AM
B2autodesigns Master exhaust thread. Invidia,Takeda, Berk, Magnaflow and more b2autodesigns Engine, Exhaust, Bolt-Ons 29 01-02-2013 11:44 AM
