Old 08-22-2013, 01:36 PM   #43
OrbitalEllipses
Drives: Attitude
Originally Posted by Hanakuso View Post
My Hawk HPS are very comparable to stock. I might actually switch back to those since my DS2500 are hard to stop squealing since I never bedded them in properly. It's pretty easy to modulate the squealing tho.
On the other hand my AP Racing C300 squeal like crazy
Perhaps it's because I have the AP Racing England kit, but my DS2500 don't squeal much (rear) and my S100 only (front) squeal on low-speed stops. Perhaps I was able to get more heat in them as my caliper isn't race designed.
Old 08-22-2013, 01:50 PM   #44
DS2500 seems to squeal for everyone that has the AP Racing kit...
@D1cker and @ImperiousRex's experience mirrors yours, i believe, as far as DS2500 goes.
Old 08-22-2013, 02:13 PM   #45
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
So does getting a " bbk " or anything bigger than stock help with coming to a stop sooner? Or is getting a bbk along with drilled/slotted rotors just to dissipate heat? I feel like tires and weight play more of a role than brakes do in stopping a car.
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
Tansey86 is offline   Reply With Quote
The Following User Says Thank You to Tansey86 For This Useful Post:
Anthony (08-22-2013)
Old 08-22-2013, 02:15 PM   #46
Tires are the single biggest factor. It's the only part of the car that touches the ground, and even the cheapest, oldest car on the road can still lock up the tires, meaning there is more braking force available in that stock braking system, than the tires have grip.
The purpose of the BBK is to reduce unsprung weight, lower long term operating cost, and generally look badass.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Anthony (08-22-2013), Anthonytpt (11-01-2013), bryanttttttta (08-20-2014)
Old 08-22-2013, 02:18 PM   #47
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
...and generally look badass.
The only reason I'm here.
function < form < FORM OF LOOKING BADASS
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
The Following 2 Users Say Thank You to Anthony For This Useful Post:
juliog (09-29-2014), OICU812 (08-23-2013)
Old 08-22-2013, 02:21 PM   #48
Anthony
Weight Nazi
Anthony's Avatar
Oh, and I finally got to watch this video. Good stuff, @Dezoris. I laughed. I cried. I subscribed on YouTube.
I appreciate the character development in all of your videos, and the addition of the Indian mechanic is a nice touch.
Old 08-22-2013, 02:21 PM   #49
Hanakuso
I always thought this kit and many other BBKs #1 priority is to handle more heat, so you can consistently brake without fade or other heat related problems.
Hanakuso is offline   Reply With Quote
Old 08-22-2013, 02:27 PM   #50
That too... sorta falls under "lower long term operating cost", sorta, but I should have clarified. oops. I need more coffee.
Old 08-23-2013, 10:40 PM   #51
JiB
JiB's Avatar
Drives: GT86
great vid as always!
JiB is offline   Reply With Quote
Old 08-24-2013, 06:18 PM   #52
Nhil
Drives: 2013 Scion FRS
Great video and info. Are you running the 17x7 RPF1's?
Nhil is offline   Reply With Quote
Old 09-27-2014, 08:35 PM   #53
noob and expert
Drives: None :(
but they dont make this kit for the back. what do you put in the back? arent you messing up the brake bias by doing this? isnt there performance left on the table too? should an ap racing factory kit go in the back??
??? is offline   Reply With Quote
Old 09-27-2014, 10:54 PM   #54
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Did you not read the product details on the Essex website? This kit is designed for this car, and to be used with stock rear brakes, therefore it maintains the brake bias.
Speaking of which, I believe brake bias can be messed up even without a BBK. Simply fitting the wrong combo of front/rear pads on factory calipers can alter the brake bias...
Fizz is offline   Reply With Quote
Old 09-27-2014, 11:37 PM   #55
noob and expert
Drives: None :(
I skimmed through it I've been reading more on the forums but thanks for pointing that out and yeah your right about messing up the bias with the pad combination
For me, there is no glide in pulse and glide :p
Old 09-28-2014, 03:36 PM   #56
Dezoris
Dezoris's Avatar
The AP kit is probably the most tested on the Forums from track users. Its pretty consistent in terms of performance and it definately responds best with the same pad compound at all four corners like oem.
I dont think anyone has had issues with bias. But one thing that the drivers of my car dont like is that the brakes are very very firm like on and off switch hard to modulate with agressive pad compounds.
The Following User Says Thank You to Dezoris For This Useful Post:
??? (09-29-2014)
SARD Racing Japan seat cover install & review CrazyWookiee Cosmetic Modification (Interior/Exterior/Lighting) 136 09-22-2017 05:58 PM
Cool install Kido RAcing Coilovers/Brake kit on FT86,10%off.. Tubano-shop Brakes, Suspension, Chassis 0 06-05-2013 12:53 AM
Essex Sprint brake kit--Strano Performance will be carrying them... Sam Strano Brakes, Suspension, Chassis 13 10-08-2012 02:47 PM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 02:32 PM
