| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#43 | |
Drives: AE86, 2x GT86, TE27
In NZ and Japan, the RC spec cars have no air con. They have a pulley in its place. Garage88 in Australia brought a few and sell them. Could also get through toyota Nz. I'll get you a part number, heck I might even get you a price. |
#44 | |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
#45 | |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
#46 |
When In Doubt...
Drives: Slowww
Agreed. My 91 MR2 weighed about the same as my BRZ. That thing was a properly dangerous two seater with a single airbag for the driver. I can't believe they pulled this weight off for a modern car without it costing more than it does. 200hp is not much for the price but 2700 pounds is, as you said, incredible, for this price tag.
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#47 |
Drives: ‘13 FRS
Get AAA and throw out the spare tire and jack. Find some nice 14-16lb wheels and replace the stock 20lb wheels. Get a lighter battery.
That's all I would do. When you start messing with body panels, the weight savings are likely to be offset by poor build quality and fitment. Not to mention you'll risk looking like THAT 18yo kid with the Krylon Black civic with body panels flapping in the wind on the freeway. :-) But that's just my opinion. New modified cars can look BEAUTIFUL if done right. I don't have the money or the talent to do it right, so I'm sticking to small mods. :-) |
| The Following User Says Thank You to NWFRS For This Useful Post: | Laika (10-27-2013) |
#48 | |
Drives: WR Blue BRZ, 240Z
And if you're thinking "I'll just move the battery to the rear of the vehicle", you'll be adding weight do the the weight of the cables. Loosing weight strategically is a like solving a puzzle.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#49 |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
if you lose 20-25 lbs off the front with a lighter battery and then remove the spare tire and jack for 25-30 lbs off the back, the weight distribution doesn't hardly change
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
| The Following User Says Thank You to Miniata For This Useful Post: | SirBrass (12-05-2013) |
#50 |
Add lightness!
Drives: 17' WRX
It's pretty easy to lose weight off the front too. Headers (~12), wheels/tires, (~10), brakes (~20), battery (~20), flywheel/clutch (~12) and an empty windshield wiper tank (~5). That's around 80 pounds off the front(ish). Get's a little tricky after that. Some of that weight is low or rear of the axle though so it doesn't exactly count as front or as significant in the dynamics of it all. The rear seat is in front of the axle though and that weighs a fair chunk with all it's mounting hardware.
I think you could remove a well balanced 150 pounds from the car easily. |
#51 |
Anorexic
Drives: 2003 Honda S2000 Suzuka Blue
#52 |
Anorexic
#53 |
Weight Nazi
Indirectly from diss7:
| The Following 2 Users Say Thank You to Anthony For This Useful Post: | diss7 (12-08-2013), PoorMansRacing (12-05-2013) |
#54 |
Drives: Suburu BRZ Limited, black
I'd just like to comment that you really don't need new brakes or pads after you make the car 50kg's lighter, not at least until you get much better grip with wider race tires. The brakes as they are now can easily hit the ABS in ideal dry conditions which is the absolute limit on braking capability for the entire car as a system. If you lose 50 kg's you're making the car easier to stop on the stock brakes. I'd suggest wheels and tires first and then a track day to properly heat them up and then test the ABS... or if you're a better driver than 90% of us forum goer's, pull the ABS fuse and try and lock them up. With good tires, and a light weight car, it's actually harder than you think.
#55 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
You want weight loss crazy, Miata guys are them. Hell, check out a miata autox forum and see how creative those guys get. Its insane.
#56 | |
Trust me, I'm the Doctor
There's not much I'd do for weight reduction, though. 53/47 is actually a darn fine balance. Low CoG is actually even more important, I'd say.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
| Tags |
| weightloss, you're all too fat! |
| Weight Loss Potential Thread | Entropy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 79 | 01-16-2017 05:51 PM |
| ≥≥≥ WEIGHT LOSS PROGRAM ≤≤≤ Lightweight battery kit. New Years Resolution Complete!!! | FT-86 SpeedFactory | Brakes, Suspension, Chassis | 52 | 05-27-2013 12:19 AM |
| CEL, Loss of Traction Light, Loss of Power | pituala | Issues | Warranty | Recalls / TSB | 19 | 09-05-2012 12:23 PM |
| Weight loss potential? | SevenTenSplit | Engine, Exhaust, Transmission | 10 | 12-10-2011 03:16 PM |
| weight loss | cynic | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 10-24-2011 05:04 AM |
