Old 03-17-2012, 04:46 PM   #43
Linseal
Linseal's Avatar
Drives: Argento MT Scion FR-S
I'm hoping for an aftermarket Scion logo, like the one the original concept car had above the plate!
Name:  Screen shot 2012-03-17 at 3.43.23 PM.png
Name:  Screen shot 2012-03-17 at 3.43.05 PM.png
Linseal is offline   Reply With Quote
Old 03-17-2012, 04:47 PM   #44
dsgerbc
Drives: BRZ(sold), STI
Can go into depth... but gonna keep it simple:
Wide wheels & tires = more traction.
Wide wheel does not mean more traction. To a first approximation the size of contact patch is the same (for the same tire pressure) and determined by car weight. Wider wheels mostly change the shape of the contact patch. To a second approximation, wider wheels will have a slighter larger tire patch, since the sidewalls could carry slightly less load (again, for the same sidewall stiffness).
dsgerbc is offline   Reply With Quote
Old 03-17-2012, 04:51 PM   #45
ahausheer
Re-member
Drives: Toyota camry
I'm pretty sure wider wheels in general means more traction, all else being equal.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 03-17-2012, 05:07 PM   #46
FRSDREAMER
FRSDREAMER's Avatar
Drives: 2013 FRS (hopefully)
Originally Posted by JDMike View Post
i hope the scion gets a digital climate control option.
Sorry Man, but that is not happening.
FRSDREAMER is offline   Reply With Quote
Old 03-17-2012, 05:20 PM   #47
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Make that whole paragraph into 7 words = ?
Old 03-17-2012, 05:20 PM   #48
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Attachment 5567
Attachment 5568
ಠ_ಠ
Snoopyalien24 is offline   Reply With Quote
Old 03-17-2012, 05:27 PM   #49
korinfox
Drives: Lexus IS300 Sportcross
Basically this:
Skinny tires are good for grip in a straight line. Wide tires are good for grip in corners. If you stagger the tires, (bigger in rear) the car will have more understeer, and be less neutral.
korinfox is offline   Reply With Quote
Old 03-17-2012, 05:27 PM   #50
dsgerbc
All else is never equal. If you take the same make/model of the tire, and one is wider, the deformation stress on the tire will already be different.
Typically going wider lets you use softer compound with less stress on it. And it's the softer compound that gives you better traction, not the shape of contact patch.
Old 03-17-2012, 05:31 PM   #51
ichitaka05
Site Moderator
ichitaka05's Avatar
Typically going wider let's you use softer compound with less stress on it. And it's the softer compound that gives you better traction, not the shape of contact patch.
so make it simple, better traction... which pretty much I have stated.
Old 03-17-2012, 05:44 PM   #52
dsgerbc
so make it simple
Make it simple - want more traction = buy softer-compound tires.
If you buy just wider tires, with the same or harder compound - you'll just alter the balance, w/o getting more grip.
Old 03-17-2012, 05:49 PM   #53
ichitaka05
Site Moderator
ichitaka05's Avatar
That's not the question he was asking, did he?
Old 03-17-2012, 05:50 PM   #54
ahausheer
Re-member
Ok but still what is that box like structure between the resonator and cat? Perhaps an easy way to alter the sound similar to the mustang boss?
Old 03-17-2012, 05:52 PM   #55
J MaM 86
Automotive Technician
J MaM 86's Avatar
Drives: AE92 GTS & Asphalt FR-S 6MT
I know for certain that wider tires reduce wheel hop. Reducing wheel hop would help prevent in loss of power during acceleration and save your diff.
J MaM 86 is offline   Reply With Quote
Old 03-17-2012, 05:53 PM   #56
ichitaka05
Site Moderator
ichitaka05's Avatar
yup
2013 Scion Fr-S on the March Issue of MotorTrend KevinDuMa Scion FR-S / Toyota 86 GT86 General Forum 45 03-12-2012 06:25 AM
2013 Subaru BRZ and 2013 Scion FR-S: A Study in Comparison and Contrast Zgrinch Scion FR-S / Toyota 86 GT86 General Forum 124 02-21-2012 02:43 AM
2013 SCION FR-S Safety Audi Scion FR-S / Toyota 86 GT86 General Forum 14 01-17-2012 08:29 PM
2013 Scion FR-S: 10 Things You Don't Know (Maybe) - Insideline rmagic Scion FR-S / Toyota 86 GT86 General Forum 56 12-15-2011 05:36 PM
