View Poll Results: What fuel do you use
91-93 with up to 10% ethanol 184 69.43%
91-93 non-ethanol 67 25.28%
93+ racing fuel 5 1.89%
E85 11 4.15%
Other 9 3.40%
Multiple Choice Poll. Voters: 265. You may not vote on this poll
Old 07-22-2013, 03:17 PM   #43
strat61caster
strat61caster's Avatar
Originally Posted by Scionshaun View Post
I meant to say, what is the lowest grade can we use. Will there be a major difference if we use a lower grade?
You can theoretically use the lowest grade available, 87. The engine should compensate for the fuel by reducing the timing to prevent knock. Again, theoretically there would be no ill effects other than a loss of power (and subsequent loss in efficiency (lower mpg)) and the engine not sounding as good (you may even hear a knock or two) but what you're doing is putting in a fuel the engine wasn't designed for and over the long term (1000+ miles) you'll be putting stress on the engine (due to knock) that could result in premature failure.
That is for this car, a modern vehicle with a modern ECU tuned from the factory. Once you step outside of that you open yourself up to more trouble.
Use the higher grade, spend the extra $2 per fill up and grab a reusable bottle of water from home instead of a coke. Double benefit to your mpg there
ineedyourdiddly
WolfpackS2k (07-23-2013)
Old 07-22-2013, 03:54 PM   #44
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Drives: '13 Whiteout FRS
I read somewhere that it doesnt matter what brand you get as long as its the same rating its the same fuel for example; chevron 91, shell 91, and thrifty 91....does anybody know the difference between brands??? and proof??? And another question is there a reason why pretty much 91 is the highest rating available in California yet other states get 93 and other choices???
CAMBAM_6 is offline   Reply With Quote
Old 07-22-2013, 04:25 PM   #45
NedVargar
Drives: 2013 Scion FR-S Firestorm
Originally Posted by OnkelC View Post
it's called "Super+" here, 98 octane and up fuel. the two bigger fuel chains, Aral and Shell, have 102 and 100 octane fuels on tap, I usually go for the Aral stuff with 102 octane.
Holy crap!!
NedVargar is offline   Reply With Quote
Old 07-22-2013, 04:30 PM   #46
NedVargar
I was switching between BP 92 and Costco 91 with E10. Started noticing crickets with the ethanol and they went away with pure gas. Got the fuel pump replaced anyway, went back to E10 Costco, and the crickets came back after about 5k miles. Switched back to pure gas and no more crickets (still going to complain on my next checkup to get a record of it).
Old 07-23-2013, 10:57 AM   #47
Realm
Drives: Scion FR-S
Only reason I buy ethanol free is to get rid of the crickets... I've switched a few time (cost) and the crickets come back within 20 miles using ethanol. Had the pump replaced once, they still came back.... soo it's non ethanol for me from now on
Realm is offline   Reply With Quote
Old 07-23-2013, 11:46 AM   #48
strat61caster
Originally Posted by NedVargar View Post
Holy crap!!
They rate their octane differently, 98 RON = 93 AKI roughly.
I've seen stations with 100 AKI which is "better" than what he posted.
ineedyourdiddly
NedVargar (07-23-2013)
Old 07-23-2013, 01:48 PM   #49
Diode Dynamics
Diode Dynamics's Avatar
Originally Posted by Dezoris View Post
93 Shell w/corn
93 Mobile w/corn
Quit BP after they destroyed the gulf.
BP gave out $1 billion to help the people affected, at least they tried to remedy the situation.
-Nick C.
John C.
Diode Dynamics
The Following User Says Thank You to Diode Dynamics For This Useful Post:
Old 07-23-2013, 02:29 PM   #50
Dezoris
Dezoris's Avatar
-Nick C.
People have short memories. Much like the disaster in Japan, caused by cutting corners and negligence. Eventually these types of corporate mistakes won't be remedied by $$$. Zero excuse for any of it.
Old 07-23-2013, 02:39 PM   #51
Twinguin
The 86 is gone.
Twinguin's Avatar
Drives: a Pony*& a HotHatch & a Cabriault
it's called "Super+" here, 98 octane and up fuel. ... I usually go for the Aral stuff with 102 octane.
Same here: same stuff & same brand :-) Must be the area.
"There is a curse. They say: May you live in interesting times!", Terry Pratchett
Twinguin is offline   Reply With Quote
Old 07-23-2013, 03:28 PM   #52
Diode Dynamics
Plus Castrol makes the best oil in the world, and that's a fact!
Royal Purple finished dead last in a recent test btw
-Nick C.
John C.
Diode Dynamics
Old 07-23-2013, 03:55 PM   #53
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
I've heard that the gasoline is that goes to the stations can be whatever random stuff. But that each different brand (shell, chevron, etc) adds their own special type of detergents and additives. I would imagine with 87 or 89 octane the difference is quite minor. Biggest difference would be 91/93 (whatever the top fuel available is for the area)
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R
WolfpackS2k is offline   Reply With Quote
Old 07-23-2013, 03:56 PM   #54
WolfpackS2k
Did you guys read this whole thread? Octane ratings in Europe are calculated differently. You're not getting a higher octane fuel than us Yanks
Old 07-23-2013, 04:41 PM   #55
Twinguin
The 86 is gone.
Twinguin's Avatar
Uncle (Onkel) might not have, as he answered first, but I did. And yes we do know the octane rating uses different values. Anyway, what we wanted to say, is that we do use the highest octane available here (Aral Ultimate w/ 102RON) and that matches the US93+ rating (94AKI to be precise).
Old 07-23-2013, 05:34 PM   #56
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Yeah i cant remember the source but i remember reading that all the "name brand" places such as shell and chevron get there fuel from the same exact source. I understand they use there own "special ingredients" but i wonder how different they really are. You know were lied to about everything else in this country, so i wonder if one really would be better or safer then the other???
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
FuelLog (Android) App:~10k miles of MPG, Range, Fuel Prices, Fuel Qty, Etc. MmmDieselFumes Scion FR-S / Toyota 86 GT86 General Forum 28 02-02-2014 08:19 PM
Poll: What color did you buy DBacon1052 Scion FR-S / Toyota 86 GT86 General Forum 64 09-05-2013 04:19 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
