KR-S, MisterSheep, Tcoat
Old 05-15-2013, 08:17 PM   #43
Calum
That Guy
Drives: 2013 asphalt FRS MT
Why does the famous K20 make such great NA power? It's because of the headflow and great combustion chambers.
The FA20 has been shown to have outstanding resistance to knock even at 12.5:1 compression, so the combustion chambers are certainly there.
We haven't seen anyone post up cam specs let alone head flow numbers. After some earlier posts from Nameless I'm led to believe that the exhaust valves are not equal distances from the port opening which will cause internal reversion issues. That isn't very confidence inspiring, but we'll see how they deal with it. Only time will tell in the end.
Given that we've seen companies running 20 pounds of boost on stock bottom end without knock issues, I'm surprised nobody is talking about upping the compression.
Old 05-15-2013, 08:19 PM   #44
Calum
That Guy
Originally Posted by Kodename47 View Post
With an I4 engine its much easier to make the power. Intake manifolds are simpler due to a more configurable runner length and plenum size, only 1 head to design/change, not 2. Also variable lift cams would make a huge difference, rather than just some can timing adjustment. Then the cams themselves could be improved.
Don't forget that Honda's are already designed to rev happier, which gives them a peak HP advantage. If you look at what the stock K20 is doing at 6900rpm, its not to dis-similar to the FA20
Excellent point, I'd love to see the difference is area under the curve for the two engines.
Old 05-15-2013, 08:24 PM   #45
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
I make 240whp on my oem block 1.8 b series Honda motor. I bet this fa20 has 260-300 in it when parts develop. All these intake and headers now are not the end all to be all. They well get better and better and with eventual cam development the same.
TouchMyHonda is offline   Reply With Quote
Old 05-15-2013, 08:37 PM   #46
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by kayoh View Post
I'm asking because countless sources says that this car needs at least 40+ more hp. I'm wondering if this amount of hp (or even more) is attainable without having to go SC/TC and if so what type of modifications and how much $$ would it take.
(btw thanks for such prompt responses)
as of today the gasoline limit is right around 185 - 195 whp with a slightly optomistic dyno. E85 is going to be 200 - 210 ish.
In the not so distant future, there will be intake manifolds and throttle bodies. I would think the IM's will offer 10 - possible 20whp.
Also, i would expect some new header designs or revisions of current designs with slightly better power.
Next comes the expensive stuff like cams, porting, head work, and the ability to rev deep. I would expect another 20 - 30whp once the motor can breath and not float the valves at 8000+ revs.
I would say 250whp NA should be doable in the next year or two.
Old 05-15-2013, 08:41 PM   #47
avg
Drives: BRZ Limited Manual
http://forums.nasioc.com/forums/show...6&postcount=11
avg is offline   Reply With Quote
The Following User Says Thank You to avg For This Useful Post:
mad_sb (05-15-2013)
Old 05-15-2013, 09:06 PM   #48
Allch Chcar
Drives: N/A
It's hard to sort through that thread, 80% of it is talking about a totally different engine -___-
Sorry, I forgot to mention that the first page is . The good stuff starts on page two.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 05-15-2013, 09:47 PM   #49
Turdinator
Señor Member
Turdinator's Avatar
There is a thread somewhere with the stock cam specs. They were around 255* total duration and 12mm lift.
The head flow will beinteresting. Again one of the vendors was talking about flowing the heads and the whole intake system but i haven't read anymore on that yet.
Incedently i wouldn't hold your breath on a stroker kit. I believe the FA20 has a sub optimal rod/stroke ratio already for packaging reasons. Increasing the stroke would just make that worse and kill any chance of keeping the engine reliable at higher revs.
1974 TA22 Celica
2013 86 GT
Old 05-15-2013, 09:55 PM   #50
Calum
That Guy
I thought those specs were educated guesses.
Old 05-15-2013, 10:31 PM   #51
Xdragonxb0i
Drives: ex500r
on a stock engine i dont think we would get more then 220WHP. That is being optimistic.
But we do get a 40WHP Bump With I/H/E+ Tune. stock ~160 to ~200whp
Xdragonxb0i is offline   Reply With Quote
Old 05-15-2013, 11:20 PM   #52
serialk11r
Drives: '06 AM V8V Coupe
Problem is bottom end of the K20 is designed for higher revs, they've got 15% longer rods, and Honda only thought it safe to bring the K20 to 8600rpm. The FA20 loses on breathing capability because of this and because of the heads (likely not the best flowing), so it's gotta make it up with efficiency, and while it's got the latest combustion system design on its side, that's a lot of air it's missing out on.
The Following 2 Users Say Thank You to serialk11r For This Useful Post:
ATL BRZ (05-16-2013), Calum (05-16-2013)
Old 05-15-2013, 11:50 PM   #53
mswhong
Originally Posted by Fenrir View Post
Watch Nameless Performance. They just picked up a second car for N/A development. ITBs, cams, the whole deal.
Could you please back that up with a link? That sounds way too good to be true! ITBs on a flat four.. now that is something that i'd want for sure!
mswhong is offline   Reply With Quote
Old 05-16-2013, 02:32 AM   #54
troek
troek's Avatar
Drives: 2012 Toyota 86
some cars in japan are dynoing up to 220 with bored throttle bodies and full exhaust mods on premium japanese gas. but most are 200-210. think the dynos here run optimistic?
Old 05-16-2013, 02:48 AM   #55
executivekoala
executivekoala's Avatar
Drives: fr-s
My take is that this is a brand new car. Most places don't have specs for the alignment yet so I don't really expect full list of mods to be out either. For Heads,ITB's,Manifolds and the like, take shit tons of R&D and $$$ to develop because they are such crucial parts and require so much into them to get right. It's not like an exhaust where developers battle about 2 hp differences. I think in a the next 2 years we will see tons more NA stuff, more throttle bodies, better tunes, and all the other good stuff, so I am just going to sit back save cash and wait.
executivekoala is offline   Reply With Quote
Old 05-16-2013, 03:02 AM   #56
Xdragonxb0i
Drives: ex500r
i heard the OEM Throttle Body is already pretty large
max, setup
Scion fr-s options and estimated release date. Fantum's86 Cosmetic Modification (Interior/Exterior/Lighting) 20 09-29-2012 04:09 PM
Scion fr-s options and estimated release date. Fantum's86 Hawaii 1 08-04-2012 06:18 AM
Capitol Subaru-estimated arrival 6/8 SuperSatinBrz BRZ First-Gen (2012+) — General Topics 78 06-07-2012 09:42 PM
Estimated HP gains - bolt on mods and reflash? ahausheer Engine, Exhaust, Transmission 207 01-14-2012 07:14 AM
Estimated Price.. SLeRoux92 Scion FR-S / Toyota 86 GT86 General Forum 44 05-25-2011 12:58 PM
