#43 |
Drives: 2014 WRB BRZ Limited
Whatever it's called, this mod is incredibly good. This + TRD Quickshift + clutch lowered to a hair above the brake pedal = perfect setup for this car. Every owner should do this mod.
#44 | |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Thanks for the tips. It only took 15mins! This may be the best 15mins of car work I've spent. I can tell where the clutch is engaging now instead of a guessing game of if the spring rotating is the clutch grabbing or if the clutch is actually grabbing. Only slightly heavier feel. Not to the level of a stonger aftermarket street clutch. I need to have everyone drive my car now to see how much different it is since I also just put in the TRD quick shifter, which shortened the throws drastically, much more than the much more expensive Kartboy shifter.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#45 | ||
Drives: 2013 BRZ Limited WRB
#46 |
After about a week with the spring out, I've gotten used to the barely any resistance at the top of the pedal feel. Think it was just strange at first because of how much resistance the first half an inch or so is in the stock pedal. I think that area with low resistance is where your clutch is completely disengaged. Could be wrong, though.
What do cars without the rotating spring do to keep the pedal firm up top? |
#47 | ||
Drives: '14 Monogram 6MT FR-S - Hot Lava
If it was hard right at the top, there'd either be pressure on the clutch at all times, or there would be no leeway for age, wear, etc. to happen which would lead to pressure on the clutch. Slack is a nessecary thing sometimes. It's the same deal with throttle cables. Sent from my PO-T4T0 with Eyes.
#48 |
Drives: BRZZZ
Hmm, I want to try this. But how hard would it be to reverse? In case I need to get back to stock or don't like the new clutch feel.
Sent from my LG-E980 using Tapatalk |
#49 |
Drives: 2015 VW GTI SE
The space is tight, it would be more difficult that it was to remove, but not impossible. I was hesitant because the first day I had it off I was in traffic and the pedal was so stiff that I almost reinstalled the spring, but now I love it.
The soft spot at the top of the clutch is normal. @Slysdexia covered it. Also, the master cylinder has a pin-hole that leads to the reservoir. With the clutch pedal up, the pin hole is open and fluid can equalize between the reservoir and the clutch lines. As you depress it, the pin hole closes and the line is able to pressurize itself. If it didn't have this "breather hole" to the reservoir, then as the clutch line warmed up the fluid would expand and your engagement point would change not to mention it would ride the clutch. Sent from my GS4 |
#50 | |
#51 |
Just the tip
Been two weeks without the spring and I'm happy to say I'm never going back!
#52 | |
#53 |
This thread should be stickied. Every single person with an 86 should be doing this.
#54 |
Drives: Asphalt Scion FR-S
After removing the spring, you can even try replacing the thin factory rubber clutch pedal travel stop with a thicker piece.
http://www.ft86club.com/forums/showthread.php?t=62137
#55 |
Drives: 2011 EB F150
I am glad so many of you have done this and enjoy the "natural" feel on the clutch!
#56 |
Drives: 2013 Subaru BRZ
Unlike some folks who have done this mod, I found that the hardest part was actually removing the pin at the top of the spring, holding it to the pedal assembly. I couldn't get the pin to budge with the clutch fully engaged (which is sort of expected), but there wasn't much room to pull it out with the clutch pedal fully pushed in.
In any case, once the pin came out, the spring assembly was easy to push out. And yes, what a difference. The first time I drove a BRZ, I almost ruled it out on the basis of the clutch feel, and it's easily been the most irritating part of the car since I've had it (with ~22,000 miles on it now), but it totally transforms the feel of it. I don't really notice it being much stiffer, it just feels far more natural in its engagement. |
| Tags |
| clutch helper spring, helper spring removal |
| Clutch engagement issue. Possible clutch cylinders upgrade? | wu_dot_com | Engine, Exhaust, Transmission | 42 | 04-05-2016 12:11 PM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 12:22 PM |
| Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 | Redline360 | Transmission and Driveline | 2 | 07-30-2012 10:01 AM |
| Clutch Masters Clutch Kits | Island Import Performance | IslandImportPerformance | Transmission and Driveline | 1 | 07-20-2012 12:06 PM |
