#43 |
Drives: 2023 Toyota GR 86 Cup
If your dealer keeps replacing the taillights they are doing it wrong. The problem isn't the taillights unless they've actually cracked...read the revised TSB...the dealer has to fix the bent taillight mounting points and install an updated gasket and updated retaining nuts.
If they do it "right" they won't leak again. Don't drill holes...
2023 GR Cup Car
#44 |
Member of the year - 2016
Drives: Scion FRS
Update:
After applying a second line of weather adhevise i now have the water back in my taillights. I will try to put both the aftermarket and OEM foam, if not then i'll go back to the dealership...
#45 |
Mechanical Guru
Drives: 2013 Scion FR-S (Argento) M/T
Anytime I get water in mine I just pull them out... they are held by 4 nuts... I pull the light bulbs out, put a hair dryer on it and the water evaporates out... I did discover that water pools around one of the plastic light bulbs which isn't sealed and I got water in that way... I took some putty-like material my dad gave me and wrapped it around the light and sealed it... I haven't had water in it ever since and it's been through several heavy storms as of late.
#46 |
Thupercharged
My condensation is gone after I drilled small (1.5mm) holes in the tail light.
I had fishbowl tail lights until I did this... after one day in the hot sun, all the condensation cleared up. I've done this on previous cars with great success and no problems. The amount of water that I got to drain out of the tail light was rediculous. When I get more time I may seal the hole back up with black RTV and try to seal the tails properly... but I don't see that happening
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#47 |
Hardworking
Drives: 2013 Subaru Brz, 2013 C300 4Matic
very well said
Lawyer in NJ and Pennsylvania.
My BRZ gets me to court quick! 2013 WRB BRZ Limited 2013 C300 4Matic Septa, NJtransit, MTA |
#48 |
Drives: GT86
Oh, but the OE lights also look like ricer lights escaped from the nineties. Full red aftermarkets like Toms and Crystal Eye look more behaved IMHO.
Anyhow, thanks for this thread, will be drilling a small hole at the bottom, seems like a more robust solution than trying to forever perfectly seal those taillights... |
#49 |
Drives: Subaru BRZ Limited
Clear Toms on a BRZ look like that's how it should've come from the factory. If you have problems with tail light condensation, I have a pair that have no condensation issues that I wouldn't mind selling.
#50 | |
Drives: 2013 FRS- Hot Lava
#51 |
Drives: 2013 FR-S, 2012 MCS
| Crystal Eye tailights are in! | deedz | Cosmetic Modification (Interior/Exterior/Lighting) | 79 | 06-07-2013 02:32 PM |
| Tinted Tailights | IceCreamMan | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 05-20-2013 05:39 PM |
| Tailights tinting? | imravenit | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 04-23-2013 08:54 PM |
| Toronto FR-S orders- Drill or no Drill on bumper | Dragon86 | CANADA | 35 | 10-12-2012 01:35 PM |
| Mysterious microscopic hole | Aznek | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 07-09-2012 08:22 PM |
