Old 05-15-2013, 01:50 AM   #43
suaveflooder
Originally Posted by Skurj View Post
Looks like you did an awesome job. This is what I would like to do but scared to death I'll f(*&& something up...
I did mine tonight. I was terrified!!!!!!! They turned out GREAT! Well worth the risk. Just go really slow and don't look for perfection! I have a couple fisheyes, but nothing that won't buff out. Gonna let the clear dry for a couple weeks, they polish them up. They already look factory and I haven't even cleaned them up yet
suaveflooder is offline   Reply With Quote
Old 05-15-2013, 04:24 AM   #44
tracerit
Drives: '13 SSM BRZ Limited 6MT
did you use the video or simple instructions posted earlier in the thread? any pics?
tracerit is offline   Reply With Quote
Old 05-15-2013, 10:45 AM   #45
ScottDRFT
Space Cowboy
ScottDRFT's Avatar
Drives: '13 BRZ SWP Ltd --> '24 Trueno Ed
These look great, I don't have any experience doing this but how are you guys polishing these? They look nice already!
ScottDRFT is offline   Reply With Quote
Old 05-15-2013, 11:53 AM   #46
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
looks great, but not sure if you prepped the lights before spraying or not but almost everyone i have seen diy has not. you really need to wetsand with 800 grit prior to spraying if you want good long term adhesion. there is almost no chemical bond adhesion and down the road that will more than likely show. wetsand with 800 grit should work well with the spray can method. i dry sand with 600 when i do them but im spraying real urethane apple candy and clear so the thickness and higher solids levels out the prep scratches instantly. not sure if spray can/ low solids would cover a dry 600 grit scratch.
Old 05-15-2013, 01:58 PM   #47
suaveflooder
I've painted the inside of lights a couple times before, so I wasn't new to doing this. First time doing the outside, so it was a little scary. Not perfect, but not bad.
Here's the link
http://www.ft86club.com/forums/showthread.php?t=36587
Wtb: frs tail lights Hindi Exterior Parts (Aero, Lighting, Etc.) 1 03-26-2013 10:41 AM
Anyone personally painted inside of tail light housings? BMHumanic Cosmetic Modification (Interior/Exterior/Lighting) 4 03-11-2013 12:44 AM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
Tail lights for the 86 Minovsky Cosmetic Modification (Interior/Exterior/Lighting) 29 02-06-2013 11:56 AM
painted tail lights now have condensation inside sitandspin Cosmetic Modification (Interior/Exterior/Lighting) 10 11-11-2012 11:12 PM
