Old 04-05-2013, 05:27 PM   #43
strat61caster
strat61caster's Avatar
Originally Posted by MVJ1975 View Post
You know, I wonder if that's not backwards - trac uses abs, vsc cuts power.
As I said above, I mostly run in VSC Sport mode, which shuts the traction control off, but leaves VSC on with a higher threshhold. When I get a little extreme, all that system does is cut power on me.
It's the brakes.
How would it cut power? It certainly isn't kicking in the clutch or changing how the torque converter is working so it would have to retard the timing in the engine or close the throttle on you; which doesn't help if only one wheel is breaking traction and would put you worse off than you already are.
Any form of vehicle stability is made up primarily of brake application.
[ame="http://en.wikipedia.org/wiki/Electronic_stability_control"]Electronic stability control - Wikipedia, the free encyclopedia[/ame]
I guess according to wiki it'll slow the engine down (likely for our cars closing the throttle since it's electronic) until you regain control but that isn't the primary method of "fixing" the problem.
ineedyourdiddly
Old 04-05-2013, 06:22 PM   #44
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
It's the brakes.
It's definitely slowing the engine down. I've got the accelerator depressed, but it isn't responding - the RPMs drop. If it applied the brakes, the RPMs would still climb as I have the gas pedal down.
It may be applying the brakes at the same time, but if it is, it's not doing so hard. I'd be able to detect it, and I'm not feeling any sort of mechanical braking.
MVJ1975 is offline   Reply With Quote
Old 04-05-2013, 07:25 PM   #45
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
From what I understand, it uses the EBD to brake at single corners to fight slip.
Nathan
SubieNate is offline   Reply With Quote
The Following User Says Thank You to SubieNate For This Useful Post:
MVJ1975 (04-05-2013)
Old 04-05-2013, 08:14 PM   #46
strat61caster
If the engine is directly connected to the wheels and the brakes are applied the engine speed (rpms) will drop regardless of throttle position.
Ever been in an underpowered car going up a hill? RPMs drop because the load on the engine is increased, same with applying the brakes or turning on the A/C.
If you've got an A/T this load may be dissipated in the torque converter not affecting the engine speed but still doesn't change the fact that traction control systems primarily rely on brake application rather than engine throttling and is the reason you are seeing the engine speed drop.
Edit: I see you do have an Auto, I would appreciate a test, next time you're slowing down in gear applying the brakes tell me if the engine speed drops.
ineedyourdiddly
Old 04-05-2013, 08:22 PM   #47
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Originally Posted by robo_robb View Post
I do this every time I drive the car. TCS/VSC is an impediment for the competent driver. Save for when you're experiencing severely inclement weather.
Please refrain from encouraging this kind of behavior. The best driver in the world cannot brake individual wheels like the aids do. Not to mention he or she cannot do it as fast as a computer can to prevent a spin. The electronics systems are capable of this.
raul is offline   Reply With Quote
The Following 2 Users Say Thank You to raul For This Useful Post:
leicaboss (01-13-2014), strat61caster (04-05-2013)
Old 04-07-2013, 03:26 AM   #48
polarstorm
polarstorm's Avatar
Drives: Scion FR-S
I was wondering what is the impact of all nannies on on fuel efficiency, vs,
Sport mode, vs,
VSC off.
I would guess with VSC off there is probably better fuel efficient since the system is not trying to preempt handling and therefore might be interfering with the power delivery to the wheels. This is my guess, does anyone know.
Of course the other side of the coin is that the driver would push the accel harder knowing vsc will take care of the rest, effectively using more fuel, but the wheels running only with what is 'stable'. But my question is more about the vsc system vs fuel efficiency and not driver behaviour. Thanks, as if there is a saving to be had, I will turn it off.
polarstorm is offline   Reply With Quote
Old 04-09-2013, 02:47 PM   #49
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
I would say in normal mode I feel sad.
In Sport mode I feel like I'm being teased, and probably more angry.
With trc off, I feel
I do not condone this behavior.
PERRIN_Chris is offline   Reply With Quote
The Following User Says Thank You to PERRIN_Chris For This Useful Post:
CoRi J (04-09-2013)
Vsc sport mode and trac off RWD-boxer Engine, Exhaust, Transmission 94 02-25-2020 10:23 PM
AT Sport Mode - What does it do exactly? karbon BRZ First-Gen (2012+) — General Topics 49 09-02-2014 03:40 AM
VSC Sport, Trac Off, Both Off - Which do you use for normal driving? pinoyplaya BRZ First-Gen (2012+) — General Topics 100 08-28-2012 03:24 AM
Delivery day. To sport mode or not? Oilers99 Scion FR-S / Toyota 86 GT86 General Forum 5 06-21-2012 07:50 AM
sport mode... pr086 Scion FR-S / Toyota 86 GT86 General Forum 6 06-01-2012 12:50 PM
