#43 | |
There is no sensor to tell the car which forward gear it is in...there would be no need for it. That information is calculated, just like MPG or DTE.
Ultramarine 2013 Scion FR-S 6MT
#44 | |
Drives: Firestorm 6MT Scion FR-S
![]() 2013 Firestorm 6MT Scion FR-S |
#45 |
Exactly. Because it's doing its best to calculate something long-term based off of immediate data, then projecting that out. That will never be as accurate as doing the math yourself using the actual miles driven and the actual fuel used.
#46 |
If the instantaneous readings are accurate, there's no reason the long term calculations should be off. It'd just be a simple summation. Let's say instant MPG is calculated once a second. Avg MPG would be the sum of all 1-second values divided by number of seconds since last reset. It looks like it does this about every 30 seconds. The reason MPG is off must be because the instantaneous values are off (or at least different than the ones pulled from the Torque OBDII app). My avg MPG is anywhere from 5-15% less than the car estimates.
Just another reason why calculations are dumb. Give me a sensor with real readouts any day.
| How to set the Shift Light & Gear Indicator Display Settings | EsoBOFH | DIY (Do-It-Yourself) Guides | 76 | 04-21-2020 09:42 PM |
| Rattle at idle when clutch engaged in netural | shu5892001 | Issues | Warranty | Recalls / TSB | 8 | 07-07-2018 09:03 PM |
| Special Deals on Clutch Masters Clutch & Flywheel Combo! | KronosPerformance | Transmission and Driveline | 15 | 08-25-2012 01:22 PM |
| Transmission rattle while revving in gear with clutch both engaged and disengaged | robo_robb | Engine, Exhaust, Transmission | 2 | 06-16-2012 02:35 AM |
