Old 04-08-2017, 11:04 PM   #43
silverlining
Just my DIYer 2 cents after attempting this with a DW265 in my garage, because I personally found the gasket/pump cap setup to be a pain in the ass to deal with but everything else seemed straightforward to me. Feel free to ignore:
1) After knocking off a couple ribs on the top of my fuel pump cap with punches I had Amazon same day deliver me a fuel pump spanner wrench. Mine claimed to be "one size fits all" but clearance around the BRZ' fuel pump cap is pretty poor, so I still put a dent in the sheet metal around the access panel with it. But at least it let me torque back to spec.
2) Run the fuel pump a few times and then check for leaks around the fuel pump cap. Most of the DIYer guides including the install guide for my DW265c just say "do everything in reverse" but following the service manual you'll quickly realize doing it right is more involved than that. I know this is probably going to be obvious to most people on the forum but leaking fuel out of your gas tank is super bad for you.
3) Read the SM entry for replacing the fuel filter a few times, and consider just getting the ST from a dealership.
silverlining is offline   Reply With Quote
The Following User Says Thank You to silverlining For This Useful Post:
kowalski (01-05-2018)
Old 04-19-2017, 06:34 PM   #44
EikNarF
FRS Member
Drives: FRS
My stock sending unit is bad. Gas level showing 3/4 full every time I pump at a station.
Looks like I need part# SU003-01106 and gasket SU003-01019.
I believe that I need to get to the one on the driver's side? or passenger's?
EikNarF is offline   Reply With Quote
Old 01-04-2018, 08:56 PM   #45
kowalski
kowalski's Avatar
Drives: 2016 brz
Extra-cautions for "doing everything in reverse"
True story. I just finished mine today (DW65c), but yesterday, after "doing everything in reverse" there was a gas leak from the top. It turns out the black plastic ring that sits between the pump basket and the cap was really messed up after adjusting back to fit the blue factory lines that indicate where the cap should be tightened to it's original position. So
A) Really be extra carefull to put first the black ring. Also I broke a clip from the hose and it was leaking there too. Big time.
B) Another thing to consider is, when taking apart the small metallic clip that prevents the coil to loosen up, be sure to do that on a boxed container or to fine grap it with some tool. Mine just jumped away and it was hard to find afterwars (doing the install on the outside for ventilation...).
The clip:
It is not a hard mod, but having to deal with the constant fuel vapors and the almost "break when looking at" clips was though. Also, C) if there are no leaks, check again when you do a full tank refill. It might not leak at half capacity, but do at full.
My 5 cents and a little pic of the pump basket once out.
kowalski is offline   Reply With Quote
Fuel pump and speed sensor Tt3Sheppard Issues | Warranty | Recalls / TSB 28 04-20-2017 02:54 PM
Fuel pump issue. sevi21 Issues | Warranty | Recalls / TSB 13 02-01-2013 10:57 AM
New tail lights and fuel pump inc MindtheGap Mid-Atlantic 14 12-19-2012 08:42 PM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 11:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
