Old 06-30-2013, 03:35 PM   #43
(BRZ)
(BRZ)'s Avatar
Wow... Beautiful
(BRZ) is offline   Reply With Quote
Old 02-18-2014, 09:38 PM   #44
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
awesome!!!!
wanna sell lol
Old 03-17-2014, 02:02 PM   #45
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
Any idea of how many degrees of negative camber you are running in the rear?
Instagram @admsevi
sevi21 is offline   Reply With Quote
Old 12-08-2014, 10:33 PM   #46
IDFWU 420
Honarary Member
IDFWU 420's Avatar
Drives: 2015 FRS
Does anyone know what color that is, please!?
IDFWU 420 is offline   Reply With Quote
Old 09-01-2016, 09:46 PM   #47
Michael
Lovin' the Low Life
Michael's Avatar
Drives: 2014 Scion FR-S
Does anyone have pictures of these 18x8.5 +32 wheels? Main post images are broken.
2014 Scion FRS: Bagged & Wide
INSTAGRAM: @frsmichael
BUILD THREAD: Click Here
Michael is offline   Reply With Quote
Old 09-02-2016, 01:36 AM   #48
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Similar:
http://www.ft86club.com/forums/showthread.php?t=53609
Old 09-02-2016, 01:55 AM   #49
Michael
Lovin' the Low Life
Michael's Avatar
Originally Posted by mav1178 View Post
What disks do you have? I did a search on and 18x9 +34 shows up as being available on T-disks and 18x.9.5 +39 as O-disks. Would that be correct? Do you have any angled pictures of the fronts that really show off the curves on the disks? Ideally, I want to run 0-disks all around with 18x8.5 +26 up front and either 18x9 +30 or 18x9.5 +39 (same as you have it) in the rear. My main concern is whether 18x8.5 x+26 O-disk will clear stock calipers up front. Below is a link to the post I made yesterday about this.
http://www.ft86club.com/forums/showp...postcount=3217
Old 09-02-2016, 03:05 AM   #50
mav1178
mav1178's Avatar
http://workwheelsusa.com/media/wheel...FR_2014_v1.pdf
There's nothing "angled" about the disk. I had T disk in front and O in rear.
The only difference between different disk type is the amount of lip you have. The face of the wheel remains the same, since it's a 3-piece wheel and not your typical 1-piece wheel.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Michael (09-02-2016)
Old 09-02-2016, 03:13 AM   #51
mav1178
mav1178's Avatar
BTW, the difference in brake clearance between A disk and O disk assuming the same width, is around 7-8mm.
So if you have 10mm or more of clearance to brake calipers with A disk, O disk will work.
-alex
Old 09-02-2016, 03:34 AM   #52
Michael
Lovin' the Low Life
Michael's Avatar
Thanks for that information. So the difference is essentially 13mm more lip with the O-disk from what I am gathering on that PDF file. I am OCD and would prefer the front to match the rear but stepping back, 1/2" less of a lip may not be that noticeable. The next thing that I need to determine is the brake clearance for the O-disk since I like that it has 6mm more inner lip clearance which is a good thing when I switch to bagged suspension. The A-disk has more brake clearance but it would require a 10mm spacer to sit flush with my fender as my current wheels do. If I go with the A-disk + 10mm spacers, I would then have 4mm more inner clearance than with the O-disk.
Hmm...
Old 09-02-2016, 05:34 PM   #53
Michael
Lovin' the Low Life
Michael's Avatar
According to Works Wheels USA, 18x8.5 O-disk will clear front and rear calipers. This is great news for my plans.
"Yes, 18x8.5 O-Disk would clear your OEM Scion FRS front and rear calipers."
Old 10-13-2018, 02:30 PM   #54
Devin11498
Devin11498's Avatar
Drives: 2013 Subaru Brz Limited
Originally Posted by MotivConcepts View Post
Specs are:
18x8.5 +32 with 225/40/18 Falken FK-453
18x9.5 +39 with 255/35/18 Falken FK-453
I cant seem to see these photos for some reason?
Devin11498 is offline   Reply With Quote
Old 10-13-2018, 03:28 PM   #55
Impureclient
Drives: 2015 FR-S
OP was last in here 4 years ago. It's time to move on and let him go...
Impureclient is offline   Reply With Quote
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x8.5 +47 / 18x9.5 +38 FML Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 91 06-13-2015 08:48 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x8.5 +38 / 18x9.5 +38 f0rge Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 01-16-2015 02:57 AM
Wheel Directory: BBS RS 18x8.5 +35 / 18x9.5 +35 JRoldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-07-2014 08:10 AM
Wheel Directory: XXR 531 18x8.5 +35 / 18x9.5 +35 Enigmus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 11-07-2013 12:43 PM
Wheel Directory: Work Emotion 11R 18x8.5 +45 / 18x9.5 +38 DR1FT Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-04-2013 01:16 PM
