Old 12-06-2011, 06:08 AM   #43
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
Originally Posted by Kostamojen View Post
I was just about to post this :p
I've been trying to find the dyno chart (subaru supplied chart from the .jp webpage) for that engine, but I don't think I saved it
At one point I was about to try and import one of those motors...
i heard that motor was pretty bad, not performance bad..but consumer bad. Like it had the shittiest economy and emissions for a 2.0 4cyl.
This is the only information i can come up with..
EJ204D AVCS (most specifically the BP/BL - Legacy/Liberty 2.0R)
Displacement: 1994 cc
Bore: 92.0 mm
Stroke: 75.0 mm
Power: 190 PS@7100 rpm
Torque: 144 ftlbs@4400rpm
Equip: AVCS (Active Valve Control System) Intake Only
Co2 Emissions: 210g/km
City MPG: 20
Combined MPG: 27.64
id like to see a dyno chart too.
WingsofWar is offline   Reply With Quote
Old 12-06-2011, 06:50 AM   #44
armythug
armythug's Avatar
Drives: Pegasus White 86GTS
Originally Posted by NESW20 View Post
"chasing horsepower" is not what this car is about, FYI...........
Hmmm I beg to differ. Toyota has given me the impression that this car is meant to be modified how the enthusiast wants. So in that case, chasing horsepower would be acceptable if one chose to do so.
Pegasus White 6MT got it. :happy0180:
armythug is offline   Reply With Quote
Old 12-06-2011, 07:03 AM   #45
m_life
m_life's Avatar
Drives: Toyota Supra SZ
Originally Posted by coyote View Post
Thanks Toyota. Next time stick to the clay modeling and leave the engineering to the experts.
I love this quote, I really do.
At the risk of sounding like a 'fanboy' its not exactly like Subaru are engineering marvels are they
m_life is offline   Reply With Quote
Old 12-06-2011, 08:33 AM   #46
serialk11r
Drives: '06 AM V8V Coupe
Dimman's comparison to twin injector bikes is basically the idea I think. When you only have direct injection, typically they will only put one direct injector into the cylinder for space reasons. Now there's a lot of ways you can arrange it but you can never quite get as good fuel distribution as when you have 2 injectors to play with. That's the idea Toyota is going at with D-4S, it is trying to get as even of a fuel mix as possible to reduce overall emissions, and in particular unburnt fuel. The port injector can almost be thought of as a compromise, except it has beneficial side effects like cleaning up the intake valve, and reducing low load emissions more effectively.
If you're chasing power, assuming the ECU is tunable then this is a great thing, as you basically don't need to swap injectors until you are pushing >>300hp (let's say conservatively, 2.5 times stock max fuel requirement). Either fueling system is capable of running the engine alone. Every bit of gas that goes into the cylinder via a high pressure direct injector rather than a port injector is GOOD.
Old 12-06-2011, 10:00 AM   #47
youngxlos
Drives: 2000 Toyota Celica GT-S
Great thread, keep the good info coming, have you guys heard of FORDs ECOBOOST engines? They are also DI and boosted, compression is at 10.0:1 though, but the logic they use is that they spray a mist of fuel to each cylinder to cool it down to avoid detonation at those compression levels, pretty cool technology if you ask me.
ECOBOOST article
youngxlos is offline   Reply With Quote
Old 12-06-2011, 10:01 AM   #48
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
I'd be happy with proper DI.
What do you define as "proper DI"?
You're making the article out to be more confrontational and emotional than it really is. If Subaru honestly had a problem getting free technology out of the deal, the FT-86 project might have been cancelled. Now they've got access to Toyota's 2nd gen DI for their Fx16 and Fx20 turbo engines so they can maintain competitiveness with the rest of the worlds engine manufacturers. How is this a problem?
It seems the only real concerns here are either the ECU might be encrypted because it's Toyota's, or that some tuners lack the engine calibration strategy knowledge to competently tune DI setups.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 12-06-2011, 10:17 AM   #49
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Bore: 92.0 mm
Stroke: 75.0 mm
City MPG: 20
Combined MPG: 27.64
Exactly. Which is why my second post cited that 197hp for a 2l itself is child's play. People have done better than that for over a decade. However Subaru has never done that with the presumed fuel economy ratings.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-06-2011, 02:47 PM   #50
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
“saddle-shaped” 50-litre lightweight resin fuel tank
This is interesting. Will the “saddle-shaped” tank also have the effect of "baffles" to prevent fuel starvation under high g-load?
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 12-07-2011, 12:49 AM   #51
PAImportTuner
Turbo Mafia Presidente
PAImportTuner's Avatar
Drives: U Mad?
Correct, but subtract AWD and 800lbs, add lighter rotational mass and redesigned manifolds and you'll get that 200hp @ 35mpg without DI.
Bore: 92.0 mm
Stroke: 75.0 mm
City MPG: 20
Combined MPG: 27.64
"the FR-S is going to have to give me a blowjob every time I touch the steering wheel if all it can make me smile with is the handling." - Maxim
PAImportTuner is offline   Reply With Quote
Old 12-07-2011, 01:47 AM   #52
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
wouldn't that still make the engine shitty?..Just because its 200hp on a lighter chassis and drivetrain...does that mean its viable?
I dunno...sounds kinda moot. Granted the EJ204 & EJ204D are miles ahead of the original EJ20.
Sounds like FA20 is still win vs EJ204D engine vs engine especially in emissions with the FA20 coming in at an estimate 130-140g/km.... I Just had wished that the FA20 came with AVLS or some sort of variable valve tech.
Id feel bad for people who would have to pay the big extra C02 tax premium if the car had came with the EJ204D.
Old 12-07-2011, 01:59 AM   #53
coyote
coyote's Avatar
Drives: Slowly
Does it not use Subaru's AVCS?
coyote is offline   Reply With Quote
Old 12-07-2011, 02:01 AM   #54
EJ20
EJ20's Avatar
Drives: NA8C, GDB, and R50
Since the heads done by yamaha (which is owned by Toyota) would it be possible to see an na fa20 with dual vvti and some bump in horsepower? Just like what they did in the early 1gfe that had only exhaust vvti, then in 2010 it had dual vvti with a bump of 25hp ?
EJ20 is offline   Reply With Quote
Old 12-07-2011, 02:09 AM   #55
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Not that I know of...The FB20 might....but the FA20 sounds like it doesn't have AVCS.
I dunno if they are going to go with VVTI or Valvematic or AVCS...I kinda have the feeling that if at all..it will have Subaru Variable Valve Tech in the future. Rather VVTi even if the heads have been work on by Yamaha.
Personally id like to see a strong Valvematic system or Dual AVLS
Old 12-07-2011, 07:47 AM   #56
mrtodd
Techmology.
mrtodd's Avatar
Drives: Scrapped project EH2
I completely agree, in fact, i'm really bummed that it didn't come with some sort of variable valve timing to begin with. I'd prefer the vvt-i as that also has control over valve lift and duration, in addition to valve timing... Honestly though, i think it's safe to say that the addition of ANY valve control system is just wishful thinking. I really don't think toyota or subaru are going to dump any more r&d into this engine - at least as far as the brz/fr-s chassis is concerned. Maybe i'm just a pessimist..
mrtodd is offline   Reply With Quote
86 forum, 86 forums, brz forum, brz forums, fr-s forum, fr-s forums, frs forum, frs forums, scion fr-s forum, scion fr-s forums, scion frs forum, scion frs forums, subaru brz forum, subaru brz forums, toyota 86 forum, toyota 86 forums
FT-86 Scoop by 7tune. Car coming in Nov. 2011 7tune-Adam Scion FR-S / Toyota 86 GT86 General Forum 122 08-14-2010 02:15 AM
