Old 01-28-2013, 07:39 PM   #43
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Nobody had time to check this?
Old 01-28-2013, 10:14 PM   #44
colHolm
Default User Title
colHolm's Avatar
It was my wife's birthday this weekend. I thought I'd find some time but I didn't. Can't promise anything for the next couple weeks either... Sorry
colHolm is offline   Reply With Quote
Old 01-29-2013, 12:48 PM   #45
NemeGuero
In for subscribe.
EDIT: may have time to pull the panel off tonight.
NemeGuero is offline   Reply With Quote
Old 02-02-2013, 03:48 AM   #46
Sportsguy83
Drives: Limited BRZ
Originally Posted by scottmcphee View Post
Okay next person to go into either door, check out some wires on the power window regulator E5 on left door or F1 on right door. Say which door because they might act different.
What is voltage observed on some wires running between the window switch and window motor, on these pins on the window motor connector:
Pin 5 white wire, when car acc power is active, and again when acc is cold.
Pin 1 white wire/black stripe, when acc power is on, window doing nothing, then again while window rolling up using switch on door. And does voltage change/drop when window reaches top edge? Continue to observe voltage and roll window down.
Pin 3 green wire, same tests as pin1.
Use a good chassis ground point wire for the negative lead on meter.
Originally Posted by 2forme View Post
I wish I caught this before I went to work. Anyone else have time today to test it?
Would there be any chance you could test this this weekend? I am looking at the instructions and I'm really lost...
Or @NemeGuero? :d Thanks in advance
Old 02-10-2013, 10:25 AM   #47
Sportsguy83
Drives: Limited BRZ
Bump in hopes anyone can help???
Old 03-05-2013, 11:13 PM   #48
Sportsguy83
Drives: Limited BRZ
@Andrew@Autolux
Woudl you be able to help checking this out? It would be awesome. Thanks!
Old 03-06-2013, 12:08 AM   #49
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Haha calling me out! I just moved this weekend and my life is in boxes. I'll see what I can do!
-Acree
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
Old 03-06-2013, 01:10 AM   #50
Sportsguy83
Drives: Limited BRZ
-Acree
LOL! Not calling you out, more like a cry of desperate help!!
Thanks for the help. It really doesn't need to be a rush. Just whenever you can
Old 04-12-2013, 06:32 AM   #51
Sportsguy83
Drives: Limited BRZ
@scottmcphee
Its never too late!
Old 04-25-2013, 01:26 PM   #52
xjohnx
Grip>Slip
xjohnx's Avatar
There's a chance i may be yanking my passenger side door panel (possibly both, but doubtful) either tonight or this weekend. can someone give me an idiots guide to actually conducting the tests @scottmcphee needs?
Old 04-25-2013, 01:27 PM   #53
Sportsguy83
Drives: Limited BRZ
Hopefully he comes in and answers! That would be awesome!
Old 04-28-2013, 09:54 AM   #54
scottmcphee
scottmcphee's Avatar
Drives: 06 Subaru Legacy
Attached the schematics for the car.
In the front they talk about how to use a meter and do troubleshooting.
On page 261 and 262 you see the module and wires I'm talking about.
When the door panel is off you should (?) be able to spot the window motor, take some pictures of the door layout and some closeups of plugs and wires in there and post up here.
I can help navigation to what I want if I can just see it.
Thanks
TapTurn flasher learn more here.
scottmcphee is offline   Reply With Quote
Old 04-28-2013, 12:36 PM   #55
xjohnx
Grip>Slip
xjohnx's Avatar
Doesn't look like it's going to happen this weekend, boo rain. man i need to build that garage.
Old 04-28-2013, 12:49 PM   #56
xjohnx
Grip>Slip
xjohnx's Avatar
i did find this photo of the wiring harnesses if that helps:
back of switches
EcuTek Tuning advancements unleash unlimited possibilities Visconti Engine, Exhaust, Transmission 27 03-03-2013 03:27 PM
