#43 |
Site Moderator
Drives: Stuff
We don't know the MAP/street price yet though.. unless MFactory uses the same price for MAP as MSRP...
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#44 | |
Grip>Slip
#45 | |
Site Moderator
Drives: Stuff
There was a time that Craig, Matt and myself could have done that install blindfolded...
-Dave
#46 | |
Grip>Slip
I think i've been one upped. |
#47 | |
Site Moderator
Drives: Stuff
![]() I should be seeing Will next month, stopping by Nick T's shop for some drinking and Will is (last I knew) planning to come out. Jack never shows up to anything besides Expo these days. Oops off topic sorry guys lol
-Dave
| The Following User Says Thank You to Dave-ROR For This Useful Post: | xjohnx (11-15-2012) |
#48 | |
VehicleDynamicsSpecialist
Drives: iG FR-S
I could easily appreciate the mechanical gain in all gears. Let alone your decreasing the load on the motor. decreased load can also improve fuel efficiency And yes, I'm aware that it doesn't add power but it has certainly decreased lap times on track. YMMV. I'm fully aware of the pros and cons here. Peace.
"The best track modification you can ever make is between the steering wheel and seat." - CSH Last edited by ill86; 11-15-2012 at 05:00 PM. Reason: edited to spell out sarcasm |
#49 |
Drives: Whiteout FR-S
I used to have a Dodge Ram with a 5.7 and 4.56 gears were a very common upgrade on them, it didn't even really hurt the already poor gas mileage. I think a ring and pinion set should be about $400 though i guess with those platforms though there are a lot more sales to be had.
#50 | |
Drives: iG FR-S
Please note however, the first ones out of Japan (auto factory) are $1200+.. So, $750 doesn't seem that bad. ![]() Cusco has some available now as well. With and w/o lsd pricing.
"The best track modification you can ever make is between the steering wheel and seat." - CSH |
#51 |
Reverse Burnouts
Drives: 2013 Argento FRS
It would be awesome with a 5.11 gear in an AT. It would close the gear ratio difference between AT and MT, coupled with faster shift times!
Maybe ECUtek has a solution for tuning the transmission?
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
| The Following User Says Thank You to carbonBLUE For This Useful Post: | zohare (04-25-2014) |
#52 |
Drives: '06 AM V8V Coupe
#53 |
Not neccessarily, you would think a lower gear ratio would always provide worse mpg but if you do primarily city driving i think the opposite would be the case. If you are on the freeway 60% of the time or more then yes mpg would most likely suffer.
#54 | |
The only time a shorter gear is possibly more efficient than a longer gear due to decreased load is if you're rolling in 5th/6th gear off throttle at idle, because the load on the engine is too high for efficient combustion. For small engines hypermilers observe that rolling in 4th gear at idle gives the best fuel economy. Above ~1200-1500 rpm, increased load is higher efficiency for all practical purposes (usually you need 2000rpm before maximum load stops seeing a large efficiency drop). |
#55 |
Honestly most people willing to change out the ring and pinion probably aren't worried that much about mpg's though, you have a valid point but if you are worried about gas mileage you probably wouldn't be in this thread unless you wanted the higher ratio's.
| Tags |
| 4.5 final drive, 4.7 final drive, final drive, mfactory, ring gear and pinion |
| Considering going to 3.727 gear/pinion in 6MT | HotLavaMann | Engine, Exhaust, Transmission | 83 | 01-10-2015 11:34 AM |
| Final Fantasy | jay4prez | Off-Topic Lounge [WARNING: NO POLITICS] | 66 | 08-25-2013 11:31 PM |
| Final 13' BRZ brochure | poormans_LFA | BRZ First-Gen (2012+) — General Topics | 29 | 03-31-2012 03:43 AM |
| Brand new FT-86 video w/ring tone link - Final reveal | ezmayo | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 7 | 12-01-2011 07:40 PM |
| Possible Final production cuts. | Syldrin | Scion FR-S / Toyota 86 GT86 General Forum | 46 | 11-23-2011 10:02 PM |
