Old 11-12-2012, 09:49 PM   #43
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Originally Posted by No Limit Motorsport View Post
I bet it is going to be an insert for the front, and a bolt in for the rear.
Ding ding ding...
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
Old 11-19-2012, 09:26 AM   #44
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Originally Posted by Turn in Concepts View Post
The adjustment in the rear is easy to get to. Just pull the carpet back a bit. The fronts are also pretty easy, but with the original camber plates we have we can't use the adjustment knobs. The NEW (wait till you guys see these!) camber plates allow for enough room on the nut to use the provided knobs.
There is no perch height adjustment like on some koni shocks.
They work amazingly well with the RCE yellows that we have on the car. The yellows feel pretty good on the stock dampers, but used on the konis there is a heightened level of grip. The level of control over the stock dampers when hitting large bumps is amazing.
Tony
I'd love a set of Koni shocks on RCE Yellows. I just won't do inserts, though. That's a half-assed solution in my opinion. I don't feel comfortable re-using the stock shocks on aftermarket springs, so I'll wait for good shocks or go to a coilover setup.
I'm getting itchy and I really want to get a new suspension, but I won't go with a half baked solution.
Grimlock is offline   Reply With Quote
Old 11-19-2012, 09:36 AM   #45
AZP Installs
What is your reasoning behind not liking inserts? Koni has successfully been using the insert system for years. We have actually raced on Koni inserts on all 4 corners for sprint and enduros. If they are installed properly/professionally, inserts work as well as any "regular" struts. We've installed probably 300 sets maybe more in the past 10 years and they perform well and haven't had any issues with longevity. The Koni lifetime warranty is also nice for a street driven car as well.
-Mike Paisan
Old 11-19-2012, 10:25 AM   #46
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by dale.m View Post
I ran this exact setup on my D Street Prepared 2002 VW GTI and won just about every autocross I entered by a good second or two. I'm considering a similar setup for this car as the control arms look like they could take a 20mm-30mm drop.
you don't win auto-crosses by 2 seconds from a damper and spring upgrade, sorry broskies, i think you've just had poor competition.
The Following User Says Thank You to 7thgear For This Useful Post:
AZP Installs (11-19-2012)
Old 11-19-2012, 10:52 AM   #47
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
-Mike Paisan
I'm not saying that inserts won't perform well enough. I just don't like cutting apart perfectly functional shocks that I could possibly resell or put back on the car when I want to sell it. I'd rather get full-bodied shocks.
Old 11-19-2012, 11:02 AM   #48
AZP Installs
Gotcha. I've always just left em in or sold the swapped Konis to someone with a stock setup if I were parting out my car.
-Mike Paisan
Old 11-19-2012, 11:06 AM   #49
gmookher
I will keep the OE springs and struts to sell if and when the car is sold minus suspension. Once can off load the custom blue anno GC/Koni setup I just ordered for a bit more $$ than the cut-n-gut I considered. The coilovers will keep some value should I ever ebay those.
gmookher is offline   Reply With Quote
Old 11-19-2012, 11:37 AM   #50
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
inserts are a pain in the ass if you don't have access to drills, tube cutting tools and a general work area that would allow you to leak fluid all over and not give a fuck
if i was to get inserts i would have to pay a mechanic quite a hefty sum to install them, the final cost would end up being more than a competitor's off the shelf ready to use unit.
Not everyone has personal garage to tinker in.
Hell, I barely have a space to store my jack and tools!
Old 11-19-2012, 11:43 AM   #51
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
The only way i'll buy the inserts is if somebody (RCE) puts them in a stock housing and allows me to send my old ones back as a core...
JoeBoxer is offline   Reply With Quote
Old 11-19-2012, 11:44 AM   #52
AZP Installs
Interesting. When we started we did them on he city streets of NYC. No garage at all. As for making a mess, an oil pan you use for oil changes is all you need to catch the fluid. Cutting tools are a pipe cutter from Home Depot under $15.
I am unaware of any off the shelf units with the performance and warranty of the Konis in he price range.
We only charge about $90 more than a regular spring install to do Konis. So for under 300 labor they can be installed.
-Mike Paisan
Old 11-19-2012, 01:46 PM   #53
Calum
That Guy
Drives: 2013 asphalt FRS MT
-Mike Paisan
Nice, I wish you guys were near me.
You gotta appreciate that something like this could be intimidating to someone that's never done it before.
Old 11-19-2012, 03:22 PM   #54
Racecomp Engineering
I'll admit it's not something that's fun to do, but Konis are pretty darn good shocks and the only option at this point. Bilsteins will come as a full replacement, and be awesome, and we will have a custom valved sport option....but it's gonna be a while.
The inserts are intimidating but I don't know of anyone that's screwed it up. I do recommend getting an extra set of used front struts to use as your donors though.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Old 11-19-2012, 03:26 PM   #55
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
- Andrew
I assume (I don't know much about RCE so forgive me) that the revalves will be very well matched to the RCE springs? They (Springs) are on my short list of springs to do STX autocrossing until I can afford JRZ/KWs.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 11-19-2012, 03:47 PM   #56
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Listen if you want to measure ****s I'm all for that, there are many things you can do if you have the will and determination.
thats already 300 more than zero, the cost for me to do a regular install myself without having to cut drill and drain anything. A torque wrench and a few 14mm sockets is all one needs. For someone like me your 90 dollars extra is actually 390 extra because.
assuming we're talking generic cars, since nothing for this has been announced yet, bilstein sports come to mind as a direct and quality competitor.
Performance Brake Components from ECS Motorsports Hawk | StopTech | DBA & More! AJ@ECSMotorsports Brakes, Suspension, Chassis 32 03-09-2014 12:18 PM
86Drift Exhaust Systems and Components 86drift Engine, Exhaust, Bolt-Ons 11 10-09-2012 05:58 PM
2 way possible in BRZ?? - JBL MS-62C 2 way components stevan Electronics | Audio | NAV | Infotainment 0 09-27-2012 06:35 AM
Components to upgrade for forced induction wbradley Forced Induction 12 09-24-2012 02:11 AM
Boston Motorsports: >>>Whiteline Suspension Components! Boston Motorsports Brakes, Suspension, Chassis 6 07-24-2012 02:07 PM
