Old 04-28-2013, 12:14 PM   #43
SoCal_86
テック
SoCal_86's Avatar
Drives: 85 Toyota Corolla GTS 13 Scion FRS
Very Impressive! Well done
SoCal_86 is offline   Reply With Quote
Old 06-07-2013, 07:13 PM   #44
lionbacker54
lionbacker54's Avatar
Drives: 2013 WR Blue 6MT BRZ
You sir, are a gentleman and a scholar. Thank you taking the time to show us how it's done in case we ever do the same
lionbacker54 is offline   Reply With Quote
Old 06-08-2013, 11:22 AM   #45
charged86
charged86's Avatar
not bad. shouldn't have "hard taped" off where you were applying color. looks really good from 5 feet away tho
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 06-08-2013, 05:13 PM   #46
ZetaVI
Gundam Meister
ZetaVI's Avatar
Drives: A Gundam
Most impressive DIY yet.
Old 06-09-2013, 11:01 AM   #47
djdnz
1337
Drives: 2013 BRZ WRB S/C
Looks quite good, nice job. I likely wouldn't have taped so close when I was respraying, but I think with some polish a few weeks down the road you will be able to cut the hard line down so it would not be noticeable.
djdnz is offline   Reply With Quote
Old 06-09-2013, 11:33 AM   #48
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
I'm just an amateur painter, but I'm guessing instead of taping, you would apply without taping, and wet sand the overspray for a blend?
I have a similar, but not so dramatic blemish I've just covered with touch up paint for the time being.
4 coats of paint and clear? or?
Thanks to the OP for taking the time to post good information and think about the community enough to share it.
Deadspool is offline   Reply With Quote
Old 06-09-2013, 02:21 PM   #49
charged86
charged86's Avatar
hard to explain on text. but when doing a professional blend. you pic a larger area than the damaged area. ln this case after doing the repair wet sand with high grit 1500-2000 uniformly. like up to the headlight, fender to bumper and maybe all the what to the mouth of bumper then tape on body meeting with the body and hood. then mask off entire vehicle. dust several coats on the damaged are do not get color further on to "good" areas as much as possible first two coats on the primer only. then two more light coats going passed original primered area. then when doing clear start by clearing areas that received color. then last coat to edges and slightly beyond your blend area.
I should try a real diy in next time I get a bumper repair
The Following User Says Thank You to charged86 For This Useful Post:
Billylammerkins (12-10-2013)
Old 11-30-2013, 01:52 AM   #50
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
That was a huge ass gash lol good job tho.
Old 12-01-2013, 03:29 PM   #51
raxman
So many questions.
What was the clear coat you used? Got a link from where you got it?
On the site: http://www.automotivetouchup.com/tou...paint/buypaint
Which did you buy? Just the normal aerosal paint or the ready to spray? What IS the ready to spray paint?
I am in the same boat, but my front bumper is scratched in the front near the license plate. The size of the scratch is 1in wide and .5 in tall.
raxman is offline   Reply With Quote
Old 12-10-2013, 02:35 PM   #52
Billylammerkins
Billylammerkins's Avatar
Drives: 2014 Firestorm Red FR-S 6MT
Can you give a more detailed step by step process of what you did and what you used PLEASE!?
Billylammerkins is offline   Reply With Quote
Old 12-10-2013, 05:06 PM   #53
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by mashal View Post
How did you look up the code ? I need some paint coz I put some nice damage on my bumper too, also where did your order the paint from?
I-Tapatalk
The code should be on the door jam of the car.
Old 01-03-2014, 06:50 PM   #54
DrawingWaves
DrawingWaves's Avatar
Drives: RS 1.0 #633
My car is the same color so I'll sub to this in case I ever damage mine. Nice fix. Looks mint.
"Drive fast on empty streets with nothing in mind except falling in love and not getting arrested." - Hunter S. Thompson
DrawingWaves is offline   Reply With Quote
Old 03-25-2015, 08:03 PM   #55
awhatzable
Drives: GTS86
Originally Posted by SkitterSkotter View Post
Yes I used a 120 grit to grind down the roughest of the plastic weld then I moved to 220. After that, and for the final step, I used this green sponge like sanding instrument to polish it even more. The paint job is really in the sanding, the second paint goes on all the prep work instantly shows.
Did you use wet or dry sand paper and can you post a picture of the green sponge like sanding instrument and also, how much sand paper of each did you need ?
My damage is the same size but with all the paint scraped off down to the plastic.
awhatzable is offline   Reply With Quote
Trading BRZ bumper for FRS bumper WHITE just86 Exterior Parts (Aero, Lighting, Etc.) 7 12-09-2012 02:08 PM
very bad 323i fixed bryansbestwax Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 06-27-2012 12:20 AM
Can this be fixed? Longhorn248 Site Announcements / Questions / Issues 10 06-20-2012 07:48 PM
So the dealer messed up... koolhawk BRZ First-Gen (2012+) -- General Topics 26 06-18-2012 08:19 PM
Messed up? You decide. Godzilla35 Scion FR-S / Toyota 86 GT86 General Forum 66 05-15-2012 02:20 PM
