Old 03-27-2024, 06:02 PM   #43
KiK
KiK's Avatar
Drives: 20’ GT86
Originally Posted by J95 View Post
Hey man, for me also the car does not behave well, but as I wrote above, I believe there is something wrong with my installation. I have to take it to the mechanic and then Id be happy to share some thoughts regarding the setup.
Actually, I talked with KW and maybe I can get a replacement springs of 50-170 to substitue my current 50-200 that I have at the front. Then I should be able to lower the car more (as I wrote, it dropped only like 20-25mm at it is already in its lowest position). @Racecomp Engineering do you think it is a good workaround?
I have the following setup:
Front: rebound 10 clicks from full stiff, bump 7 clicks from full stiff
Rear: rebound 9 clicks from full stiff, bump 8 clicks from full stiff
I have aprox. 40mm lowered (and had to jack up the front quite a bit).
The ride quality is great with this setup.
Can you show a picture of your front coils? I found it very weird as my fronts were actually really easy to slam.
KiK is offline   Reply With Quote
The Following 2 Users Say Thank You to KiK For This Useful Post:
J95 (04-02-2024), Racecomp Engineering (03-28-2024)
Old 09-26-2024, 07:36 PM   #44
J95
J95's Avatar
I disassembled the coilover and took these pics
https://photos.app.goo.gl/U9aT4CpyUpKjWQY27
At this perch height, I get -26mm drop (340mm wheel hub to fender), and I measured aprox. 32mm of bump travel to the "start" of bumpstop, and 43mm droop
It's like the cs top mounts behave the same height as oem mounts. Quite confusing since already 3 persons in this thread agree obtaining a different result @marco_mc22 @Racecomp Engineering
J95 is offline   Reply With Quote
Old 10-04-2024, 05:19 AM   #45
MrSkubi
MrSkubi's Avatar
Drives: 24 GR Yaris, 23 GR86
Kind of late but here's the pic I promised
MrSkubi is online now   Reply With Quote
The Following User Says Thank You to MrSkubi For This Useful Post:
J95 (10-05-2024)
Old 10-05-2024, 01:32 PM   #46
J95
J95's Avatar
cool thanks. At the end, I took the coilover to a shop to make sure everything is in order, and it is apparently. I put the ride height at F 331mm/R 340mm and it should be ok. I measured front droop and calculated that bump travel might be around 25-28 mm at the spring
Probably the CS top mounts don't add more than 5mm of bump travel
@KiK did you refine your bump/rebound adjustment?
KW Clubsport 3-way Valving TRAKRAVN Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 12-20-2019 11:45 PM
Using KW Clubsport top mounts for KW V3 thpark93 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 03-20-2019 12:39 PM
Tein SRC vs. KW clubsport 86wtywly Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 04-02-2017 05:55 PM
