BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
04-20-2023, 09:04 PM | #43 |
Drives: 2005 Toyota Camry
there's one other reason why there's little/no camber for a street car from the factory.
when you have camber your car tends to follow the crown of the road more, and also will have a tendency to tramline more. So the last thing you want as a maker of a vehicle is for people to complain their car is all over the place when it is unmodified... https://www.tirerack.com/upgrade-gar...ses-tramlining |
04-21-2023, 12:30 PM | #44 | |
Drives: '23 BRZ
Plenty of other performance cars have utilized *some* front camber. 0 degrees is pretty lame... |
The Following User Says Thank You to ZDan For This Useful Post: | OkieSnuffBox (04-24-2023) |
04-21-2023, 12:34 PM | #45 |
Drives: Crapcan
Mine started tramlining terribly once I went beyond 3
04-21-2023, 12:37 PM | #46 | |
I'm just stating the rationale of design engineers. Subaru is known to have their cars being conservative when it comes to vehicle dynamics. it is what it is. |
04-21-2023, 01:11 PM | #47 |
Drives: 2022 BRZ; 2014 BRZ
I don't find mine too bad at -4* of camber and 0 toe up front. Then again, my last car was a Camaro with 305s up front, so it would be hard to be that bad
04-21-2023, 01:58 PM | #48 |
I was actually surprised by the tramlining I got on the highway with stock suspension and -2.5 degrees front camber. The car followed grooves and ruts that I didnt even know existed before then haha. But I also swapped wheels/tires at the same time so I’m not sure which was the root cause. It was also one very specific section of highway and I haven’t noticed it as much on different roads.
2022 BRZ Build 2013 FR-S Build |
04-21-2023, 02:32 PM | #49 | |
Anti stance.
May as well play to the lowest common denominator for all activities. Wrap all kids in bubble wrap, and put a warning label on everything. |
04-21-2023, 05:02 PM | #50 | |
Drives: '22 BRZ
You are speaking from your own bubble. I bet a large portion of these cars will never see a track or an autocross course. Is it outrageous that they are being engineering with street driving in mind? I don't think so. You want some negative camber? Its super cheap and easy to get some crash bolts and there you go.. Is negative camber better for performance driving? Yes. Did I learn to drive with it after spinning out? Yes. Is 1.5 degree camber noticeable compared to 0 degree? Absolutely. Is 0 camber safer for street driving for an average driver who never done any performance driving? I am pretty sure thats a yes too Thats all I am saying. |
04-21-2023, 05:19 PM | #51 | |
Drives: Crapcan
04-21-2023, 05:50 PM | #52 |
Custom Switch Panels!
Drives: 2015 Subaru BRZ Series.Blue
There is no need for a 2-door sports car if you drive the speed limit on public roads either...
04-21-2023, 06:16 PM | #53 | |
Weight Weenie
Drives: 15 FR-S
04-21-2023, 09:01 PM | #54 |
Drives: 2023 brz limited 6mt red
Waiting for people to have a window sticker “0 degrees is lame”
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles |
04-24-2023, 07:50 AM | #55 | |
Anti stance.
04-24-2023, 12:01 PM | #56 |
Spelling Impaired
Drives: 2022 BRZ Limited WR Blue
There are so many variables in play, I don't know if you could blame tramlining on just the alignment of the car. From what I've experienced, tire tread, tire width, and even the way the groves/ruts are formed can play a huge part.
Not long after I bought this car I was on a roadrip in it with my wife, somewhere near Kansas City I think... Regardless of the location, it was on long stretch of fairly new concrete interstate with the groves cut in the direction of travel. The problem was the groves were not cut in a uniform manner. One moment I'd be sailing along just fine, the next the car was squirming and tramlining all over the place and just as suddenly it would stop when I drove onto the next segment. In a totally different incident with a different car I remember driving to a tire shop on one set of tires with no problems. Driving the same road on the way home I got wiggles from tramlining. The only variable which changed was the tires. |
Similar Threads | ||||
SOLD: Raceseng caster + camber - adjustable front camber plates | higrip | Brakes, Suspension, Chassis | 4 | 09-17-2019 01:43 PM |
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! | Corner3garage | Southern California | 188 | 04-24-2015 01:10 PM |
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! | Corner3garage | Mechanical Maintenance and Tools | 6 | 10-31-2013 03:40 PM |
